Question about LG WFT1071TP Top Load Washer
MACHINE IS WORKING BUT SPIN FUNCTION MODE NOT WORKING
  • LG Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Sep 30, 2010
Hello, I have a Maytag legacy series washing machine and recently it stopped working properly, first it tripped the breaker, then in regular washing mode it washes normally but skips spinning and water...
Sounds like a bad relay array, or timer module. The little motor that makes the selector move (and then trip the function switches inside the timer module) could have trouble moving the selector past a certain point. When the machine stops, press your ear up against the timer module. Do you hear the little timer motor running? Yes? then it's probably the timer module itself, not the timer motor. I say this because you can manually move the selector to activate the modes.
Jan 03, 2014 | Maytag Legacy Series Top Load Washer
Whirl pool top load washing machine directly goes to aqua save mode and disable all other functions?
This is just a setting error. For troubleshooting of this error, just enter in diagnostic mode. Keep pressing Program button and then also press Water Level button. Now release both buttons. Now machine will auto run for wash-rinse-spin. After it finishes, Keep program on Normal, Keep water level low and now Start the machine. It will now work normally as before.
Nov 17, 2012 | Whirlpool Washing Machines
My 8015c works fine but wont spin. Is there any way I can get it to spin?
You need to check the output from the program controller when the function is on the spin mode.
It is possible that the program controller is not working as the motor seems to work with wash cycle.
Try and use another program and see if the spin works, is not try to see if the spon works manually choosing to start on the spin cycle. If not the program controller is faulty.
Aug 09, 2011 | Washing Machines
Maytag Neptune Washer MAH8700AWW will not spin. It will fill, drain, tumble ect but will not spin. i tried a quick spin test and it sounds like it is trying to drain after all the water drains. I went...
You may have tried this, but check the door switch, and the pressure switch(water level switch) to see if either could be bad. both of those affect whether the washer spins or not.
Jun 12, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Washer will spin while in rinse mode, but does not
this could be a main control board problem.how ever i would check the drain pump for any kind of foregin object that may be causing the drain but to stop functioning.last resort bad drain pump
Sep 17, 2009 | Frigidaire ATF6000ES Front Load Washer
End of wash cycle, no draining or spinning, but can move to rinse cycle and it agitates again, no spinning after rinse either
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The drain and spin functions are started when the timer advances to the spin mode.
The motor is reversible. When agitating, the motor spins one way, when going to the drain / spin mode it reverses.
Since the machine agitates, the problem points to the timer.
Sep 04, 2009 | Kenmore Washing Machines
Frigidaire washer machine stop in the middle of the cycle
Replace your lid switch.
The machine must have a goodd lid switch to continue timer functions after wash and rinse.
Feb 28, 2009 | Frigidaire FWS833A Top Load Washer
Washer wont spin or drain
did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
Feb 07, 2009 | Frigidaire Washing Machines
GE Profile washer won't spin cloths after wash or rinse cycle
My GE washer model number WLSR2000G3WW washes and pumps water out but will not spin...can someone help me to solve my problem PLEASE?
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
Estate by Whirlpool washing machine will not drain or go into spin mode in any cycle.
I would try and check voltage at the overload on the motor
when in spin cycle and see if you have power there..
 that should tell ya if your at least getting power from the timmer or not in the spin cycle to the motor
Sep 04, 2007 | Admiral AW22 Top Load Washer
LG WFT1071TP Top Load Washer Logo
135 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
