Question about Kodak EasyShare C613 Digital Camera
What do you mean with obstructed lens,remove lens cap.
    Brigadier General:
  • 3,006 Answers
Sorry, but your question is confusing. This appears to be your first FixYa question and nobody has answered it yet nor asked for a clarification, but your question appears to be querying an answer which you have already had.
I'm going to assume that you've simply made an error and want to know how to solve a problem with an obstructed lens on a digital compact camera (the heading suggests a Kodak EasyShare C613). Sorry if the assumption is incorrect, but if you have a stuck lens then you presumably want a fast answer.
Obstructed/stuck lenses are such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Kodak service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
If you really did mean to ask something else, then instead of rating my answer please add a comment to clarify what you want to know and I shall try to offer you further assistance.
Posted on Sep 30, 2010
My cannon finepix S4200 camera wont zoom in or out I also get message "turn of camera and remove lens cap or obstruction from lens" but no lens cap fitted and there doesnt appear to be any obstruction...
The sensor or logic board in the camera must be fooled, or one of them is defect.
When removing and reinserting the battery does not change this, contact a Canon certified repair centre and ask what it will cost to repair this error. Then decide if you want to spend that money for repair or as a start for a new camera.
Mar 29, 2015 | Cannon Cameras
What does remove obstruction mean
Is mirror in locked up position? In manual mode? Especially if the lens is irised down to a high f-stop.
Aug 24, 2014 | Fuji FinePix Cameras
What is the Meaning of turn the camera off remove the lens cap and turn the camera on'
Really it means what it says.
Switch of the camera, and switching it on again, will reset the program, like a cold boot from a computer. Perhaps the camera could not move the lens barrel and as a precaution it gave this warning. When you removed the lens cap, please check there is no mechanical obstruction on the lens. Then switch on again. When the error keeps coming back you should ask advice to a Nikon certified crevice centre close to you.
Jul 26, 2014 | Nikon COOLPIX Cameras
Will not work
Try to find out if there is something else obstructing the free movement of the lens barrel. And then try to find out if your battery (yes) are still ok. If they can't give enough power, the motor to drive the lens, can't work and the camera also "thinks" the lens got stuck.
Sometimes, a gear that is involved with moving the lens became broke. If that happens, only a repair shop can help.
Nov 24, 2013 | Kodak EasyShare C142 Digital Camera
My camera says lens obstructed. What does that mean?
Hello, That means the CCD assembly is not transmitting a full image to the cameras internal circuits, needs to be diagnosed and serviced / repaired.
Best Regards, Russell
Dec 25, 2012 | Kodak EasyShare M532 Digital Camera
Lens obstructed. remove lens cap
This is a fault of the camera Not your fault. The camera will require service / repair to correct this. Again, this is no fault of yours.
Nov 26, 2012 | Kodak EasyShare C142 Digital Camera
How do I re-set a 10.1megopixel c1033
Chances are something is blocking the lens. It could be a lens cap, or your finger, or even a grain of dust or sand.
Here's the best first course of action:
1. Turn off the camera
2. Blow sharply into the areas around the lens/lens cap.
3. Turn it on again and see if that resolves the problem. Be sure nothing is physically obstructing the lens. (No lens cap, no finger, etc.)
4. If blowing doesn't work, try using a can of compressed air like you would buy at an office supply store, and blow out the area around the lens and lens housing. Chances are, if nothing was obstructing the lens that you could see, it might be a bit of dust or sand. Even a little sand can totally screw up the lens and keep it from moving in or out.
5. If this doesn't work, you should take your camera to a camera shop and have it professionally inspected and cleaned. Check out how much this will cost, though, before you do -- it might not make sense to pay what they want to charge, versus just buying a new camera.
May 05, 2012 | GE C1033 Digital Camera
Lens obstructed- rem lens cap error kodak z990
"Lens obstructed, remove lens cap." This is the message the camera states. My camera does the same thing. It is refurbished. The camera was only used a couple of times and the problem started just as the 90 day warranty ran out. I suspect this is a common problem and these cameras should have been thrown away instead of selling them. It seems that it is not a " stuck lens problem".It seems to be an electronic problem rather then a mechanical one. Has anyone fixed this issue? Has anyone contacted Kodak for a price?
Mar 10, 2012 | Cameras
Kodak digital camera z990 lens obstructed remove lens cap
It seems that many people think that sending a camera back to the manufacturer is helpful. Most of us want help to fix it ourselves. If it is under warranty most know enough to send it back. If it is out of warranty the repair cost for most problems is more then it cost to replace it.
Feb 15, 2012 | Kodak Cameras
Getting lens cap on message push button nothing happens
lens cap means a cap in your camera lens, you have to remove it manually with your hand and not just a push buttons.
May 10, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
Kodak EasyShare C613 Digital Camera Logo
867 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
