Question about Sharp AR-275 Copier
The copier will not copy, its an AR 275 SHARP. it said on it monitor panel " call for service H14-00.what can i do?
In AR 275 Sharp copier U2 40 is very common problem
Posted on Oct 06, 2010
Copy quality from my sharp AR 275 copier keeps fading away. I have replaced the drum. I cannot locate the corona wire. where is it located.
No corona wire is there on this model, you can find one saw teeth like portion inside the main charger it serves the purpose of corona wire you can find the charger assembly on the drum unit, you try to clean the charger assembly by washing it and drying it buy the sun light, better to replace the maincharger, drum, cleaning blade, and developer together. Rate this and vote for this .
May 18, 2011 | Sharp AR-275 Copier
Call for service u2-40 sharp ar 275
CRUM chip communication trouble = the chip on the toner cartridge is faulty.
1, Try to clear the code press P, *, C, *, to enter the service simulation, on the key pad press 1,6, then the copy start, press execute on the screen.
2, Change the toner cartridge.
If it is a brand new one return to supplier as faulty, if it is a refilled new one take back to supplier (the CRUM chip serves as a genuine supplies protection for sharp and 'blows' when the toner is empty the re-filler will have to put a new chip on it)
Nov 16, 2010 | Sharp AR-275 Copier
I have a Sharp AR-M280N copier and it has an error code of L6-10 on it can you tell me what that means?
An L6-10 code means that the polygonal motor isn't rotating at 25,000 r.p.m. This motor is located inside the laser unit of the machine. You can try this procedure to try and reset the machine. Press the following buttons in this order: #,interupt,C,interupt,1,4.The operation panel may ask if you want to do this, choose "yes or 1". Then press the "copy" button as if you were making a copy. This will reboot the copier. The polygonal motor will need replacing soon regardless.
Oct 15, 2010 | Sharp AR-275 Copier
Paper jams at the fusing unit on my Sharp AR 275
Very common problem in that copier. The fuser unit has little pawls which seperate the paper from the rollers, they can become dislodged when customers remove jams. Another very common problem is the gear that turns those rollers wears down internallly, to check this make a mark on the orange fuser roller with a sharpie. See if the mark moves from it's previous spot after trying to make a copy. These rollers turn every time the machine is used or is turned on.
Sep 10, 2010 | Sharp AR-275 Copier
Sharp AR-275 Copier
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
May 19, 2009 | Sharp AR-275 Copier
Call for service U2-40, on a sharp AR275 printer
In AR 275 Sharp copier U2 40 is very common problem, U have to only reset the above error code as fallows
press # then intrrupt then c them intrrupt then display will show simulation mode then enter 16 then press ok key
pl ask for any difficulty
May 17, 2009 | Sharp AR-275 Copier
Sharp AR-275 copier with fax module. Need to edit sender ID
push custom or system setting button, push key operator programs on lcd, type in 00000 from number pad, hit fax settings, fax default settings, own name/number set. hit ok button at top when done then CA button to return to main menu.
Mar 04, 2009 | Sharp AR-275 Copier
Sharp copier printer error: PostScrip printing not licensed for t
what is you OS? check you printer drivers. are they properly installed?, what is your connection between your PC to your printer?, AR 275 can be connected thru network, parallel port, and a USB... they have different printer drivers
Feb 01, 2009 | Sharp AR-275 Copier
Sharp AR 275
Press and hold down "Copy" key. Total count will display, as will approximate percentage of toner remaining.
Jul 09, 2008 | Sharp AR-275 Copier
Sharp AR-275 Copier Logo
91 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
