Question about Keurig B70 Coffee Maker
The coffee tastes bitter...how do i clean system or improve this...it tasted great in the beginning but now is like all other coffee makers...dissapointing
  • Patrick Williams Sep 30, 2010
    I will try that as well as Vinegar....thanks
    President:
  • 2,047 Answers
Run water through nthe device like you are making coffe but ensure that there is no coffee in it. Try doing this a couple of times it should clean up the chambers where the coffee go through while it is being made. Usually coffe starts to taste bad when residue from coffe that has been made inside the machine starts to mix with new coffee being made. Running ordinary water through the unit ensures that most of this residues are removed.
Hope this solution has been helpful?
Posted on Sep 30, 2010
How does wheat grass juice taste like?
Grass juice taste like grass only but it is very healthy. Healthy things do not taste good so to have the healthiness of the juice you can have it with a smoothie. Some health benefits of grass juice are:
1. Contain vitamin-like B 12, E, C
2.Treat skin diseases
3.weight loss
4.Reduce food carving
5. Detox your cells
6.Improve immunity
7. Improve digestion ad much more.
Apr 29, 2014 | Sunny Health & Fitness Office Equipment &...
Bitter taste
You will likely find the bitterness is a function of your coffee bean choice or the 'roast' component of that coffee. Darker roasts tend to taste bitter.
Nov 03, 2013 | Cuisinart Grind and Brew 10 Cup Coffee...
Over time, my coffee has become acrid and bitter. I use fresh ground coffee and clean my pot regularly...what else should I do?
There may be some buildup in the machine other than in the pot itself. To test this, try running the brew cycle with no beans. Taste the hot water. If it's acrid and bitter, your problem lies in buildup (such as the basket). Otherwise, if the hot water just tastes like hot water, then the temperature of the water has probably become too high (that will make coffee tastes more bitter). If this is the problem, there's probably no fix (just make sure you fill the reservoir with cold, not hot, water).
Sep 26, 2013 | Bunn Pour-O-Matic VPR
Why is coffee bitter?
Bitterness is a dominant quality in the overall taste of coffee. You need a certain amount of bitterness to balance out the flavor. There are two types of chemicals that give coffee most of its bitter taste - both are antioxidants.
Jan 10, 2013 | Wine & Spirits
Ran descale program and coffee still tastes funny (bitter)
If you are using a Claris filter, please remove this from the watertank. The descaling agent will clog the filter and make the water taste bad. After descaling, also be sure to rinse the watertank so there`s no resedue of the solvent left in the tank.
However, bitter taste on the coffe usually is related to the coffee side; Try to run a cleaning program. And check grinder settings. If the powder is to fine, it will increase the contact time, and that will make the coffee bitter. My advise is to clean the machine and experiment a little with the grinder settings.
Apr 05, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
What can I clean my Bunn proffessional coffee maker with ?
mcdevito75 here, Contact Bunn for their recommended cleaning material for your coffee maker, or see any large store that carries coffee makers for their cleaning kits.
Jul 11, 2010 | Bunn VPR Coffee Maker
Coffee is really bitter and doens't taste good
hmm well it wouldn't surprise me. I'm glad you were able to get to the bottom of it! ;) have a great day and enjoy your Keurig!
May 26, 2010 | Keurig B60 Coffee Maker
BITTER TASTING COFFEE
I would check the temperature of water. Sounds like it might be too hot. The temp of the water should be between 192 and 197. Colder and its sour, and hotter and its bitter.
Mar 13, 2010 | Rancilio Coffee Makers & Espresso Machines
My cuisenart 12 cup thermal coffee maker makes bad coffee. I can't return it as it was a fathers day gift. coffee always tastes bitter and burnt. at work we use the same coffee in a 20 dollar sunbeam...
The quality of the water is responsible for the flavor of the coffee. If you have had this coffee maker for a while it is probably coated with lime. Run a couple of cups of vinegar through it followed by a couple of pots of clear water. That will clean up your machine.
Once it is clean, try making a pot with bottled water, or water that you run through a water filtering pitcher.
You will be amazed at the differenct.
Jun 11, 2009 | Wega Mininova EPU Espresso Machine
Saeco Aroma now only produce bitter coffee...
besides a good coffee machine, 2 things are critical when you want a good cup of coffee; the coffee itself and the water. When in France, i tasted some of the best coffee I have ever had, but they always told me that the quality and purity of the water made for 50% of that great taste. Has your municipality changed anything about the water treatment recently? Do you drink that same water and find it tastes funny? Perhaps bottled water is a solution in your case. Hoping this helps.
Marc
Feb 03, 2009 | Saeco Aroma Espresso Machine
Keurig B70 Coffee Maker Logo
1,873 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
