Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a craftsman lawn tractor 19.5 model 917270821 rear wheels won't unlock.
  • 49 Answers
SOURCE: mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Posted on Feb 05, 2009
  • 246 Answers
SOURCE: owners manual for a craftsman model 917255812 lawn tractor
Hello:
>>You can Use the Site Addys at this Site Addy; http://www.yetmans.mb.ca/antiques.html to Search and Locate New/Used Parts or for Manuals for this Unit.
Respectfully
John
Posted on Apr 21, 2009
  • 376 Answers
SOURCE: how to remove rear wheel of lawn tractor
You should be able to remove the bolt from the center with a 1/2" socket an slide it off the axle. You do not want to do any heavy hammering on the wheel because you could possibly drive the axle out of the transmission. MTD mowers are notorious for being hard to get the rear wheels off. If you do get them off or ever buy a new one, remove the rear wheels and coat the axles with anti-seize compound. Good luck
Posted on May 15, 2009
  • 4 Answers
SOURCE: my steering wheel is really sloppy on my craftsman lawn mower
My pants are real saggy! Really saggy!!
Posted on Aug 19, 2010
SOURCE: Poulan Lawn Tractor 42" 14.5 hp Model 733-864 How ...
I need the diagram for a drive belt for a 42'' lawn tractor - 14.5 hp Can ANY ONE help me?
Posted on Jul 14, 2011
Wheels are locked cannot move in neutral
If, t's a Craftsman You might can go to rear of your Mower and Release the Freewheel Control Level.
Nov 11, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman lt 1000 riding lawn mower and it runs, but it won't go into gear it goes into gear, but clutch won' engage the gear.
Look under the mower to see if the drive belt has come off or broke. It is the belt that runs from the bottom of the engine to the rear axle.
Oct 01, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I put the rear end of my craftsman lawn tractor on a cinderblock to take the rear wheel off and fix it. It was on the block for a couple of day. Now my tractor won't go forward or backward. the belt...
Did you forget to reinsert the key or did it slide out while putting the wheel on. A quick way to check is if you remove the center cap and have someone put it in gear and try to go while you are watching the axle. If the axle is turning and the wheel is not then the key is missing.
Sep 12, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I can not get my wheels to unlock on my riding mower LXT 1000 Model # 917 272461
which wheels are you wanting to unlock if it is a hydrostatic rear end that you wanta unlock to push manually then in the back of the mower there is a rod that you pull out or push up & over to release the axle
Jun 27, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Problem for Craftsman 20 hp 42 in. Deck Lawn Tractor - ca model wheel alignment: both wheels point outwards
the bar connecting the wheels is bent. this is easy to change. just pull the pins out on both sides and lift the rod out. you can straighten it in a vise or order a new one through sears. cost about $12. our local repair shop keeps them on hand.
May 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Getting Rear Wheel Off A Sraes Craftsman Riding
pull off plastic axle cover in the center of the wheel, remove large e-clip seen on the end with small screwdriver and large washer. take care not to let it fly off somewhere. lift tractor with a jack, pull off wheel then note the location of the square shear pin and save it for reverse assembly
Apr 16, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Rear wheel drive on mower does not engage
Its possible that the cable slipped does the pulley turn on top of trans.if so does the shaft turn if so then your gears on wheels need cleaned or replaced.
May 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Removing tire from SEARS CRAFTSMAN LT1000 TRACTOR.
You need to remove the black rubber cap from the center of the wheel. Remove the "C" clip from the axle and the wheel should come off. The rear tires will have a square key in it. Do not loose the key.
Jan 26, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman lawn mower
Hi judycdenn
You can get replacement wheels from most decent hardware stores, either with ball race bearings, or just plain old plastic bushes. they don't cost much, I would take in my old wheel to get one that fits.
But before you go buying spares for the mower... you should read this
regards
robotek
Apr 28, 2008 | Black & Decker 19" Electric Lawnhog...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
98 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
