Question about iLO IWT3206 TV
I can't change from SAP to Stereo on my iLO IWT3206 32 inch TV. I have no remote, but there isn't an "Audio" option on the menu for the TV unit itself. How do I fix this problem?
5 Suggested Answers
  • 126 Answers
SOURCE: My ilo tv picture is 1 1/2 inches. How can I fix this??
its a vertical problem could be bad cap or possible vertical i.c. okay take to tv shop is their still a warrany on this set sounds pretty new shad
Posted on May 15, 2009
r_wensell
  • 51 Answers
SOURCE: It just went out nothing iLO IWT3206 32 inch
I am sorry but I am unsure of what you are asking. If your tv wont do anything right down to not turning on I suggest you either take it to a repair shop or contact FUNAI CORPORATION.
To contact them here is their info:
FUNAI CORPORATION
Customer Service
Tel :1-800-605-8453 Press option 4 to order new remote.
http://www.funai-corp.com
Posted on Aug 28, 2009
r_wensell
  • 51 Answers
SOURCE: remote wont change to vid1, vid2 please help
The GE universal remote #24914 works to change your Ilo tv from analog to digital and switch to vid1 or vid2 ect.... The code is in the book that comes with the remote. I use this remote myself. This remote can be bought at Target for under $10.
Posted on Sep 03, 2009
  • 8457 Answers
SOURCE: Some of my channels are in sap and I don't
Sorry the SAP function are only can be change in the Audio option menu or the tv original remote only that have the SAP button.Try website like Remotes.com to buy the tv original remote.
Posted on Apr 19, 2011
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
Ilo tv in spanish need english
To change the menu language of the TV using the remote:
Display the menu screen.
• Press [MENU].
6 menu items will be displayed. The third item will be ENG/ESP/FRA
Select "ENG/ESP/FRA".
• Using [CH up / CH down] buttons, select "[ENG]/ESP/FRA".
Every time you press [VOL up / VOL down] buttons, the language
will be advance to the next. Select the language. When ENG is selected, exit by pressing [MENU]
If you are trying to change the AUDIO of the TV, simply press the [AUDIO] button on the remote. This will advance the selection between MAIN, SAP and MONO. MAIN is the native language of the program (often in stereo), SAP is "secondary audio program" - which is usually a second language, but may be an audio source not related to the picture at all. MONO is monophonic, or a single sound source that is the result of combining the LEFT and RIGHT stereo channels to one output or speaker. This selection is often a downgraded version of the stereo output provided by the MAIN audio selection - but may be useful under certain conditions.
You can review your manual here. Pg. 31 has details for the menu display language selection and pg. 16 has details for audio language selection.
If you found my answer to be helpful, please rate it "very helpful" Thanks & good luck!
Aug 22, 2011 | iLO IWT3206 TV
Some of my channels are in sap and I don't have an audio option on my menu nor the orignal tv remote. How do I change it?
Apr 19, 2011 | iLO IWT3206 TV
We bought a universal remote to increase our access to cable channels. Some of the channels display the symbols S.A.P. and have no volume. How do we disable the S.A.P so we can hear the volume.?
S.A.P. Means Secondary Audio Program.
SAP, Mono, Stereo, Etc. You should be able to switch this from your remote. Even universal remotes should have this button to adjust sounds. Otherwise you need to go into the TV menu (not the remote) and change it from there. The only way you can change it on those channels is to switch manually. Happens a lot on these older TVs. No worries. Very common.
On many sets, the audio channel can be switched by remote control or through a SAP switch located around the tuning panel or "on screen programming." Usually, there is a setting labeled SAP, AUDIO SELECT, B-AUDIO, MTS, or MENU. By changing the setting, you should be able to select SAP. Not all TV sets are alike, so you might want to check your instruction manual for all the details.
Mar 10, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
There is no sound from the unit. I have no remote but it says it is in sap mode. can I correct this?
SAP means "Separate Audio Program" - usually SAP mode is for changing the language of the broadcast (i.e. from English to Spanish) and is also used to enhance the sound broadcast of some programs.
Not having a remote may make this difficult.... you need to find a way into the set's menu- some sets have a "menu" button on them..... some require two buttons be held down together.... look at the set carefully.... if you have the manual, it is a good time to look at it.
When you get into the menu, find the AUDIO menu and de-select SAP. Your sound should be restored.
If you cannot get into the menu, you will need a remote. Write down the brand and model of your set, go to a decent electronics store, and browse the "universal remotes". Find one that supports your set and follow the instructions to set it up for your television. You will then be able to access the menu and turn off SAP.
Jan 28, 2011 | Televison & Video
Audio only has mono how do you change it
If you open the menu,there should be an option for sound.If you have a universal remote,you will probably have to do it with the buttons on the TV.SAP and stereo are about the same.It most likely cycles through mono,stereo,SAP with the volume button.Good luck!
Aug 05, 2010 | Sharp Televison & Video
Lost volume on some channels
enter in menu, in audio side put in stereo, no in sap.
Apr 02, 2010 | iLO IWT3206 TV
What is sap and how do you turn it off
SAP is an alternate audio program usually seen in markets with different languages. The most common is for a Spanish broadcast of an English program. It is also used to provide audio descriptions of programming for the blind. There should be a menu option under Audio to turn this on and off.
Dan
Mar 03, 2010 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
I cant get SAP off the tv
Access your menu, and navigate through.
Look for the Audio option then something with the words "SAP" or "Secondary Audio Programming"
then, of course, change it to mono or stereo.
With your universal, press the "TV" button or the button you would press to have it communicate with your TV, then press menu or settings.
Dec 12, 2008 | Televison & Video
TV problem
Might be as simple as you have the SAP or second audio progam turned on, go in to the sound menu of your set and see if it's set to S.A.P if so turn it to Stereo
May 15, 2008 | iLO 2600 Television
iLO IWT3206 TV Logo
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
