Question about Bosch Washing Machines
The door won't open on our Bosch Maxx 900. My daughter did a wash this morning. The read-out says ready, but the door won't budge. Any ideas?
  • Patrick Irwin Oct 01, 2010
    Thanks Gingko.
    I did drain it this morning, using the drain at the front, checked the pump filter; OK, and set it off on a wash.
    OK until it finished the rinse; then nothing.
    I'm draining it again. Looks like the pump is US, do you agree?
    I'll try and get the pump out and have a look at it.
  • Patrick Irwin Oct 02, 2010
    Thanks Gingko.
    Good advice.
    We had the pump replaced. Expensive ($A95, plus labour, similar) but we keep the machine working a few years longer, hopefully.
  • Bosch Master
  • 19,396 Answers
Hi.
You need to drain water out of the machine.
Disconnect power and first work on the drain hose at the back of the appliance, use a bucket to empty water placing the hose at the floor level.
Second part of drain job is done accessing the filter. the filter is connected to the drain pump. This is accessed through the service access located in front of the machine, on the lower side.
Remove the trim at the base of the machine using a lever, then unscrew the filter cap located at the left hand side, ensure that you have a container ready to collect the water.
At that point, try connecting back power and unlock door. Door should open.
If door still does not unlock, then the door interlock, the pressure switch or door lock may be responsible. In that case most Bosch have an emergency lock located near to the pump:
Posted on Sep 30, 2010
  • Ginko
    Ginko Oct 01, 2010
    Hi.
    The pump is tested by energizing it, but rather than jumping contacts (that is energizing) it is better if you just observe if pump is spinning (safety first you know).
    If the pump does spin, then the problem is not the pump, but probably the pressure switch, that is supposed to stop pump when drain is complete. Pressure switch is quite difficult to test, it is a $15 part, then often it is easier to replace it straight away.
    Before replacing the PS try blowing into and cleaning the thin rubber hose attached to pressure switch.
    If you think my comments are helpful, then please do not forget to rate the solution.
    Best regards.
    Ginko.
  • Ginko
    Ginko Oct 02, 2010
    Hi Pat.
    I guess we are talking about Au$ here.
    $95 plus approx same labour is a fair charge. Bosch parts are not cheap. I think the pump wholesale base price is about $88. Definitively worth repairing.
    Thanks for the feedback.
    All the best.
    Ginko.
  • 2,272 Answers
Try to open the door manually:-- Door lock manual release hole is held to the right side of the drain pump by a clip.Simply pull on the cable to release the door.To remove the access cover to use the door lock manual release.Insert a pointer object or too into the hole ,push it to release the latch and rotate the cover clockwise.-------------- Yes check the pump. Also :--- Some interlocks prevent the door from opening if the drum is moving. The mechanism that detects this is called a ****** unit and it is located around the motor pulley. It connects to the interlock via a cable assembly. If the ****** unit is broken in the "on" position it may be preventing the interlock opening. Visually check and try to activate the mechanism by hand.
Other interlocks have a secondary locking system which ties in with the pressure switch. If this system is faulty - caused by blockages in the filter, pressure vessel or the thin rubber pipe running to the pressure switch the machine "thinks" its still full of water and wont allow the door to be opened. Take off the top cover, examine the interlock from behind and detach any rubber pipes or cables to try to open it from inside. If all else fails, the interlock itself may be faulty and will have to be broken open. A replacement interlock unit and/or catch will of course be required.
------------ Check out.Keep updated.Thanks.
Posted on Oct 01, 2010
What is error E:00 in Bosch maxx 6 washing machine?
error E:00 in Bosch Caroline, Could not find anything pertaining to this Bosch code. You may be can contact Bosch at last link posted or download manual.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Identify Bosch Washing Machine Error Codes
How to Identify an Error Code on Bosch Washing Machine
Washing Machine Error Codes Front Load and Top Load Washers
Download instruction manuals
Apr 02, 2016 | Bosch Maxx 6 WAB28260GB White 600 mm...
Purchased s/hand Bosch maxx 900. Which draw do I put the soap in
if in doubt put on and open drawer and c wich one has water going through it
Feb 27, 2015 | Bosch Washing Machines
Bosch Maxx washer door jamb
IF THEIR IS A DRAIN SYSTEM (BESIDES THE BACK OF THE WASHER) SHOULD BE AT THE BOTTOM RIGHT... IF YOU TAKE THE CAP OFF AND LOOK UP (ON YOUR RIGHT) YOU SHOULD SEE A LONG PLASTIC PIECE HANGING.. WHICH IS LIKE A KILLSWITCH PULL IT DOWN....THAT SHOULD POP THE DOOR OPEN
Jun 01, 2013 | Washing Machines
I'm having spots comming up on some washing, Bosch Maxx 900
This video will show you how to change a door seal on this Bosch Maxx 900
Jan 11, 2010 | Bosch Washing Machines
Bosch maxx wfl 1300 washing machine that wont start.
hello could be brushes on the motor. there are 2 black clips that sit on the motor after time these whare down just slide them out and slide new ones in good luck
shaun
Jul 21, 2009 | Bosch Washing Machines
Washing Machines Logo
2,325 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
