Question about Microwave Ovens
Sagging frigidaire microwave door
Professional series one year old frigidaire microwave. the kids pull the door when using it, so the door is sagging. still works fine. any solution?
thanks
salem
  • 21 Answers
If your door is removable, look where there is a plastic seal or ring on the door itself. It is usually attached to a bracket or near there someplace. I have taken plastic washers and put in place, otherwise replaced the parts that are worn out on the door assembly.
Tell kids not to pull on door while in use. Harder said then done. I have 9 children and they all have done this. My youngest still thinks he can microwave GI Joe to death.
Anyrate, if the issue I gave doesn't work, try your local appliance repair store. Sometimes they can help by either repair or giving advice.
Good luck.
Posted on May 26, 2008
  • 2 more comments
  • mcla1312 Mar 10, 2011
    i have the a same problem. it started out with just the bottom hinge becoming loose inside now a middle tack weld or something has come loose. the door is really hanging now. it looks like the hinges were tack welded to the metal frame are all coming loose
  • cantonglassw Jul 17, 2011
    I have the same problem. The kids are short so they pull the door down as they open it.
    I called a major dept store that has an online parts center and they sent me two screws ($17) . After getting the unit off the wall it appears that there are no screws to attach at all and the unit was tack welded as you suggest.
    There are holes that line up on the hinge and the microwave but they are bigger than 4mm but smaller than 5mm. The thought has occured to tap a 5mm hole and screw it back together. I could get a buddy to weld it back. I've read on line about JB Weld. Definitely fixable.... seems like a common problem. Curious how others have solved this.
  • warcraft demonhunter Mar 02, 2013
    All you have to do is use 3mm or 4mm pop rivets. I fixed mine a year ago and its still holding strong.
  • warcraft demonhunter Mar 06, 2013
    http://www.fixya.com/support/t1769845-fr...
Frigidaire microwave door is sagging
Hello Irfan, thank you for your post!
From the information you have provided the door on your Frigidaire microwave is sagging. Your door could be sagging due to the hinges or the door being damaged. I would check to make sure there is no visible damage. It is possible that the hinges and door may need to be replaced as well. To help avoid any unnecessary part purchases you may need to seek assistance from a professional technician for proper repairs. -Matt
Aug 10, 2015 | Frigidaire Microwave Ovens
My Frigidaire microwave door is sagging and about to fall off
I appreciate your post, Wayne!
From my understanding your Frigidaire microwave door is sagging and about to fall off. This could be an issue with your hinges or door. In order to check if you hinges are not damaged you may need to disassemble your microwave this is not a simple DIY job. I would highly recommend having a professional technician out to perform a proper diagnosis and repair. This will help you avoid personal injury, future problems, or unnecessary part purchases. I hope this information is helpful for you. -Matt
Apr 24, 2015 | Frigidaire Model PLMVZ169GC Microwave Oven
Fix sagging frigidaire microwave door
Hello Rick, thank you for your inquiry!
From my understanding you need to fix a door that is sagging on your Frigidaire microwave. Your door could be sagging due to the hinges or the door being damaged. I would check to make sure there is no visible damage. It is possible that the hinges and door may need to be replaced as well. To help avoid any unnecessary part purchases you may need to seek assistance from a professional technician for proper repairs. -Matt
Apr 01, 2015 | Frigidaire Microwave Ovens
My Frigidaire microwave trips the breaker every 5th or so use before the microwave begins to cook.
Thank you for your post, Steve Shaw!
From what you have described it sounds like a possible faulty wiring harness, control panel, or magnetron within your Frigidaire microwave. I would recommend having a professional out to provide a proper diagnosis. This will help to avoid unnecessary part purchases. -Matt
Dec 17, 2014 | Frigidaire FFCE1638LB
Door is sagging and causing it to not work properly
Hey friend, thank you for the post!
I understand that your Frigidaire microwave door is sagging and your appliance is not working properly. You could need to a new door or hinges. These intricate parts do require precision and patience, therefore when replacing the exchange of such components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Chris
Aug 17, 2014 | Frigidaire PLMV168 Microwave Oven
Microwave door sags
I had the same problem. An easy fix is to remove the door by opening the door, take a screwdriver and pop the plastic retainer piece from just below top hinge on the door. Now lift the door gently and it will come off in your hands. Set aside and be careful not to let the loss bracket that passes into the microwave body fall back into the cabinet. I would suggest you use a small vice grip locked onto that bracket to keep from lossing it inside. You will see two holes, one near the top and bottom through the cabinet into the hinge. line these holes up with the hinge holes behind them and use a pop rivet gun and 3/16" rivets to lock into place. Then replace the door and retainer piece. If you only have 1/8" rivets you can hold the bracket lined up with the original holes and drill 1/8" holes of your own a little distance away from the original holes and then pop rivet through these holes.
May 12, 2010 | Frigidaire GLMV169D Microwave Oven
Frigidaire Professional series microwave won't heat
The most likely problem is the magnetron. Check your warranty in owners manual, I believe you have five year warranty on magnetron.
Mar 15, 2009 | Frigidaire FMV156DC Microwave Oven
Frigidaire gallery microwave door sags
Repairing the loose, detached hinge is simple.
First buy a pop rivet tool and 1/8'' or 3mm rivets for about $16 at lowes
Second remove the door. There is a little plastic pop tab on the inside top corner of the door by the hinge that keeps the door from lifting off of the hinge pins. Use a 1 inch putty knife or maybe a butter knife and pry from the bottom crack. Once tab is off the entire door can be lifted off.
Third, line up the little holes in the bracket with the little holes in the microwave face. Insert a pop rivet in the hole and squeeze the tool till it pops off. I put one 3mm rivet on the top hinge and one on the bottom.
No drilling needed on my Fridgidaire PLMV169DCd microwave. I guess u could drill a 1/8'' hole thru the microwave face and the hinge bracket if there isn't one on your model.
Mar 10, 2009 | Frigidaire GLMV169D Microwave Oven
Sagging microwave door
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If the door seal is damaged or out of alignment, there is a chance of leakage, which can cause burns, damage to the oven or even a fire hazard.
Feb 08, 2009 | Frigidaire FMV156DC Microwave Oven
Microwave Ovens Logo
1,040 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
