Question about Samsung Televison & Video
No sound just out of warranty - Samsung Televison & Video
My microwave just made a loud sound. It still runs but doesn't heat up. Is it likely a fuse & if so what do I do?
fuses make very little sound when they blow so a loud sound in a microwave is an expensive sound
best take it in for a proper diagnosis and quote as many loud sound repairs cost more to fix than a new unit
Dec 05, 2016 | Microwave Ovens
Where do I SEND my IQ sound 8012 for repair when it is still under mfg warranty?
Visit the manufacturer websit. Register your product then claim your warranty.
May 14, 2016 | IQ Sound Audio Players & Recorders
Faulty drive
The clicking sound is often refered to as "the click of death". In most of the cases the sound indicates that the drive is getting to the end of its life.
I recommend getting another drive and back up all your essential information as soon as possible. Then, if you still have warranty on the drive, exchange it. Even if store warranty has run out, the manufacturer might still give warranty depending on the age. Even if the manufacturer's warranty has expired, your local Consumer Protection Act might back you up to get it exchanged any way.
Dec 13, 2013 | Freecom Mobile Drive Mg 1TB USB 3.0
There is no sound coming out of speakers for radio, navigation, etc. Screen is fine, no sound....2011 Journey LUX AWD.
Sounds like a common issue that has been happening on the2011 Dodge Journey's. It is covered under warranty and is advised you do not try to fic it yourself. You may void the warranty trying to fix it yourself.
Jun 10, 2011 | 2011 Dodge Journey
My seagate barracuda 7200.11 640gb iomega external hdd has malfunctioned (or so a bubble tells me when i connect it to my pc! it has not been moved or droppped or suffered heat damage. The power light...
If the hard drive has failed, which it sounds to be the case and it does happen even to new hard drives, and is still under warranty with Seagate, go to the following page to start a warranty claim for the drive.
You can also check to make sure your hard drive is still under warranty there as well.
Dec 14, 2009 | Iomega Computers & Internet
I'vs had my HP Pavilion Dv9000 laptop about 2 months now, and it has been great. recently however sounds have only been coming from the right sound channel. The left side just makes a starng buzzing noise...
There is a problem is the sound card. The HP laptop should be still under warranty, take it to the supplier to get it repaired under warranty. If you try to fix it yourself you most likely will void your warranty.
Oct 24, 2009 | HP Pavilion dv9000z Notebook
Picture but no sound
main pcb needs to be cleaned were audio ic is. there is black gunk
Jun 01, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
We have sound, but no picture
We had the same problem on our Samsung LNS4692. Call manufactures 800# there is a replacement part and they will send out the repair person. if under warranty no charge. No warranty can cost $600+. God Luck. Don't let them try to get out of fixing it.
May 08, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Sharp Aquos Sound problem
This unit should be under warranty. DO NOT open it up as that would void the warranty. I would try and see if there is a pattern to when the sound fades. This will be helpful to the service center. At the very least, log a service call stating that the problem is intermittant. Then if the problem goes away on its own, but re-appears after the warranty is over, you should still receive warranty coverage.
Dan
May 29, 2008 | Sharp AQUOS LC-32GP1U 32 in. LCD HDTV
Televison & Video Logo
42 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
