Question about Ecoquest Fresh Air Air Purifier
No power, the cord was damaged tried to fix the cord but still not working
  • 1,711 Answers
You need an electronic tester to see if power arived to the machine
Posted on Oct 02, 2010
After removing six screws, how do I get case apart to repair electric cord
How do i replace the power cord on electrolux nimble - Fixya
www.fixya.com/.../t25091002-replace_power_cord_electrolux_nimble
Sep 11, 2014 - Power cord is frayed next to body, need to replace it. how do i get ....See all Electrolux EL8602A Nimble Upright Bagless Vacuum Questions.
Amazon.com: Customer Reviews: Electrolux Nimble Upright ...
www.amazon.com/...EL8602A/.../B004GUFWBM
Amazon.com, Inc.Electrolux Nimble Upright Bagless Vacuum, EL8602A ... The rotating brush on/off buttons are located right under the soft-touch power button high up at .... Cord is a $30replacement part, which I'm regretting not doing from the get-go, due to ...
Apr 13, 2015 | Electrolux EL8602A Nimble Upright Bagless...
Lasko Tower Fan stopped working but Speed switch has power on all but one cable, How to find the issue?
you should only have power on the black wire into the switch. The white wire feeds straight through. the switch breaks the black and routes it to one of the three outputs for the motor.
Aug 07, 2014 | Lasko 2510 36" Tower Fan with Remote...
Environizer doesn't work
Is it dead? does the motor run? Fan blow? No freshened smell from unit, only stale odor? You haven't given any usable info here but I'll address a dead unit condition for you: power cord stretched/damaged, on/off switch bad, fuse/cicuit breaker(if any are used).
Jun 15, 2014 | Air Purifiers
Device appears to have no power. Power cord looks good, it was working the day before then suddenly stopped working... no lights indication of any power making it to the device.
This unit will not operate if it is plugged into a power strip - it must be plugged directly into the wall outlet. An extension cord may be used.
Aug 16, 2011 | Honeywell (18155) Air Purifier
Won't power up.
Check all connections.
1) Make sure the plate is inserted inside correctly, into the groove top and bottom.
2) Make sure the back screen is inserted so that the safety switch is depressed.
3) Make sure the cord is inserted firmly, and that the wall outlet is live.
4) Make sure the little switch by the cord is pressed so the "I" symbol is in and "0" is out.
5) Try using the remote control. If that doesn't work, try the manual controls.
6) If nothing works, check the fuse. Replace it with one EXACTLY the same, available at an auto parts store.
If none of these suggestions help, you'll need to call Vollara (new name for EcoQuest) 800-989-2299. Use #16618 as the dealer referral if you are no longer in touch with the registered distributor who sold you the machine. Unfortunately, Vollara no longer manufactures or services this model, but it can qualify you for some great options.
Jan 23, 2011 | Ecoquest Breeze AT Living Air Purifier
MyFresh Air Air Purifer is not working. About 1 year ago I accidentaly put a staple through the power cord to the purifer and it stopped working. I have had it in storage but would like to start using it...
You can use any standard computer power cord for this purifier. If the damage is closer to the plug side of the cord, you could cut the plug end off and put on a new replacement plug. You should be able to find a replacement cord or plug at a hardware store. Hope this helps you.
Jan 20, 2011 | Ecoquest Fresh Air Air Purifier
One of my plates has a loose wire and it's making a noise when its on. Can I replace the plates. Also I have misplaced my cord. Thanks
You MUST replace the plate!!! Do not use any damaged plates in the machine.
You can order the plates and a new cord from the company. Vollara (new name for EcoQuest) customer service is 800-989-2299. Use #16618 if you need a referral number.
Although the company is no longer selling or servicing the Breeze, the plates and cord are standard components which are also used in other products still manufactured by the company.
Hope this helps.
Jan 14, 2011 | Ecoquest Breeze AT Living Air Purifier
Damaged power supply plug for Zip Connect i Tower
it's +24DC and -24VDC.
the connector is a 4-pin DIN but hard to locate. Older laptops used the same connector. I'm in the middle of fixing two for some local folks here as well, and I can't locate them on Mouser.com. But I do have two older laptops that I may just use the cord from and repair the SI333 iTower supply for them.
Tim
Dec 13, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Pure-Ion not working?
Didja wash the plates? It takes a little maintenance, and there are a lot of things that could make it stop working (Magnum, anti-aircraft fire, someone tripped over the cord, power quality in Karachi is lousy, there's pudding in the works...) but washing the plates with dishsoap and water, (then drying them before trying to start again) ought to fix most things that could be wrong.
Sometimes a fiber (a gift from a guest, maybe) is protruding into the works that needs to be removed, but those are the main reasons.
Jun 20, 2008 | Brookstone Pure-Ion UV Air Purifier
Ecoquest Fresh Air Air Purifier Logo
121 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Kory Ronning
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
