Question about Frigidaire Dryers
My Frigidaire Dryer works it is turning and doing everything but it is not getting hot....no heat at all
  • Frigidaire Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 30, 2010
Everything works on my frigidaire LER331DSO but it does not get hot
Thank you for your post, friend!
Based off what you have described your Frigidaire dryer is not heating up properly. Sounds like a possible problem with your element, thermostat, or control panel. You should also check to make sure there is not a build-up of lint or debris within the vent or vent assembly. A build-up could cause your dryer to stop heating. If there is not a build-up on your dryer, then in order to accurately diagnose your dryer you would need to disassemble it and test each component. This is not a simple DIY job. To properly take apart your dryer you should inquire assistance from a professional technician. They will have the tools needed to properly remove and test each part on your dryer. I hope this information is helpful. -Matt
Mar 14, 2015 | Frigidaire Dryers
Top of dryer and the back panel get too hot.
Of course they get hot, that is normal.
Jun 30, 2017 | Frigidaire AEQ6700FS Dryer
DRYER WILL NOT HEAT UP
It's either the fuse, heating element, thermal cut-off or thermostat
May 26, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire dryer doesn't produce heat, but everything else is working. What do I do to fix that problem?
Unplug remove panels necessary
Check the element for breaks or issues
if no problems found replace the safety devices directly in line with the power supply for the element
Nov 15, 2011 | Dryers
Everything on the dryer works but it is not getting hot at all. I am not familiar with gas dryers. Where do I start and what could the problem be?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 03, 2011 | Frigidaire FGR311F Gas Dryer
Frigidaire AGQB6400FS not hot
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 30, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Dryer turning but not getting hot, what could be
heatman101
May 21, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire dryer problem
The vent duct length's sound fine.
Have you confirmed that the heater element is working? You don't mention whether the unit get's hot.
If it get's hot, then suspect the thermostat, or the overtemp stat.
Also, be suspect that users are overloading the dryer.
Also make sure that you feel a strong blast of hot air discharging at the vent end, with the washer/dryer in place.
Check that the vent grills inside of the dryer are clear.
Reply back and I can help you further.
Feb 03, 2009 | Frigidaire Dryers
My Dryer won't get hot
try doing the following checks--
  • Check for proper air flow
  • Test the safety fuse
  • Test the thermostats
  • Test the centrifugal switch
  • Test the timer motor
  • Test the heating element
If you need the manual check the following link.choose the manual for the appropriate model.
http://www.retrevo.com/samples/Frigidaire-Dryer-manuals.html
Dec 11, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire Gas Dryer not heating up. Other elements are all ok.
It sounds like your igniter is no good. At all costs, check the Fuse before anything else. It is usually accessed from the back of the unit.
Nov 25, 2008 | Frigidaire FGQ332ES Gas Dryer
Dryers Logo
57 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
