Question about Epson TM-T88III (C420863)
Epson TM-T88II Partial cut driver for Windows 7 is not available
SOURCE: Hello, I bought an Epson TM
You can download from below link.
Click here
Click on above link and download driver then install.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Aug 11, 2011
SOURCE: can't install epson tm-t88iii serial
unistall the epson driver.
reboot your system.
connect and turn on the printer.
reinstall the driver, v3.02, selecting for create a serial port.
choose the right setting os serial interface.
after install, reboot your system.
it works to me.
Posted on Sep 02, 2008
57 varieties
  • 1653 Answers
SOURCE: TM-T88III print speeds and other issues
Try setting both switch 1-7 and 1-8 to ON for 38400 baud, set switch 1-2 to OFF to give a 4k buffer, set switch 2-5 to OFF to release the busy buffer at 256 bytes, set switches 2-3 and 2-4 to ON & OFF for medium print density and OFF & ON for dark print density or OFF & OFF for normal print density.
Also remember that the thermal TM-T88III also prints faster when the print head is cooler and slower when it heats up. The print speed is adjusted automatically depending on the voltage applied and head temperature. So make sure your power supply is providing a steady 24VDC at full load and has enough capacity to provide a peak of 7.7A in full speed mode. If you are using the printer in high temp and humidity you might want to swap the unit out for a Star Printer which performs faster and uses the same protocol or use a cooling fan.
Also make sure you use a good quality paper and that the humidity is within range at 10 – 90% RH although the paper performance will be greatly diminished at higher humidity levels.
Specifications:
High-speed = Approx. 150 mm/s {5.9"/s} max.; 47.2 lps, max. (3.18 mm {1/8"} feed);
35.5 lps, max. (4.23 mm {1/6"} feed, at 24 V, 28°C {82°F}, density level 1).
Low-power: Approx. 16.5 lps (4.23 mm feed {1/6"}); 70 mm/s {2.76"/s}
Ladder bar code: Approx. 42 mm/s {approx. 1.7"/s}
High-speed mode: Mean: Approx. 1.8A Peak: Approximately 7.7A @24VDC
Low-power mode: Mean: Approx. 1.2A Peak: Approximately 6.6A @ 24VDC
Operating temp = 5 to 45°C {41 to 113°F}
Operating Humidity = 10% - 90% RH
Posted on Aug 29, 2009
mephron
  • 8 Answers
SOURCE: I need driver for Epson
https://download.epson-biz.com/modules/pos/index.php?page=prod&pcat=5&pid=42 is the location for the drivers for the TM-U220 printers.
Posted on May 27, 2011
Geekman
  • 32281 Answers
SOURCE: driver install EPSON TM-T88IV serial in windows 7
You maybe able to download the driver from Epson's WEB site. If the Windows 7 printer driver is not available then this printer is too old and Epson would like you to purchase a later model printer.
You can download the Epson printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
Posted on Feb 25, 2012
I cant find any drivers for this product for windows 7
Use this link to download the Windows driver for this product, this is a universal driver for Epson POS printers should include support for multiple interfaces.
http://bit.ly/HBHPMc
Jul 12, 2012 | Epson TM T88II Label Printer
Need drivers for win 7 for TM-T88II
1. Do you get any error message?
I would suggest you to follow these steps and check if it helps.
Method 1:
Try following the steps mentioned in the below link to install the printer and check if it helps:
http://windows.microsoft.com/en-us/windows7/Install-a-printer
Method 2:
Try downloading the drivers from the below link, install and check if it helps:
https://www.epson-pos.com/cgi-bin/sdssm/main/soft.jsp?BV_SessionID=@@@@0883895352.1281895967@@@@&BV_EngineID=ccceadeldldgdljcefeceeedfhldfkl.0&oid=12885&sub_id=12888
or
Download and save the Windows Advanced Printer driver package from here..
http://pos.epson.com/developers/techresdetails.htm?productpk=642
When downloaded, double click the file to start the unzip process..
You will see a PDF document in the list to be unzipped..
Double click the PDF to open it and then save the PDF to your hard drive..
There is a section in the document which explains how to install the printer in Windows 7 32 and 64-bit..
Jul 12, 2012 | Epson Tm-t88ii M129b Pos Thermal Receipt...
I have a TM-T88IIIP model MI29C and windows 7 operating system. Do you have a download available for this?? Thank you Carol
Here's the driver link for the Epson TM-T88IIP Receipt Printer: http://www.posmicro.com/RECPRINTERS/EPSON/Epson-TM-T88II.htm
This link will take you to the download page for the manual as well. This driver is supposed to be for Windows XP but should work for Windows 7 32 bit OS. Give it a try - if it doesn't work or won't install, then post back to this solution and I will help you further. It is likely that a Windows 7 driver doesn't exist, but unless you have the 64 bit version of Windows 7 this driver should work one way or another.
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
May 03, 2011 | Computers & Internet
Looking for a Windows 7 driver for the Epson TM-T88II
1st You download Printer Driver. Epson TM Printer After this install the Printer driver in the system.
Installation of Printer Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
May 07, 2010 | Epson TM-T88III Thermal Printer
Is it possible to use my epson TM-T88II with Windows Vista?
Epson R360. Printer error. Please see your documentation?I have an Epson R360 and attempted to print a cd. As I put the tray in the printer didn't respond, when I looked at the screen the display was showing a message, " Printer Error. Please see your documentation" It advises to turn off and turn on again which I have done, several times. It was working directly before this as I had printed my daughters homework.
I uninstalled the drivers and reinstalled them to see if it would make any difference, but nothing. My printer just keeps telling me this message. When I power it up there is a lot of noise coming from inside the printer, the ink carriage is moving but not a great deal. Any help advice is appreciated.
Apr 26, 2010 | Epson TM T88II Label Printer
Specifications:
Aug 28, 2009 | Epson TM-T88III Thermal Printer
Can't install epson tm-t88iii serial
reboot your system.
it works to me.
Aug 19, 2008 | Epson TM-T88III Thermal Printer
How to auto tear paper after printing receipt is completed.
moz-screenshot-2.jpgIf you are using the generic driver you can get the code from epsonexpert.com site or try this
SELECT CUT MODE AND CUT PAPER ASCII GS V m
executes full or partial cut. HEX 1D 56 m
DEC 29 86 m
m = 0, 1, 48 or 49 cuts paper
SELECT CUT MODE AND CUT PAPER ASCII GS V m n
feeds paper and executes full or partial cut. HEX 1D 56 m n
DEC 29 86 m n
m = 65 or 66 feeds paper to (cut position + [n x (vertical motion unit)]) and cuts the paper
n = 0 to 255
8f9f602.tif
Apr 08, 2008 | Epson TM-T88III Thermal Printer
Epson TM-T88III (C420863) Logo
4,228 people viewed this question
Top Epson Televison & Video Experts
janman
Terry Dovre
Terry Dovre
Are you an Epson Televison and Video Expert? Answer questions, earn points and help others
