Question about Sony Cyber-Shot DSC-T1 Digital Camera
I'm taking close up photos of jewelry, using ISO band it's a little blurry?
    Brigadier General:
  • 11,967 Answers
Make sure you're using a tripod and that the camera is set for "macro" photos for close-ups.
Posted on Sep 30, 2010
Randomly, many of my photos are blurry.....
Looking at this camera manual I see that you can switch to PASM mode which I'm suggesting you use "P" Program. Also to get the best ( steadiest) photo's switch to the EFV (electronic viewfinder) there is a little swich just below and to the right of the viewfinder for switch from and too. it may have LCD/EFV on the switch A great idea for the very best photo to print is to use ISO 100 but this may prove difficult in some lighting situations try it and if you have some problems this can be changed to ISO 200 or higher but the higher the ISO number the grainier the pictures will become.
So a reap. Change to "P" program in the PASM mode. Switch to the EFV viewfinder, try ISO 100 but ISO 200 will work as well. What the big change is, is to use the Electronic viewfinder this brings the camera closer to your face and your arms are tucked into your body making it much more stable to hold. Happy New Year
Dec 31, 2010 | Kodak EasyShare Z740 Digital Camera
Trying to take photos of football game at night. pictures either blurry or too dark. Any fixes?
Are you using a point and shoot camera? If so, unless you get very close, you're not going to get good results. You could try raising the ISO setting and do not use flash. Use a monopod or some sturdy way to hold your camera steady. The best camera for the type of shots you want is a DSLR.
Nov 28, 2009 | Cameras
Used to take great photos. Now lots are blurred.
Camera or hand shake are the most common cause of blurry photos, long exposure needs slower shutter speed, this is happened when your subject have inadequate light, and during this process, the camera sensor/shutter is open, causing the resulting photo to be blurry, because even a single movements of your camera or hand will cause the camera sensor to move, that causes a blurry capture. In order not to experience this, you have to be familiar with the setting of your camera, there are 3 important settings you have to understand: ISO Setting, Shutter Speed, and the Aperture Setting, they are related with each other. ISO Setting, is the sensitivity of your camera to light, meaning the higher the ISO, the more sensitive your camera in light, and the more sensitive, the faster your shutter speed. ISO scale from 100, 200, 400, and so on, depends on the cameras specs. Shutter speed, is the speed of the opening and closing of the camera's curtain( e.g. 1/30, 1/60 of a sec....and so on) and Aperture is the opening size of your lens focal points (the lower the f, the wider the opening: f1.4, f1.8, f2.0, f2.8, f3.5, f5.6, f8, f11, f16, f22, f32
I hope this will be helpful.
Jul 19, 2009 | Canon PowerShot SD850 IS / IXUS 950 IS...
Close up pictures
For the jewelry shots you will need an accessory telephoto lens with a macro feature OR a close-up filter set. The lens will give you more features, but the filters will be the less expensive option. The lens should also help with your video shots. I have a Z650, and I use both options - depending on the situation. eBay is a good cost-effective source for these accessories.
Bill B.
San Antonio
May 11, 2009 | Kodak EasyShare Z1275 Digital Camera
How to take clear close up pics of jewelry
use close up mode on camera (flower mode). turn off flash and light jewelry with other light source like sun light or other photo lighting (like light box or photo lamps).
Apr 16, 2009 | Sony Cyber-Shot DSC-P200 Digital Camera
Blurred images
Any number of things.
Low ISO. No Flash. No tripod. Too little light. No "shake" correction on the camera.
Depending on the goal of the photo, you may wish to use a tripod. Or use the flash. Or use a higher ISO (400+). Or any combination of these.
The easiest thing to do would be to make sure you use a flash. If you're trying to take a photo of something without the flash, you'll have to use a tripod. And even then, if something is moving fast through the frame, it'll likely be blurry. You simply need more light.
If you're new to digital cameras, I recommend the automatic settings. There's an "action" mode which usually has a man running as an icon. Or someone in motion. Some cameras even have settings for use at night or in darker rooms. Try those.
If you feel comfortable, you could manually bump the ISO up to 400 and try again. Your photo may be a little "grainer" and will probably look a bit ugly blown up much over a 5x7, but for 4x6 or anything online, it should be fine.
Feb 27, 2009 | Polaroid i830 Digital Camera
"hand" icon flashing
It's likely your photos are blurry from camera motion, caused by taking a hand-held photo with a slow shutter speed, rather than out of focus.
The hand icon flashes when you don't have enough light to take a crisp (not blurry) photo without either using a tripod (or a flash). The reason for a flashing hand is you can't "hand-hold" the camera at the current settings - you need to use a tripod. If you are "zoomed in" (on a telephoto setting for your lens) you can sometimes get a crisp hand-held photo if you "zoom out" to a wider angle setting on the lens. (You need a steadier hand to hand-hold a telephoto lens setting than a wide-angle lens setting.)
You may have changed a setting that sets the ISO (the normal setting would be "auto") and if so, if you change the ISO to a high number, or to auto, this will help you take better photos in low light. Check your camera's user's manual to see how to check/change the ISO.
When you have more light the icon will stop flashing. If you need to take hand-held photos in low light then you need to use flash, or get a better camera that has better low light capabilities.
Dec 14, 2008 | Nikon Coolpix 5200 Digital Camera
I can not get the watch band to fit my wrist. How do i shorten the band
If it is a metal band there are links in the side of teh band that you can remove. If all teh removable links are gone you may need to change the band into a smaller one. And there are little pins by the watch you can do that as well. I recommend taking to a jewelry repair shop. Some jewelry store do repairs as well, and may have parts you need for this as well as the tools.
Dec 12, 2008 | Watches
Canon power shot S3IS
Apparently this is not the camera for marching band stuff at night because I had this problem over the weekend!  I tried everything...
Oct 18, 2007 | Canon PowerShot S3 IS Digital Camera
Sony Cyber-Shot DSC-T1 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
