Question about Brother HL-2040 Laser Printer
Have mislaid my HL-2142 manual and need to install new toner cartridge . . . I'd be grateful for some help please.
  • Brother Master
  • 379 Answers
All brother manuals and software is available for free download from their website - go to www.brother.com , and select your country.
Posted on Oct 04, 2010
I have a Brother HL-2142 Compact High quality mono laser printer and I am having trouble putting the new toner cartridge back in as it flashes error and the paper gets jammed. I dont know where the...
Open the front door and pull the whole toner and drum unit out of printer. The toner locking lever is usually on the left hand side as you see it and is usually blue in colour. It needs compressing and at the same time lift the front of the toner cartridge out of the drum unit. Your new cartridge will simply lock into place. When you install the complete unit and close the door, the new toner cartridge will reset your printers counter.
May 20, 2011 | Digital Products Brother HL-2040 Laser...
The colours on our HL-4040CN have gone all strange - when we perform colour calibration the colours go either red or green. All toners are new and the drum has been replaced recently as well. We do a lot...
Hi
We need to isolated the problem on what cause ink cartridge not print in color. When even you installed new cartridges, It is necessary to run the print nozzle to clean the print head. Also, please try to clean the print head manually by removing all the ink cartridges and rub the print head into a white paper with alcohol until ink flows and then return it back and run the print nozzle for 2 times.
Then try to print again.
If it does not help you, please let me know to give you more help.
Mar 03, 2011 | Brother HL-4040CN Laser Printer
Every page I print out has a vertical stripe down the left hand side of the page.
(1) Clean the corona wire in the drum unit.
(2) Check that the wire cleaner is at the home position.
(3) Check that the toner cartridge is not empty.
(4) The drum unit may be damaged. Install a new drum unit.
(5) The toner cartridge may be damaged. Install a new toner cartridge.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 25, 2011 | Brother HL-2040 Laser Printer
HL 2140 printer need ink cartridge installation instructions
This is a laser jet printer there is no ink, it uses toner. Purchase a toner cartridge and open the lid, remove old cartridge and insert new one. The part number for the cartridge is TN360. Good luck. here is a place that sells them for $50.00 http://www.lasercartridgeplus.com/tn360-tn-360-brother-hl-2140-toner.html You might be able to find it cheaper if you look around.
Jan 17, 2011 | Brother Office Equipment & Supplies
Have HL-2142. Can't remove cartridge from printer. Guide says: Open front & pull- Won't come out!
It doesnt come out easily you will need to use some force when pulling it out.
Open the front cover and using the handel of the cartridge pull it out with a bit of force.
If you then want to remove the toner from the drum push on the tab on the bottom left to release the lock and remove the toner from the drum
Apr 17, 2010 | Brother HL 2140 Laser Printer
Hl 5240 i installed new toner cartridge still status is solid red toner is solid yellow
The new toner cartridge is not properly installed. Remove the toner cartridge and reinstall it.
Download and read the service manual
http://ekse.pp.fi/Fixya/sm/BROTHER%20HL-5240,%20HL-5240L,%20HL-5250DN,%20HL-5270DN,%20HL-5280DW%20Service%20Manual.pdf
Page 3-2 to 3-6 has the instructions on how to properly install the toner cartridge.
The page numbers are 63 TO 67 if you look at the page counter.
Oct 08, 2009 | Computers & Internet
Printer won't print error message corona wire needs cleaning
When you experience a persistent problem like this right at the beginning - listen to your own good advice. Take it back to the store and exchange it for a new one.
Jul 30, 2009 | Brother HL 2140 Laser Printer
Blank pages after installing new drum
when replacing the toner did you remove the plastic film sealing the toner? if the drums receives no toner you will get blank pages. please check
hope this helps
good luck
Oct 25, 2007 | Brother HL-2040 Laser Printer
Brother HL-1440
(blinking every 5 seconds) Toner Low Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated. (solid) Toner Empty Replace the toner cartridge with a new one. User's Manual is available at the following location: http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf Hope this helps.
Aug 22, 2007 | Brother HL 1440 Laser Printer
Brother HL-2040 Laser Printer Logo
321 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
