Question about Refrigerators
Purchased GE PFS22SISBSS french door bottom freezer four years ago. One year ago replaced mother board. Last week, replaced mother board again. Solved the clicking problem, improved cooling, but it still isn't cooling properly either in freezer or refrigerator. Everyday it works for a few hours, then freezer completely thaws and refridgerator warms to 50+ degrees F. No frost in freezer. Tech says he thinks I need a new compressor for > $600. Is it possible that it could be something less costly, such as the thermistor? I've already spent $400; I will not replace the compressor but will buy another refridgerator and it WILL NOT be a GE. Sorry, GE, but it's over between you and me!
  • Refrigerators Master
  • 19,396 Answers
Re: then freezer completely thaws and refridgerator warms to 50+ degrees. If the unit is cooling, then the compressor is starting and working.
More than a compressor it can be a problem with defrost system or with temperature control.
The following parts may be responsible, testing of thermostats precision at different temperature is quite difficult.
Defrost:
thermostat-bi-metal - freezer defrost thermostat, part 620 in diag.
Tested reading Ohms, if open replace, tested checking it it does open at limit temp, if it is shorted, replace it.
Check also condenser and defrost fan fan and defrost heater. Fan tested energizing it and heater reading Ohms, if open replace. Check the thermodisks, those are high limits, they may also be shorted if they do not cut off.
Temperature sensing:
sensor (temperature sensor) - part 241 in diagram.
(determines fridge temp- test is done starting fridge with sensor open and shorted)
Check also the compressor overload (overload/relay).
I dont think this is faulty, this is simply cutting off because of overload caused by temp control.
If all the above is OK, then there is a problem with electronic temperature control, the compressor motor is pumping.
Ensure that main pcb is grounded properly.
Here diagram
Here part list.
Posted on Sep 30, 2010
3 year old side by side hotpoint. 3 months ago freezer frosted up & would not cool. Repair person replaced heater & mother board worked until about 1 month ago. Frosted up again. Repair person...
This is the part that is bad....it is cutting off the defrost too soon...
http://www.partselect.com/PS1017716-GE-WR50X10068-Defrost-Thermostat.htm?SourceCode=5&ModelNum=hss25gft
or Click here
heatman101
Aug 02, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
I have a PFSS5PJXCSS French door with bottom freezer GE Profile refrigerator. Was making an awful noise and both fridge and freezer were warm. I opened back panel of freezer to find ice everywhere,...
Had similar problem, freezer was working fine, but fridge was warm, (68 degrees) It wasnt my damper, the mother board was fried, and so was the inverter board that told the compressor what to do, after having the inverter and two mother boards replaced.......I threw it out, biggest piece of ****, only three years old, and Sears would not stand behind it, even though I used their repairmen. I will never buy another GE product, or enter a Sears store again
Jun 03, 2011 | GE Profile PDS20SFS Bottom Freezer...
GE French door profile freezer is not freezing
Call the service company back and make them fix the problem, period. If they said that would fix it then they just bought the repair no matter how much it costs.
Jul 03, 2017 | GE Profile Bottom-Freezer Refrigerator...
Loud buzzing/rumble when running
Try this website "appliance partspros.com" You enter your model numer and the have compete breakdowns with pistures and how too instructions. the best part is if you join the websites blog......there you ask questions and an expert appliance reapir person sends you a reply. I have used the website for a few years and have never been steered wrong.
Jul 22, 2009 | GE Profile PFSF6PK Bottom Freezer French...
Worst refrigerator I ever owned--a lemon
I won't say I can solve your problem short of coming around and loading your POS fridge in to the back of my truck and running by the scrap metal yard. Keep contacting GE and the retailer who sold it to you about your problems. Hopefully one or the other will get sick of hearing from you and give you a replacement. A 20 cubic foot over/under fridge with ice-maker can be had for $450 US, which should last you around 10 years or so, which is pretty much typical for white goods. I have had pretty good luck with Frigidaire and Hotpoint so far. I still wish I hadn't put the 40 year old Wizard Imperial 14 cubic foot bottom mounted freezer that I bought about 23 years ago out at the curb. Given the chance, it would probably still be working today, as ugly and inefficient as it was.
Jun 17, 2009 | GE PFS22SBSSS Stainless Steel French Door...
Tried to replace the filter and after that the upp
I don't think replacing the filter had anything to do with your problem.  If the ice maker is working then the freezer is OK since they have the same cooling source.  I had the same problem with this model refrigerator six months after I got it (in 2/2007).  The cooling in the refrigerator section failed.  The refrigerator fan and the air duct as well as the mother board were replaced.  A year later the ice-maker fan froze up. It and the housing were replaced with improved models.  The mother board was also replaced again due to software changes related to the ice maker.  This model is also part of an Energy Star/LG case agreement to modify the circuits and provide a lifetime annual rebate payment.  Check it out and register on the LG web site.
May 19, 2009 | LG LFX25960ST Stainless Steel French Door...
I have a GE Profile,model PFS22SISBSS,3 years
Possible main pcb failure failure which would cause everything to cut out and restart . Is the compressor or back of the appliance hot ?? Do all the control lights go out when the compressor cuts out ??
Feb 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not working again!
here is link my trouble description:
http://forum.appliancepartspros.com/refrigerator-freezer-repair/2538-clicking-noises-back-ge-refrigerator-2.html
Mar 08, 2008 | Refrigerators
Refrigerators Logo
416 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
