Question about Ovens
My AEG D98000VFM Cooker hob won't turn on. It bleeps quickly but won't actually start. Ovens work fine.
4 Suggested Answers
SOURCE: AEG Oven model D98000VF - error code F8
I am pretty sure this is the temerature probe that has failed it can also be a failure of the main control board see how you get on but resubmit question if in bother.Hope I helped.
Posted on May 07, 2010
  • 174 Answers
SOURCE: My90 duel fuel range master
the ovens work through the clock auto contacts if the clock not working then the ovens wont. may need a new clock or you can bypass the timer relay contacts if your clever. one of the oven elements may have blown to earth this is the main reason for a clock failing
Posted on Aug 04, 2010
MNfisherman
  • 11896 Answers
SOURCE: Smeg A2 cooker, 11 2years
Is this gas or electric? If it is electric, you will want to test the power to the burners with a voltmeter. This will tell you if the control is bad and not giving power to the burner, or if the burners themselves are bad or possibly just loose or corroded connections.
If you have gas, check the gas valve and the tubing. Make sure there are no holes or gaps letting out the gas, make sure the valves is completely up to allow full gas flow. Also check that the tubing is clean of debris.
Posted on Oct 18, 2010
Aeg ovens work on brand new model number 49176iw-mn but induction hob wont turn on
Many people have had faulty AEG cookers. I would return it if i were you and get something else
Jun 24, 2016 | AEG Ovens
What products can I use to clean my aeg hg795540xb gas glass top hob? The instructions say neutral products and no hob scrapers
Please, follow this link:
http://www.amazon.co.uk/AEG-Electrolux-50296742005-Ceramic-Cleaning/dp/B002LJDJ7Y
25358477-ou0pu244fjwiiyewsm5u145c-2-0.jpg 6. CARE AND CLEANING WARNING!
Refer to Safety chapters.
6.1 General information
• Clean the hob after each use.
• Always use cookware with clean bottom.
• Scratches or dark stains on the surface have no effect on how the hob operates.
• Use a special cleaner applicable for the surface of the hob.
Dado
Jan 06, 2015 | AEG Ovens
Twin ovens stopped working
Hi, Have you altered the time clock on the cooker? It is possible that the clock/timer is set for 'Auto'
Dec 26, 2013 | Caple Ovens
Gas hob will not light on my leisure gas hob
At the rear of the oven is a gas cut off valve. Try twiddling it
Nov 24, 2013 | Ovens
I have an AEG D8800 4M oven. Oven overheating to the point where element glowing and had to turn off quick. Tried again next day on low setting and although control panel bleeps to incate required...
If it is a fan assisted oven, then make sure the fan is working o/k, if it is, then I would suspect that the oven thermostat is faulty and needs to be replaced.
Jan 23, 2011 | AEG Ovens
The light on my aeg competence oven and grill is not working. I can not use the timer.
It's either the thermostat / switch or the timer unit. Make sure the timer was not set to have turned off the grill first
http://www.espares.co.uk/part/cookers-and-hobs/thermostats/aeg/p/1604/143/0/0/1061574/top-oven-thermostat.html
May 20, 2010 | Ovens
AEG Oven model D98000VF - error code F8 on display. All functions failed (no grill,ovens,hob)
May 02, 2010 | Electrolux Ovens
Cant turn cooker on
Depending on the brand of oven, you need to get it off auto, and onto manual to be able to use oven.
You should find the info you require in your user manual.
Please rate my solution.
Thanks.
Sep 22, 2009 | Ovens
Ovens Logo
163 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
