Question about Sega Genesis 2 Console
My sega megadrive 1 and 2 won't turn on. the plugs are new and so is the tv visual lead. I have a mega cd 1 an 2 and that does not appear to turn on. is that because of the console? if so should i get the console repaired or just buy a new one? Thanks
kozachek
  • 122 Answers
SOURCE: sega megadrive 2 never comes to black screen just snowstorm
Ensure that the switch on the back of the unit is set to channel 3 or 4, and that your TV is tuned to this channel. Additionaly, make sure that the rf switch is properly wired in to your television and that no wires have come loose or fallen out.
Posted on Mar 18, 2010
  • 14 Answers
SOURCE: I have a sega megadrive 2 in good condition. I
yup...update your system
Posted on Nov 05, 2009
SOURCE: Sega megadrive 2 that wont load
Just keep fiddling with it. I kept messing with the video cable, where it plugs into the back of the console. I got the "Licensed by Sega, etc." message for a few seconds before it went black again, turned it off, pulled out the cartridge then slammed it back in. Now all of the few carts I own are working with the console.
Posted on Dec 27, 2009
key-kun
  • 83 Answers
SOURCE: video but no sound on sega megadrive 2
Nothing wrong with the tv or the cartages or even how you hooked it up
its the wire that connects the tv to the console, these some/a waire broken on the inside.
gotta get another one, or find the brake and twist it around till they meat then put some duck tape or something around it to keep it in place
Posted on May 02, 2010
key-kun
  • 83 Answers
SOURCE: SEGA MEGADRIVE
dont know how many times ive said this but
GET AN OLDER TV
it saves all that time you use trying to hook it up to a new one..it doesnt even have to be that old just not a plasma or HD tv, its much MUCH easyer and saves lots of time, and mabie even money
Sega mega drive with av cable
if your screen is black and you unplug the cable from the megadrive , does the screen go blue ? if so the machine is sending out an a/v signal to the tv and your problem lies with the game cartridge contacts being dirty or the contacts in the slot on the console being dirty , try cleaning the contact strip with some electrical contact cleaner on a cotton bud or small paint brush , hope this helps ,its saved loads of my games
Aug 10, 2012 | Sega Megadrive Black Console
Hi I have a Sega Megadrive 1 & Mega CD 1. It has wroked for years from new but it has got a problem within the last week. When turned on the conosles comes on as normal and you see a good and...
Well, Sega's aren't known to be long lasting, but if it isn't an issue with the console itself you could try checking all of your cords, assuring they are plugged in good and tight to both your console and screen. Faulty cords can easily be overlooked. If your discs aren't working, but you're hearing the music from different ones and no picture, it sounds like an issue with one of your video jacks, so make sure everything is properly plugged in.
Failing that, bring it to a retro gaming shop to have it looked at or test it at someone else's place.
Mar 01, 2011 | Sega Mega-CD Console
Help! My Sega-Mega CD won't work. The MegaDrive works just fine (I played a game on it just 5 minutes ago) but the Mega CD won't even start. I've set it all up, referred to the manual and reset it and done...
the fuse has probably gone in it, thats a common problem with the sega cd's, you will have to replace the fuse on it, try looking up "sega cd model 2 fuse repair" in google and there should be some info/video's on the net to help you ;) I only know because I have the same problem lol
Dec 10, 2010 | Sega Mega-CD Console
Can't find the frequency for the genisis 1 sega megadrive, I have the RF converter but I've tried doing auto search and manual, just cant find it...
Hi some new TV'S may not have the frequency of these old consoles i recommend purchasing a AV cable which is can be found at http://www.gameoz.com.au/store/sega-mega-drive/mega-drive-accessories/sega-mega-drive-1-av-cable.html
No tuning in a channel and better picture Quality
Apr 24, 2010 | Sega Genesis 2 Console
SEGA MEGADRIVE
GET AN OLDER TV
Apr 13, 2010 | Sega Megadrive Black Console
Just got a Sega Mega drive, connected to my plasma
Most old systems such as Mega Drive will come with an RF adaptor, which plugs into the back of the console and has a coaxial tip on the other end, to connect to the tv.
When you connect the coaxial end to the tv, you connect it to the round coax plug which is where you used to plug in your old cable tv hookup. It also might say Ant. or Antenna.
Turn on your megadrive and use your TVs input selector to change to either "antenna" or "tv" or "cable" input, or until you hit the input which displays your megadrive's signal.
Tip: use your TV's view options to change the input to a 4:3 or "not stretched" aspect ratio so that your old Fullscreen video games will not be stretched out wide on your new widescreen HDTV.
Good Luck!
Jan 30, 2010 | Sega Megadrive Black Console
I just aquired a sega megadrive 2 with all leads but no instructions. can you tell me how to set it up please? Michael
First plug the power plug into the mega drive and turn it on (there should be a red light showing that the megadrive is on)
Plug RF lead into the back of the mega drive and TV and make sure the switch is set at the megadrive side and not the ariel side, if you have a switch.
Now turn off mega drive, put a game into the slot and and then turn the console on.
Select a channel on your TV and tune it into the mega drive.
This should work.
Mike
Jun 13, 2009 | Sega Genesis Console
How do i connect a sega mega drive 2 to a tv?
use the RF lead (plugs into the mini din at the back of the megadrive)
if you don't have the lead you might want to look at ebay for a replacement
of if you don't want the hastle of tuning your megadrive into your tv you could buy a scart lead from www.retro-cache.com
Oct 22, 2008 | Sega Video Game Consoles & Games
How do I set up a sega genesis?
here we go
This is a step by step with testing set up for the sega mega drive
first plug the power plug into the mega drive and turn it on (there should be a red LED light)
plug RF lead into the back of the TV and make sure the switch is set at the megadrive side and not the ariel side, if you have a switch. (or you can buy scarts from www.retro-cache.com)
Select a channel on your TV and re-tune it into the mega drive. (on some TV's the tuneing is around the C36 area if that is any help)
If you tune into a blank screen than turn the mega drive off, remove the game, clean it and replace the game and try again.
Oct 01, 2008 | Sega Genesis 2 Console
My genisis has no picture!
the leads probably need replacing as these often split inside are you sure the your selecting the right setting on the tv are you using the colour leads red and white or is it scart lead ...............
Nov 19, 2007 | Sega Genesis 2 Console
Sega Genesis 2 Console Logo
369 people viewed this question
Top Sega Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Reggie brown
Frank Zabroski
Frank Zabroski
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
