Question about Brother DCP-110C All-In-One InkJet Printer
Have new PC running Windows 7. Old DCP110 printer is working but print is very faint, can't read. Top bar with computer info prints normally . . . can I print a test page with old software?
    Problem Solver:
  • 10 Answers
Hi vt_mail.
As i can see Brother don't have a Win7 driver for the DCP-110C, but anyway it should run without any problems on Win7.
(se this link: http://www.brother-usa.com/lp/windows7compatibility.aspx#WinUpdate)
Maybe you should to take all toners out, and put them back again, or replaced them.
Posted on Oct 07, 2010
I am working windows 7 and my printer is old not support windows 7 and printer is hp psc 1410 all in one . softwar download successfuly but when command on print one but when again...
Disconnect the USB cable from the back of the printer. Uninstall the software of this printer. Then after uninstalling it now re-start the computer. After your computer starts completely then just connect the USB cable from your computer to your printer and windows 7 will install basic drivers for your printer, print a page and it will print the documents.
Apr 19, 2011 | HP PSC 1410v All-in-One Printer
For key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install...
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose your o/s
now run it and presto......
regards, dean
Jan 08, 2011 | Keyspan USB Server US-4A (d47710) Print...
I have window 7 64bit and the keyspan software installed fine but the server utility does not recognize the print server. I allowed port 3842 tcp and udp through the windows firewall but still no luck.
for key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install windows virtual pc, start it up and insert a windows xp pro install disk. for info on this google 'workaround to install windows xp mode in windows 7 home premium and home basic') Once you have windows xp mode running, install the keyspan server utility int he virtual machine and setup as usuall. then share the printer. go to windows 7 devices and printers and add a printer, chose a network printer, select the new virtual machine and select the shared printer. In order for the printer to work just start up the keyspan program from windows 7 and print....your welcome.
Sep 08, 2010 | Keyspan USB Server US-4A (d47710) Print...
Print quality problem with Windows 7 and HP DeskJet3650.
You need drivers for win 7 only for the two printers you have .some of the mfg, have not got all the bugs out as yet. Im in the same boat .had to get a new model so i could print. Check windows web. site for driver 7up dates.hope this helps
Feb 25, 2010 | HP DeskJet 3650 InkJet Printer
Can't address envelopes using Microsoft Word 2007 & Windows 7
Excellent question. Wish I had the answer. I have the same problem with the MFC-7440N. I hook up my old HL 1240 and it prints them fine, so I now use two printers - one for envelopes and one for normal printing. I contacted Brothers and was told that it was not the printer, but the Application. If so, then why does my old Brothers printer work? They do not have the answer.
Feb 24, 2010 | Brother MFC-7440N Laser Printer
Tried to connect to lap top, test page shows error will not print
Reload your driver ... Still have a problem ... get the latest driver from www.lexmark.com/support
Your printer is able to run using the OS on your computer, right? New laptop running 7? old printer? You may want to check the MS compatability listing at http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
Thanks for your interest in FixYa.com
Feb 23, 2010 | Lexmark Z816 InkJet Printer
Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
Jan 25, 2010 | HP Color LaserJet 2600n Printer
Network printing between Vista and Windows 7
Try plugging the printer into a different pc and see if you can see it from windows 7. Windows 7 has a more secure network setting.
Jan 05, 2010 | Computers & Internet
Running windows 7 printer wont print anything but installed ok
Is this a brand new computer or did you upgrade to Windows 7? If you did an upgrade, you needed to uninstall the old drivers (with the printer disconnected from the computer). Then you could install Windows 7 and finally install the printer.
You can try unplugging the USB cable, uninstalling the printer and then reinstalling it.
What software are you using to create the file that you want to print? With Microsoft Office, I have seen reports that changing the font on a document can cure a failure to print the document with Word.
I hope this helps.
Dec 29, 2009 | Lexmark P4350 All-In-One InkJet Printer
My new computer won't print using the ''Prt Scr'' key
Sorry, I did not mean for my post to be a clarification request.
Sep 15, 2009 | Computers & Internet
Brother DCP-110C All-In-One InkJet Printer Logo
66 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
