Question about Video Game Consoles & Games
When i put the ps3 on . it shows a red light and when i click it a green light appears and then a yellow light without showing anything on the screen and then it turns to red light and keeps flashing . how do i work out this problem.
  • 358 Answers
Hi, people assume because it is blinking red that it is the "YLOD", better known as a hardware failure.
"When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked."
"If this happens:
• Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
• If the PS3 system is in an enclosed area like a bookshelf or entertainment center, move it to a more open area.
• Leave the PS3 system off for 30 minutes to let it cool down.
• If you continue to have issues, you will have to send the system in for service."
You can try an reset.
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with
your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call Sony for further assistance.
Take care.
Posted on Sep 30, 2010
  • 4,102 Answers
Hi, its not good news im afraid the reason it shuts down and gives you a ref light is due to damage being done to the circuit board inside the ps3.
it could be that it has over heated which is often the case this could be down to dust build up or if the heat sink paste on the gpu and cpu chip has gone brittle or if you have been using the ps3 on carpet or in top of anything else that gives off heat such as dvd or sky box, these cause it to over heat really quick.
right now you have a couple of options if you have any warranty left take it back and get a refund if your warranty has run out then you could try getting it repaired but their is no guarantee the repair will work or how long it will work after the reapir.
as you have got the red light this does mean the console has over heated and their is a fault with the board so its not going to work again the way it is.
now i repair these for 25 quid plus parts so you need to look around if you want it repaired and see what the best price you can get.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
p1
Ps3 wont go from red to green light to play turns offback to red
Hi dpoar,
Are you seeing any flashing red/yellow lights?
If so this is the red light error and you will find that is why the system will not turn on.
Why Does It Happen?
The GPU and the CPU are the 2 main chips in the system and they deal with all of the number crunching however they can get very hot and if they lose connection the system will either freeze up or turn off and give you the red flashing light.
How To Fix?
The key is stopping the heat build up and you can either send it in and they will fix it for you.
Bear in mind that for the PS3 red flashing light error you will be waiting for about 4 weeks and it will also cost you $150 for the repair bill!
Other Ways To Fix?
You can also use a good PS3 Repair Guide to fix it and this will show you how to stop the heat build up with a few household items.
Just make sure that you get a good guide there are some good ones out there!
Click Here For A Complete Review Of All Available PS3 Repair Guides.
Hope this helps and any questions let me know?
Mar 03, 2011 | Sony Playstation 3 (PS3) Console
When I turn on my PS3 it shows the green light first but then the light goes yellow and makes two beeping sounds. Then it goes back to red.
Your Hard Drive could be failing once it tries to read your HDD it will turn off if it is not working porperly. Try removing the hard drive and turn it on without it if you can get to the main screen without turn off then looks like it would be a bad hard drive.
Feb 26, 2011 | Sony Playstation 3 (PS3) Console
When powereing on my ps3, the power light turns green, then yellow then red and blinks
There are many reasons to cause PS3 power light show green, yellow and red then blinks. It's waste your time and money if you send to somewhere repair - because the same problems will be back after then. The best way is to learn the repair techniques of yourself. There is a PS3 DIY Repair Guide : The author use text and video to show you how to use your hands to open your console and do some maintenance and fixes, at last you are amazing that why you can do that yourself. The best part is you can help your friends too!
Jan 31, 2010 | Sony Playstation 3 (PS3) Console
WHEN I TURN IT ON THE GREEN LIGHT TURNS YELLOW THE RED
There are many reasons to cause PS3 show green, yellow and red light. It's waste your time and money if you send to somewhere repair - because the same problems will be back after then. The best way is to learn the repair techniques of yourself. There is a PS3 DIY Repair Guide : The author use text and video to show you how to use your hands to open your console and do some maintenance and fixes, at last you are amazing that why you can do that yourself. The best part is you can help your friends too!
Jan 22, 2010 | Sony Playstation 3 (PS3) Console
Ps3 slim turns off without showing any yellow light, it´s brand new and it doesn´t show any image on the tv screen, it takes like 20 seconds after turning it on for it to shut itself, and then...
FIRST IF U HAVE 2 HIT ANY EQUIPMENT THAT SONY MADE ITS NOT GUNNA WORK RIGHT PERIOD MANLY B/C SONY SUCH A BIG COMPANY (YES THEY MAKE OOPSIES) AND DONT MAKE SMALL ERRORS LIKE THAT ALL IM SAYIN IS BUY A NEW ONE IT GOT MEST UP IN BUILDING PROCESS OR U ACCDENTLY DROPPED IT OR SOMTHIN HOPE I HELPED
Jan 13, 2010 | Sony Playstation 3 (PS3) Console
It comes on but I can't get anything on the screen. if I put a game in it gives me the blue and green light but nothing happens
  • Have your ps3 in standby mode (red light).
  • Now, press and hold the power button in the front down. Your ps3 will beep twice. Let it go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
try this
When i power on ps3: light goes green to blue to red (3 beeps)?
This is the yellow light of death i got it some time ago and had to buy a new ps3 there is a way to fix it but i costs more than a new ps3 i had to buy a new one so your screw lol.
Dec 06, 2009 | Sony Playstation 3 (PS3) Console
My ps3 is showing a blank screen.
if you barly bought it then return it and get a new one because it was dropped when they ship it
Apr 03, 2009 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
115 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
