Question about Whirlpool Duet GHW9150P Front Load Washer
Wshers on "control locked" can't get it off of this to work
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To unlock the controls you?ll need to press and hold the END OF CYCLE button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 30, 2010
Why won't it start?
The lid switch needs to be replaced.
Jul 16, 2015 | Kenmore Washing Machines
WSHER WILL NOT START CYCLE
The motor coupler may be worn out. It connects the motor to the transmission.
Aug 20, 2014 | Kenmore 20022 3.4 cu. ft. Top-Load Washer
Wsher gt water in bottom wont drain or wasing saying sensing
Hi Kimberly, I am happy to assist you. Often when a unit does not drain properly, it is because it cannot dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Aug 06, 2013 | Frigidaire Washing Machines
Maytag Neptune FAV6800AW Top Load Washer, service manual
I have the letters "LF" on display, wsher does not work.. What does "LF" mean?
Thank you
Aug 09, 2012 | Maytag Neptune FAV6800AW Top Load Washer
I have a gasket around the top of the tub that is leaking. I have had a repair man twice and he finally told me he can't fix it because he cant find the model number. Where can I look for it? It's...
Typically the model number is in one of 3 places
inside the lid
on the back of the control panel
on the lower left front corner of the cabinet on the left side wall of the cabinet
Aug 30, 2011 | GE WBSR3140DW Top Load Washer
Wsher always stops @ 26 minute mark w/F1 code? It takes multilpe restarts to get it to finish the load.
We recently solved this same problem. Remove the control panel via the three screws on the back, check the water inlet tube area ( blue with the water lines coming in and several electrical connections) make sure it is screwed down tightly with 2-3 screws (ours wasn't). If it's not than find a couple screws to tighten it down. Turn the system on & see if that solves the problem. When re-attching the control panel be sure not to tighten too much, just enough to hold snuggly or this will cause your F1 problem also.
Dec 26, 2010 | Whirlpool WTW6600SW Top Load
LHW0050PQ 2 fabric softener does not enter wsher.
top of the drawer may be blocked where the water enters, also check water pressure
Oct 09, 2009 | Washing Machines
Speedo not working
remove your front wheel and on the speedo drive side you should have a wsher with 2 lugs on check and make sure the lugs have not been damaged or are missing completely if they are replace.
Jun 06, 2009 | 2001 Honda NSR 125 R
Wsher stops in the rinse cycle wiht a n F4 message
f2 error means long drain or no drain
check the drain pump
replace drain pump if nessesary
Mar 17, 2009 | Kenmore Washing Machines
Kenmore 42042 front loader
Buy affresh wsher tablets from whirlpool corp. They keep the wsher from smelling and they clean the washer too. They say they are for front loaders but they work great on top loader too!!!!!!!
Nov 10, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
15 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
