Question about Canon Office Equipment & Supplies
I have lotte canon model LC-2300... now its printout is dark from left of page... i clean all the mirrors. reflectors, chroma wires.... but doesnt work... plz help me
2 Suggested Answers
  • 62 Answers
SOURCE: Canon NP 6030 dark copies
Have you cleaned the slit-glass located behind the drum? Its a thin piece of glass that is about the length of a drum assembly. Check that the drum voltages on the drum label have been correctly installed. Perform a AVPC in service mode to set the primary charge value.
Posted on Oct 24, 2007
In my ir3300 xerox in very light if any setting is there make to dark print?.... what is the setting can u help me ?plz
Check your drum. if drum is ok clean the laser unit and clean the drum unit and chraging roller.
And clean the laser scanner lamp and the Mirror.
You must alert while cleaning the mirrors(Reflectors) don't use thinner, alcohol and stain removers for cleaning scanner lamp and mirror don't do that to movements the reflectors just open the copy board glass and clean with a cotton.
Jun 26, 2016 | Canon Ir 3300 Black & White Copier
WHEN PRINTING ID CARDS THE PICTURE IS BLURRE BUT WHEN COPYING ORDINARY ORIGINAL IT IS GOOD.
Clean the Feeder glass with cleaner problem will be solved.
  1. For clear image decrease the Density.
  2. Clean the Laser Scanner and Reflectors(Mirrors).
Don't Do That
Do not use hard stain removers and alcohol while cleaning laser Scanner Lamp and Reflectors.
Also clean with a cotton.
Jun 13, 2016 | Canon Ir 3300 Black & White Copier
My canon np 6030 copier is printing faint copies what could be the problemmy canon np 6030 copier is printing faint copies what could be the problem
clean the optical system i.e.first mirror,second mirror,reflector,lens etc to get dark copies.
checklife of photoconductor drum if it is over replace the drum.
Jul 26, 2011 | Canon Office Equipment & Supplies
When i look thru any of the lenses all i see is black. i can look into telescope without any lense and i see light. but as soon as i put the lense in it is blakc and it doesnt mater what size or...
We receive more complaints on this scope than any other brand. You never said which model you own? Is it a refractor or a reflector style???
Read this page and look at the pictures. Notice a refractor has a lens in the front and the eyepiece in the back.
The reflector has MIRRORS and the focuser end is on the UP end of the telescope-- the mirror is the BOTTOM of the telescope.
http://texasastro.org/telescope.php
Nov 12, 2010 | Edu-Science (10166) Telescope
Copying very dark lines down page.
hi just clean complet scanner mirrors and charge and transfer crona wires if solved ok if not solve just replace the drumcleaning blade.
thanks
May 14, 2010 | Toshiba 1370 Black and White Copier
Installing my deh 2300
Heres all the radio wiring colors for your car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 02, 2009 | Pioneer DEH-2300 CD Player
COPIES COME OUT DARK
Have you cleaned the optics, if there is a build up uf dust and grime on the glass and mirrors, the machice will get progressivly darker.
Remove the glass and lens cover, and gently clean the mirrors and scanner reflector, then clean both sides of the glass.
Hope this is of some help.
Ed
May 08, 2009 | Savin Office Equipment & Supplies
Cannon PC1061 making dark copies
OR you can do it yourself.
your problems seems to be Dirty Mirrors.
Your copiear has 6 mirrors that need to be clean up. 5 of them are kinda easy access. the other needs to be clean thru something thiner than your fingers. (you can see the mirror but no way you can reach it).
Now dont worry (not yet) about that 6th mirror since THEORICALLY it doesnt get dirty.
So try first to clean up the other mirrors. and see what happens.
They are located below the platen glass (remove it) and be careful with the lenses (do not touch them). clean everything that seems to reflect light Or images.
If nothing changes you may want to try out with a new cartdrige. Your drum may be done.
Oct 19, 2008 | Canon PC1061 Copier
Dark Printouts
try adjusting to light is there any change? what about photo mode?
try this site for the drum
http://www.precisionroller.com/
Nov 29, 2007 | Canon ImageRUNNER 330s Copier
Canon 330s Copier with Dark printouts
How dark is it??
canon is sensitive to dust,
turn off machicne take off top copy glass move scanning glass and wipe with a clean towel.
try adjusting the dark and light does it change? if it comes out better on light then the drum is the problem. ( getting old)
Nov 29, 2007 | Canon imageRUNNER 400S Copier
102 people viewed this question
old marine
old marine
