Question about HP Compaq ProLiant ML350 G3 Server
Internal health LED flashing / System critical. To identify the component in a critical state, refer to system board LEDs. Red LED at video / monitor port. Please assist.
  • 4 Answers
SOURCE: HP PAVILION 760n
tell me if there is something i need to know like: what were the things that you've doing with your computer before the problem happened?? are there any recent hardware/software changes?? tell also your OS- is it XP or Vista...
first, let's try to check if the problem is with the monitor or not,okey? try unplugging the monitor blue connector at the back of the tower.and make sure that your monitor is turned-on.If you can see a colored bars displayed.you monitor is okey.if not, try a known good monitor...if it woks the problem is with the old monitor.(resolved)
2 (if not)
Now, complelely turn off your computer and try reseating all the cables, and your hardware components such as memory,video card,IDE cable and so on. but before doing so, unplug the power cable and then push the power button to drain the power.after reseating everything, plug back the power cable and turn on computer.try listening to the tower,tell me if you can hear some beeps also.
if no video issue is still there, try putting a known good video card if you have any.if a known good video card works then the problem is with the old one..
if the problem is still there after everything that you've done try calling the manufacturer. this is lead to a motherboard problem but try to call them first.
Posted on Jan 17, 2008
Mikenet2620
  • 106 Answers
SOURCE: ProLiant DL160 G6 Server, Part
ProLiant ML150 G6 and DL160 G6 (HP Smart Array B110i SATA RAID) does not support more than 4GB memory, (2GBX2 modules) or more added, it works fine with single 2GB module. Boot OS with single module and upgrade system Rompack to the latest version then upgrade B110i controller driver to 6.8.0.32. Shut down the server, add additional modules. It will work fine.
Posted on Aug 16, 2010
Mikenet2620
  • 106 Answers
SOURCE: Why Internel Health LED Shown
the internal health simple tells that there is a degraded component
so in order to tell what is the component damaged you need to check the logs
or run a insight diagnostic report that is found at>
start/all programs/hp system tools/insight diagnostics
this report will tell you which is the components with problems
Posted on Nov 19, 2010
SOURCE: My HP Proliant ML370 G 5 as an internal health LED
check your smps and the raid status if you have created any raid in the server....
-Ashok
Posted on Jan 11, 2011
SOURCE: Internal health led red display
Check with another PPM module.
clear NVRAM.
Posted on Nov 29, 2011
ML350 G3 S/board CPU Error Amber LeD + Internal Health Error
You will continue to get internal error until you add memory. It shouldn't even boot without RAM.
Feb 04, 2013 | HP ProLiant ML370 G4 Server
Tip
Monitor led is blinking or steady, but the display does not come up
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
on Apr 22, 2009 | Dell E173FP 17" LCD Monitor
On one of our HP DL360 G5 systems every time after soft reboot the server cannot be booted back. This is 100% reproducible also with Cold boot. Can someone help us find what internal component is...
The simplest way is to check Insight Manager. Type localhost:2301 on a web browser locally. Or, servername:2301 for remote access. You need local Administrator password.
Insight is only available if it was set up with a Smart Start disk. It's that pack that comes with all HP servers, but can be downloaded as well. Best practice is always install.
Don' know what IML is, and ILO has no baring to problems.
There is Insight Manager link on specs.
http://h18004.www1.hp.com/products/quickspecs/12476_na/12476_na.html
Nov 12, 2012 | HP ProLiant DL360 G5 Server
Compaq Proliant ml370 g2 does not boot, beeping every 30 seconds, no video output. Internal Health LED is RED, Harddisk Health LEDs all green Component Health LEDs all green (RAM Banks are...
hdd fault caused by surge video card failure ram failure hdd failure depends what the beep codes are they are coded the length and duration tells you what the fault is ie three short beeps or two long ones try bleeping computer.com or check out bleep codes
http://h30499.www3.hp.com/t5/ProLiant-Servers-ML-DL-SL/Proliant-ML370-G2-server-strange-beeping/td-p/3221528#.VJgYMsgDQ
Apr 28, 2011 | HP Compaq ProLiant ML370 G2 Server
Led light is flashing red and yellow and tv wont come on
If there is a flashing led on front of the TV, that indicates a fault condition.
1The internal circuits are jammed because of electrostatic chargesaccumulating on capacitors, or because of a wrong voltage read by themain chip on your monitor controller board. this started the protectioncircuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
Commonfaults that can occurr suddenly are a blown capacitor on power board, a convergence IC has blown, or a faulty on Digital board.
check also the video cable, if the cableis shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Check also connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact SonySony Global - "Contact Us".
Regards
Mar 07, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
My sceptre monitor S1902D won't turn on just stopped
If the monitor has no power at all then you have a dead power board, or a broken power cord, test also a different wall AC outlet.
If instead there is a flashing led on front of the monitor, that indicates a fault condition.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
Regards
Mar 06, 2009 | Sceptre S1902D 19" LCD Monitor
Monitor dead
Regards
Mar 06, 2009 | Philips Computers & Internet
What do the front panel leds on the ml370 g3 represent?
External health (power supply) LED
Green Normal (system on)
Amber Redundant power supply failed
Red Critical power supply failure
Off Off = Normal (system off)
~gnomer
Jan 28, 2009 | Compaq ProLiant ML370 G3 (340262-001)
Monitor light blinking
  • Video cable.
  • Motherboard.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Jan 17, 2009 | LG Flatron 775FT 17" CRT Monitor
Internal led of ML350 server is glowing.......how do i resolve it?
Hi Franceso, plz specify
Is it powering ON ?
Which LED is glowing?
These leds are there on the front panel :
1 Power On/Standby button
2 System power LED
Green = Power on
Amber = System shut down, but power still applied
Off = No power
3 Internal health LED (Wave sign in BOX)
Green = Normal
Amber = System degraded. To identify the component in a degraded state, refer to system board LEDs.
Red = System critical. To identify the component in a critical state, refer to system board LEDs.
Off = Normal (when in standby mode)
4 External health LED (power supply)
Green = Normal
Amber = Power redundancy failure
Red = Critical power supply failure
5 NIC 1 activity LED Green = Network link
Flashing = Network link and activity
Off = No link to network.
6 UID LED Blue = Activated
Flashing = System remotely managed
Off = Deactivated
7 UID button
If it is Internal health led then any internal h/w issue is suspected.
If it is external health led then any power supply or power source related issue is suspected.
Also check the status of the server & its IML (Integrated Management Logs) in ilo (Integrated Lights Out ) if it is configured. (2nd RJ45 port in rear)
Also make sure the cabinet is properly closed.
Nov 18, 2008 | HP Compaq ProLiant ML350 G3 Server
HP Compaq ProLiant ML350 G3 Server Logo
1,296 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
