Question about Samsung Televison & Video
My 25" plano sansung tv suddenly got failed.I called a mechanic and checked .He informed me that horizontal transister got failed.Please guied me to repair.I am living at kalpakkam,60 km away from chennai.
  • Samsung Master
  • 17,130 Answers
The question is not complete but I think the horizontal transistor is failed and so the LOT can also be faulty. If so you will need to change both so that the set powers up to work .
Please respond if the question was otherwise.
Posted on Sep 30, 2010
C804 transister burn and i cant see the parts number so i am asking you if you could help me
To which section of circuit this transistor fitted. Horizontal output section? Power regulator section?
May 28, 2012 | Daewoo DTQ-26S1FC 25" TV
My china tv horezantal transister heatup
Hello
If horizontal output transistor heats up rapidly within seconds after the TV is switched on, surely there is some fault in the horizontal output section. It may be either with deflection yoke or horizontal output transformer. Deflection yoke fault is very rare, about 1% or so. but the horizontal output transformer fault is common. The winding in the horizontal output trnsformer, otherwise called as line output trnasformer [LOT] also. can be shorted inside it, and is irrepairable. It should be replaced with same type and number. Number and type is mor important, and should be insist on. Replace the horizontal output transformer. OK.
Feb 12, 2011 | Sanyo Televison & Video
I turned on my samsung 25' tv this morning it showed well and then the tv went blank no sound or picture. when i listen keenly to the tv i hear a slight hummimg sound. what could be wrong with the TV
it could be a bulb went out. I advise to call a tech to take a look at it. If its a CRT TV you can replace the bulb, however now a days its not that easy anymore and cost alot more. I hope this will get you on the correct path, wish you the best!
Sep 03, 2009 | Samsung TXE2546 25" TV
Samsung TXE2546 will not power up
 i think  there  should be  gone a output transister at  horizontal  stage.   if that tv is   21" or less  use  BU508F,D2499,1803DHI, OR = .......   if that tv is 25"  then use   D2508DF OR =.
if that proble is not above  then check the power suplly once  and check EHT(LOT) finally   .
Oct 26, 2008 | Samsung TXE2546 25" TV
TV screen turns green
i think your color combination chip is not working. you may have to change the chip of color system.
Jun 11, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Weird TV
the audio is perfect, but the screen vertically squeezes to about a quarter of an inch and stays horizontally regular. it is due to vertical section of your tv has failed. it is a common problem if you are not a tech person call tech to fix it. solution 1 check vertical section supply. 2 check components in vrtical output stage. 3 check vertical output ic. 4 loose contact in vertical section it is not a major ptoblem. good luck.
Oct 06, 2007 | Panasonic CT25G7 25" TV
No Picture
Rarely picture tube also shows the same symptom. High pitch sound is due to through deflection area LOT power supply is loaded. Compulsary horizontal output transister short. From your statement i think Lot puncture takes place. Change LOT and horizontal output transister and check tv is now working.
Aug 23, 2007 | Zenith A32B86R 32" TV
Televison & Video Logo
104 people viewed this question
Jerry Greenberg
Jerry Greenberg
