Question about Canon DR-7580
My Canon 6080 does seem to be able to pick the fact that there is paper in the tray. the tray lifts but the on screen error tells me there is no paper in the tray. Any idea what this might be?
  • 490 Answers
Clean the sensor area in the centre of the Paper tray thoroughly, use Isopropyl alcohol if required, but dont use any solvent. If the problem persists even after this you need to check the sensor.
S. Mohan
Posted on Oct 17, 2010
Canon dr-6080 getting an error a01 and won't feed paper?
As per the manual it is "In the event of a pick-up error, the document
was fed to the front registration sensors." Clean all the Sensors and try. Use isoproyl alcohol only.
S. Mohan, India
Oct 28, 2013 | Canon DR-7580
I have a canon 6080 scanner. getting a error "no
Clean the two 'black dots' in the paper tray, just under the roller. They are actually paper sensors. Try 'page counting'. If this works, the scanner is okay. If the problem still persists, try reloading the scanning software.
S. Mohan, Chennai, India
Nov 17, 2010 | Canon DR-6080 Path-Through Scanner
Scanner is not taking the pages and it is showing error message 4401
Please explain the problem more clearly.
Switch on the scanner, load some papers and try 'page count'. If it works, then there is no problem with tray lifting or paper movement. If this is not working, try 'Qumatool' and give a command to lift the paper tray. If it lifts, then the problem is with a sensor under the paper lifting tray. (It may not be in HP - Home position). If the tray is not lifting, then you may have problem with motor. S. Mohan, Chennai, India
Aug 18, 2010 | Canon DR-9080C Path-Through Scanner
Paper tray at front of scanner will not lift. Scanner has been reset multiple times and computer rebooted as well. Error msg= unknown error canon DR-6080/7880/9080C driver versioin 1.3.10502.17001 (-4523)
Disconnect the scanner from the Comp, Try 'page counting'. If the papers go through, then you know feed mechanism is okay. if the tray is not lifting, then you have a problem. Use Qumatool software and check if the tray is lifting. If the scanner tray if lifting then the motor is okay, if not, the lifting motor may need a check.If the motor is okay, but tray not lifting means the sensor in the paper tray is faulty. Check this out.
Jun 30, 2010 | Canon DR-9080C Path-Through Scanner
Dr6080 paper tray does not raise up. computer says no paper in tray
Use Qumatool and check if tray is lifting. If it is lifting, then Tray lifting motor is okay, then you need to adjust the sensor just under the Document lifting tray. If it not lifting, then you may have to change the motor. (Just now saw yr note and replying, hope it is not tooooo late!) S. Mohan
Apr 19, 2010 | Canon DR-6080 Path-Through Scanner
Have just got canon ip3600 printer and can't seem to load bottom paper try properly. Help please? Error message keeps telling me there is no paper. There seems to be no indication just how far to push the...
You may not have removed the piece of packing foam that lies in the track under the printer head. It is a long, narrow dark grey piece of foam that is wedged tightly in the track and is accessible when you lift the top cover. Unlike the pieces of orange tape it is hard to see and it is not shown in any of the setup instructions. If you don't remove it it prevents the paper in the A tray from moving and generates the "paper empty" message.
Nov 23, 2009 | Canon PIXMA iP3600 Photo Printer
False ricoh 1224c paper jam warning
check tthe clips retaining teh feed rollers havent sliped off if it isnt picking up from tray take the tray at top out and then watch from above to see if the rollers are turning to feed paper.. if the lifts out check the side door guide isnt out of plavce check the end paper guides as well//check when you take the tray out look to see there is any paper stuck at the back where the tray sensors ares can cause a lift motor error aswell
Mar 24, 2009 | Ricoh Office Equipment & Supplies
Paper not feeding
because of u r printer roller has been damaged so it cant pick up paper & also change the gear box of your printer
Nov 27, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Paper won't load from both cassettes
is the copier seeing the paper in the cassette, if yes then your pick up assy. connectors could be loose or your pick up assy s. are bad. try switching the assy first before replacing also check your connectors
Jun 19, 2008 | Canon CLC 1150 Color Copier
No page was found in scanner when one was there
Lift up the black frame around the large soft grey pick rollers on the upper part of the paperfeed until it locks into place. Power off scanner and back on and the trya will lift and the paper will feed.
Oct 22, 2007 | Canon DR-9080C Path-Through Scanner
226 people viewed this question
old marine
old marine
