Question about Aqua Master Black Ceramic Diamond Watch for Women
My aqua masters watch has come appart at the strap it is in need of 4 pins for the strap which i can not seem to get from anywhere ,any ideas?
I need a new watch strap for my Nike Hammer WC0021 sports watch. I have lost the pin (43mm in length) and the metal rectangular bar from the end of the strap (hence it cannot stay on my wrist) but I...
mcdevito75 here, Best bet, look for a small watch repair shop in your area, they should have replacement pins. Approx. $5.00 maybe even less John you can also type into serach, Contact Nike Hammer Watch.com Nike has to have a web site.
Feb 09, 2011 | Nike WC0021 001 Mettle Hammer watch
Having been unworn for about 6 weeks, due to the strap having a pin come out, it was repaired at an omega outlet and now the watch is running 4 seconds fast every minute. any ideas why??!!
Let you watch run down compleatly than rest the time and put it in a watch winder or activate it the same way you have been the problem is the watch has not been used for a time
Jan 29, 2011 | Omega Seamaster 2561.80 Wrist Watch
I have a Columbia Sportswear Company analog watch. I bought in February of 2008. It recently stopped working. I checked the manual. It appears like the battery needs to be replaced. I have tried to...
I cant seem to find a good pic of this watch anywhere!
Is it one where the leather band goes behind the watch?? You will have to remove the pins (at least one) to get to the back.
Sorry.
I would take to a local jeweler if its more difficult then that.
Jewel
Sep 18, 2010 | Columbia Leather Strap Analog Straps eBook...
How do i know if the aqua master is fake
mcdevito75 here, Easiest way is to see your local jeweler, try a small watch repair shop over the larger fancy shops that will charge a lot.
Jun 15, 2010 | Aqua Master Men's Diamond Tank Chronograph...
I have been given a casio wave ceptor wvq 570 as a present. Unfortunately the plastic strap keeps detaching itself, by pulling the strap pin out. The strap seems undamaged but has a lot of play round the...
If the pin keeps coming out, then it seems likely that it is bent.
This can happen if the watch is fastened very tightly and your hand bends back until it strains the pin.
I suggest that you go to a jeweler and have a new one fitted.
Jan 12, 2010 | Casio Wave Ceptor Watch WVA105
How to change the battery on a Nixon Scout Watch?
Strap is attached to case by spring pins. Both ends of spring pin are inserted into holes into the case lugs,
. Take the knife and push the spring pin end inwards to release the watch strap.
Do not forget to rate, please.
Feb 10, 2009 | Nixon Scout NIX0013 Wrist Watch
Adjusting the strap
Most clasps have a series of small holes drilled in them, and the end of the strap is held in by a small, spring-loaded bar whose ends are seated in one set of holes. Take the end of a small paperclip, or a large needle, and use it to depress the spring-loaded pin. You can then carefully slide it to another set of holes to make the band smaller. Don't let the ends of the pin slide all the way out of the clasp, or it might shoot off into space.
Jan 22, 2008 | Versace 27473-008-00 Wrist Watch
Second hand at 6:00 instead of 12:00
you simply pull out the crown then push the button at 2 o'clock as many times as needed to return the hand to 12.
Jun 16, 2007 | Aqua Master Men's Diamond Encrusted Watch
Aqua Master Black Ceramic Diamond Watch for Women Logo
123 people viewed this question
Top Aqua Master Watches Experts
Ansel Alberto
Ansel Alberto
Are you an Aqua Master Watch Expert? Answer questions, earn points and help others
