Question about Intel Motherboard
Hi...i want ethernet controller for n1996 as its showing yellow Question in device manager...plz help
  • 4 Answers
Perhaps you can try updating driver software or refresh (scan for device changes) again to see if that error is still there.
Posted on Sep 30, 2010
(ethernet drivers HP n1996)PCI EXPRESS BUT I CAN NOT FIND OUT HERE
You will have to open up your network connections.
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled.
Click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow Question/ Exclamation mark ? ! or a Red X you will need to update/reinstall the driver for the device
You only need check the following if you cant install the driver
Make sure you Ethernet/internet is enabled in bios.
Restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press Enter make sure its enabled
then recheck the driveri t should be there
k the driver it should be there
make sure its enabledPci device arrows key scroll to nstalled
if you computer came with a motherboard disk the driver could be on it
or this disk provided by your ISP provider Internet Service Provider
or you might have to download one
http://download.cnet.com/wireless-atheros-ar5b91-7/3000-2112_4-202570.html
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
if these packages are not the right
http://download.cnet.com/2000-20_4.html
On the home page you should see a search tab just type in what you are looking for
tick in the box for windows software or all software box
IE: Motherboard name Wireless or Ethernet driver
you might have to try a few times to get it right
Dec 12, 2013 | HP 5188-5473 Motherboard
Acer mainboard n1996 drivers
If you are having problems with drivers
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver:
if your computer came with a motherboard disk the drivers could be on it
hope this helps
Jul 01, 2011 | Computers & Internet
Hi, i do have a n1996, ms-6547, motherboard, imtrying to download a fix for and also for usb 2 and i can not find them,thanks in advance
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)right click update driver
If your Device Manager shows an ENHANCED USB Host Controller, the system has High Speed USB (USB 2.0) capability.
Types of High Speed USB (USB 2.0) Host Controllers
· Intel Enhanced
· SiS Enhanced
· VIA Enhanced
· ALi Enhanced
· Standard Enhanced
· NEC Enhanced
The system shown has onboard Intel High Speed USB (USB 2.0) with an NEC High Speed USB (USB 2.0) PCI card installed.
The key word is ENHANCED. If you have an ENHANCED USB Host Controller then you have High Speed USB (USB 2.0)
All other types are USB v.1.1
hope this helps
Nov 11, 2010 | MSI MS-6547 Motherboard
I reinstalled the operatiing system & it won't to the internet. Doesn't show an network conn ection in the device manager just a yellow question mark by the ethernet controller. I've installed all the...
Here are the stpes that you can try..Go to Device Manger select ethernet controller, then right click, select Properties and then select Uninstall. After this re-install your Ethernet driver. The yellow question mark means that the computer is not detecting the device.
Sep 10, 2010 | Dell Dimension 2350 PC Desktop
Ethernet controller driver can,t be found
Hi there.
right click in the adapter with the yellow mark and select properties, look in the device status box, if it says code 10 the device cannot start then you installed the wrong drivers for the adapter.
Get the correct network controller drivers from here >>>>>>>>
http://support.acer-euro.com/drivers/notebook/tm_2480.html
If you still suffer the same symptoms after the correct drivers are installed then the device maybe faulty.
Good luck
May 30, 2009 | Acer TravelMate 2480-2153 Notebook
Pleas i m not getting the ethernet controller
You need to re-install your Ethernet driver.If you have Driver CD with you then first uninstall the Ethernet driver from device manager and install the Ethernet driver from you driver CD.
If you don't have driver CD with you then You can download ethernet driver by Clicking here.
Thanks
Mar 04, 2009 | HP Compaq nx6115 Notebook
Re. aspire 1360 wireless problem
hi there,
for your first question ..yes u are uninstalling from device manager. and the second.. the wireless card not showing was taken into account..cause the ethernet controller that has the yellow mark is your wireless card..it just does not have the drivers...hence the name ethanet controller....
try this link for the card listed in your post :-
http://www.laptopvideo2go.com/forum/index.php?showtopic=7172
Apr 10, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Intel Motherboard Logo
119 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
