Question about Intel D945GCL Motherboard
How to check above board warranty tell me - Intel D945GCL Motherboard
Enter this site with note down *********** board serial number and AA number
http://www.intel.com/support/motherboards/desktop/sb/CS-009050.htm#swr
and click live chat support button when he ask you send your serial number and AA number he will tell about your warranty
Posted on Oct 02, 2010
Green line tv screen
A defective or loose contacted LVDS cable can cause this problem. Re-seat the cable said above at it both ends and check. A defective T'Con board too can cause this. The LVDS is the flat cable the connects between display panel and T'Con board. If you wish see the cable and internal connections of LCD TV, check the link given below. Check the disassembey procedure to any LCD TV. Illustrations are there. Check the cable said above, which connects panel and T"Con board. This will be common to most models. Pull up older posts there. You can get an idea.
May 16, 2013 | LG 50PK550 50 HDTV Plasma TV
I have a problem in Samsung omnia B 7610.When I plug in the charger to power source it displayed the battery is full.When I plug out the battery is low and uncharged. samsung service center people say...
hi,
are you sure your battery or charger are OK?
first check these two device then refer to warranty section .
1- check the battery with an other charger same as your charger which you load from one your friends which has it .
2- chack your charger same above but with a battery of your friend.
if none of them didn,t the suitable result , then refer and follow the warranty section for
change of complet board , of course if this way is costs
good luck
gorbesia
Jun 15, 2011 | Cell Phones
When I turn my power on my screen stays black and i have no picture on it ....if i continuiously run my hand across the keyboard and keep turning it off and on it eventually comes on...i have had a couple...
you have to do process of elimination as it could be all of he above or something else.
first- take battery out plug in ac only to check battery
second- hook to external monitor to see if its display
third - if you have 2 memory modules take one out at a time
if not those probably main board related or component related if warranty call support or take to repair shop
Jan 21, 2011 | Dell Inspiron 1525 Notebook
What does a square with a line through it and 114 08 mean? Typewriter won't type. And there were 6 beeps associated with the above.
114 is a processor board error. The boards are about 125.00 to
150.00 plus labor. The George Beyers Co. offers a complete rebuild for under 200.00 With a warranty 800-392-8085 tell them O'Reilly sent you.
DickyO
Mar 03, 2010 | IBM Wheelwriter 30 Typewriter
Power Problem with Zenith Z50PX2D
I had the same problem with same model TV a year back, they replaced some board (I was not there at home) as I had warranty and after a year same issue popped up again.. Can you please tell me what board replacement worked for you. I don't have warranty anymore.
Jan 30, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
Warranty on maxtor 3200
This is Maxtor's website for checking the warranty of your product - just enter your model number and serial number - it is also usually on the last page of the manual - you can also call Maxtor and give them your model and serial number -
http://support.seagate.com/customer/warranty_validation.jsp
May 26, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Motorola Z8. I have a Motorola Z8, it is 4 months old. I have a period error, when it's fully charged and i use it, it shuts down, and i can't start it again before hours later. It gets really hot too....
There is a short in the phone or the battery has a defect. I would bring it in for a service check. If the phone is under warranty, they will either change the circuit board, or give you another phone. If it is out of warranty, it will most likely not be worth to service the phone.
Were you even out in the rain with this phone?
Did you ever splash water or any liquid on this phone?
Did you ever drop this phone?
The three questions above are the most common causes of failures in most mobile phones. When the service tech opens the phone and looks at the circuit board, he will be able to tell if the board ever became wet. There will be burns and or corrosion in the board surface.
Jerry G.
May 02, 2008 | Cell Phones
LG 50PX4DR plasma tv
call 877-543-8325 this is an LG Executive call center and they will fix this for free. I have a 50" plasma I bought january 2006 which is out of warranty by 5 months. They faxed me and the LG repair shop a 30 day warranty for my tv to cover the repair. Just tell them you heard a pop and in my case the picture is distorted. All they need is the model number and serial number and they should take care of it. No arguing needed.
Jan 13, 2008 | LG DU-50PX10 50 in. Plasma HDTV
Help
sounds like the main board is out but could be a power board, too. hard to tell without using a voltage meter on the powerboard. vizio normally will change out one board and then the other to see which part is bad. a lot of these parts are covered under warranty and some parts have lifetime warranties. so definitely check with vizio support and have your model number. hope this helps.
Nov 18, 2007 | V, Inc. Vizio P2 Plasma Television
NO MONITOR OUTPUT
Check your ram. Just take it out, clean it and reseat it to reinforce connectivity.
Thanks,
Lolita
Oct 12, 2007 | ASUS A8N-E Motherboard
Intel D945GCL Motherboard Logo
219 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
