Question about Sony Playstation 3 (PS3) Console
The playstation 3 started beeping while my son was playing it. Now it will only turn on for a second then it shuts itself off. What is wrong?
  • 4,102 Answers
The PS3 YLoD can be caused by a number of things. Most commonly, it's a result of a hardware failure, overheating, dust build-up inside the system, and occasionally just due to loose cables.
Let's start with the easy stuff first to narrow down the cause. Follow the steps below:
1. Assuming you were playing your PS3 when the YLoD happened, move your PS3 into an open area with a lot of ventilation and let it cool down for 20-30 minutes. Once it's cool, try to turn it back on and see if that helped. If not, go to Step 2.
2. Unplug all of your cables from the PS3 including the A/V and the power cord. Also unplug the power cable from the wall. Now try to plug them all back in and make sure they are all secure. Turn the PS3 back on and check if it's working. If not, go to step 3.
How to Fix PS3 Yellow Light on Your Own
3. Get a vacuum with a hose attachment and vacuum out the vents on the system. Sometimes dust build-up alone can cause your PS3 to stop working properly. You might also want to take one of those cans of air and blow it in there to get some of the stubborn pieces of dust out.
If none of those solutions worked, the problem lies within the PS3 and you will probably need to take it apart to fix it. The most likely scenario is that your heat-shield overheated, the chipsets got shifted due to heat, and your solder could be cracked.
the causes of the yellow light of death
Here are some of the top causes of the PS3 Yellow Light of Death:
* Overheating - The unit gets too hot. Sometimes caused by too much dust buildup in the vents.
* Blu-Ray drive failure.
* Bad power supply.
* Hard-drive critical errors.
* Hardware malfunction on the motherboard - The solder starts to crack due to excessive heating and cooling.
if you have warranty then take it back if you dont then you can either try the repair yourself how ever this is not very easy to do and can cause more harm than good you will need special tools to take it apart and its not easy you also need an understanding of heat seal paste and heat sinks due to this being the part you need to remove and put back
i do the repair for about 25pound plus parts so if you are paying someone to do it then your looking at least that price, i only charge if the problem is fixed so try and get the best price you can.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
ylod1
Posted on Sep 30, 2010
My PS3 keeps locking up during start up on franchise mode on Madden 11 against a certain user. I am able to play him on a different PS3. I am also able to play different opponents in the same franchise. It...
no no that is very slim that it is your playstion 3 console, if your game is freezing heres probably,another reason why your data has been currupted,you turned off your playstation3 the wrong way,you have to shut it off the proper way,or it will currupt your data,theres two ways to fix this issue,call play station two or three and let them guide you in how to restore your data at the very beggining,like if you were freezing up on call of duty black ops,its more then likely you have currupted data one way to find out,is to put a disk in of a movie ,and if it plays it then its not your lasor,now if the first few steps does not work,then you will go to the second step total restore like on a computer,on the playstation 3 and if you want to test my suggestion,or knowledge,try this take the game out of the playstation 3 hold down the powe button with your thumb totally on the button youll here one beep then two beeps then youll here a beep beep then you will get into the system of the playstation 3 if you need my assistance my email is sprolesr2@yahoo.com and drop me an email and i will assist when sending me an email in subject put playstion 3 help that way i know,oh ya and another issue that can cause your data to be currupted is **** this is horrible i know
Jan 25, 2011 | Sony Video Game Consoles & Games
Ps3 games will not play ps3 games it will play ps2 games and movies whats wrong with the system?
Welcome to Fixya
Try the troubleshooting procedure below:
Step 1 - Turn off the playstation 3 by holding the power button on the front of the unit till the power light is red.
Step 2 - Touch and hold the power button, you will hear the first beep, meaning the playstation 3 is powering on. Continue to hold the power button and after about 5 seconds, you will hear a second beep, indicating the video reset. Continue to hold the power button and after about 5 seconds, you will hear a third beep and the system will power off (power light is red).
Step 3 - Touch and hold the power button, you will hear the first beep, again for the playstation 3 to power on. Continue to hold the power button and after about 5 seconds, you will hear a second beep for video reset. Continue to hold the power button and after about another 5 seconds you will hear a quick double beep. At this point release the power button. if you succeeded in activating the safe mode, you will see a message on the screen saying 'connect the controller using a USB cable and then press the PS button.
Step 4 - Perform the safe mode options in the following order until one of the options works for you. If one option works, do not continue onto the other options.
Restore Default Settings
Restore File System
Rebuild Data Base
Restore PS3 System etc...
Thank you
Dec 27, 2010 | Sony Playstation 3 (PS3) Console
I was playing a game and the ps3 just randomly shut off then the red light starts flashing and every time I turn it on it shuts off right away
If the system turns on but then turns itself off, beeps at you and flashes it's lights at you then you have over heated the system. The GPU chip has probly pulled itself away from the board. This will require you to diassemble the PS3...
better u download repair guide....
click here to download repair guide
Dec 17, 2010 | Sony Playstation 3 (PS3) Console
The playstation 3 shut off in the middle of play. Now the little red light just keeps blinking. We unplugged it made sure theere was nothing blocking it to cause it to over heat, we plugged it back in and...
If the system turns on but then turns itself off, beeps at you and flashes it's lights at you then you have over heated the system. The GPU chip has probly pulled itself away from the board. This will require you to diassemble the PS3...... u just fix this by using ps3 repair guide....
Oct 11, 2010 | Sony Playstation 3 (PS3) Console
Ps3 shuts itself off in a sec and doesn't eject game.
HI, this is a power unit issue. you will need to replace the power unit block asap if possible. these can be purchase on line or, you can contact sony for this repair as well.
we recommend contacting Sony for the correct power unit for your system.
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
My playstation turns off seconds into powering up
dunno mate, probably something is wrong with it. If its under warranty, ur best bet is to replace it.
Mar 24, 2009 | Sony Playstation 3 (40 GB) Console
Playstation 3 shuts down as game loads
Generally there are a couple of things that can cause this. Bad installs of games, and more commonly thermal damage. The bad news is it will probably have to be repaired and Sony generally charges about $150 for that. Hopefully its under warranty? =)
There is some talk that the new firmware download may have altered physical parts that control the temperature inside the unit. Although that's just heresay i've been hearing more and more people thinking this is the case.
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
System Turns-Off
your system is overheating, your beter of either repairing it or getting a replacement :(
Mar 24, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
468 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
