Question about Bose Wave Radio
My alarm setting is on and I can't turn it off. It is interfering with all the other controls. Any advice on how I can turn off all alarm settings?
  • Bose Master
  • 17,130 Answers
Remove the plug and try to keep it aside to reset. now try to see if the alarm can be put off, if not the problem can be the mP going off in errors. keep the set unplugged overnight or if the manual describes a reset try to set it up.
Posted on Sep 30, 2010
How do I set the alarm on this model, which I cannot find any where. Grateful & puzzled. Model 7-4806A GE Clock Radio
if I could see a good picture of it perhaps I could assist . most have a slide bar to turn the alarm on then you use the hour or minute buttons to set .
Mar 18, 2016 | Audio Players & Recorders
Tip
How to set & cancel theft deterrent system or how to set & cancel security...
Theft deterrent system (on some models)
Theft deterrent system is designed to deter vehicle theft. The system flashes the turn signal lights and turns on the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn when it detects abnormalities such as follows:
• Any door or hood is forcibly opened.
• The batter terminal is disconnected and then reconnected
• The system control is disconnected and then reconnected.
• Abnormal impact is detected when the impact sensor function is on.
The system flashes the turn signal lights and turns the interior light or the signal lights only (depending on the model), and sounds security horn and vehicle horn if someone attempts to damage or break into your car.
Setting the system
You can set the system with or without the impact sensor function. For details, see "Canceling the impact sensor" below.
1. Turn the ignition key to "LOCK" and remove it.
2. Have all passengers get out of the vehicle
3. Push the lock (set) switch on the wireless remote control key once. At this time, the turn signal lights flashes once and the security indicator light comes on.
The system is set after 30 seconds. At this time, the security indicator light start flashing slowly.
Once the system is set, you cannot start the engine until you cancel the system.
The system will not be set in the following cases.
• When any of the door is open; security horn sounds for 1 second, close the door and set the system again.
• When the hood is open; close the hood securely.
Canceling the Impact Sensor
The impact sensor can be cancelled to prevent false alarms from being triggered incase of the following conditions:
• When parked in the noisy area
• The vehicle body or glass is subjected to a strong impact from the (such as in highly pressurized car wash).
• When transporting by a car carrier or ferry.
To cancel the impact sensor;
1. Lock the door by pushing the lock (set) switch on the wireless remote control key once, and turn signal light flash once
2. Then push the lock (set) switch twice within 5 seconds. At this time, the turn signal flash 5 times to indicate the impact sensor function is disable.
The impact sensor is deactivated as long as the system remained armed.
Canceling the system
The system will be cancelled by the following two ways:
• Turn the ignition key from "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch
If the turn signal lights flash 3 times, the system has been alarmed. Check to see if there is any abnormality with your vehicle.
If any of the doors is not opened within 30 seconds, all doors will be automatically locked and the system will be set.
When the system is set
Activating the system; When the system detects abnormalities such as follows, it flashes the turn signal lights and turns on the interior light or the turn lights only (depending on the model) and sounds the security horn and vehicle horn of 30 seconds.
• Unlocking any door without using wireless control
• The battery terminal is disconnected and then reconnected.
• The system control assembly is disconnected and then reconnected
Reactivating the alarm;
Once set, the system automatically resets the alarm after the alarm stops.
The alarm will activate again under the same circumstances described in "Activating the system".
Stopping the Alarm
The alarm will be stopped by the following two ways;
• Turn the ignition key from the "LOCK" to "ON" position.
• Unlock any of the doors by pushing the unlock (cancel) switch.
The system can be cancelled by these ways at the same time.
If the battery becomes discharged due to the vehicle being unused, for a long time etc., when the battery is recharged or replaced, the system will activate the alarm. If this happens, immediately unlock any of the doors by pushing the unlock (cancel) switch, and the alarm will stop.
Testing the system
1. Set the system
2. Insert a wireless remote control key into the key hole on the driver's door handle, and unlock the door.
3. Open the door, and an alarm will sound.
4. Stop the alarm by pushing the unlock (cancel) switch.
5. Repeat this operation for the front passenger's door.
Good luck.
on Nov 08, 2010 | Toyota Pickup Cars & Trucks
Alarm set
this is a factory alarm, the problem is the alarm is active, you will need to use the door locks to turn alarm off, insert key in driversdoor and lock and then unlock door this will turn alarm off, if that doesnt work then use pass/side door, the lock has a built in switch that knows when the door is locked or opened, the driversdoor may have a bad switch so inturn the computer thinks the door was forced opened without key and it is turning alarm on, so again use the key to unlock door try the pass/side if driversdoor doesnt work. good day
Nov 24, 2011 | 1998 Plymouth Voyager
How do you turn off the HWS alarm on a makita bmr100
A beep tone will activate when selecting the HWS buzzer
alarm.
The alarm beep will become shoter and shoter every
15 seconds for one minute followed by one minute silence
before repeating the cycle.
The HWS alarm will sound for one hour until turning off by
pressing the Power button. Press the Power button whilst
the alarm is activated will cancel the alarm for 24 hours.
1. The HWS buzzer alarm can be set either radio is on or
off.
2. Press and release the HWS buzzer alarm button
, the symbol will flash.
3. During the symbol flashes, long pressing the
button for more than 2 seconds followed by a beep
and display Hour digit will flash.
4. Rotate Tuning Control to select required alarm hour,
then press time set button again. The minute
digit will then flash.
5. Rotate Tuning Control to select required alarm minute,
the press time set button again to complete HWS
buzzer alarm setting.
6. Press and hold down buzzer alarm button for
more than 2 seconds followed by a beep to switch on
or off the HWS buzzer alarm.
Display will appear when buzzer alarm has
been set.
May 25, 2011 | Car Audio & Video
The engine wont start and the tamper alert system keeps interferring when it's on. What can I do to fix this problem? We believe it may be the fuel line stopped up, but I want to keep more options open to...
Could you explain more? I know mine did that. If you set the alarm off or unhook and reconnect the battery it will disable the computer and the car will not start. Try reconnecting the battery. That will set the alarm off then insert the key into the drivers door and turn it to disable. It could also be problem with the alarm system. Sorry if
Im misunderstanding.
Mar 31, 2011 | 1992 Chrysler New Yorker
I don't know how to set the clock for a MA4203 model
I couldn't find the information for your particular model, but I did figure out the general procedure for Memorex alarm clocks currently in production:
  1. Make sure power is turned off (no radio or whatever playing). Press the Time Set button (on some models, this is the Skip Search Back button for an iPod docked in the unit).
  2. When the display blinks (on one model, the volume control knob lights up), press the Hour button (Vol. -) to set the hour, then press the Minutes button (Vol. +) to set the minutes. On the model with the light-up volume control, rotate the volume control knob to set the time.
  3. When you have the time set, either wait 15 seconds or press the Time Set button again to start the clock.
Setting the alarm works the same way on single alarm models, but the Alarm Set button may be the Skip Search Forward button. Dual alarm models have separate Alarm A and Alarm B buttons.
Feb 05, 2011 | Memorex Audio Players & Recorders
How to set alarm time on bose wave radio
To set the Alarm 1 time - On the control panel, hold down ALARM
SET and press TUNING up or down. The time display changes slowly at
first, then more quickly. Release TUNING to stop.
On the remote, press TIME. The ALARM indicator flashes. Press
TUNING up or down. The time display changes slowly at first, then
more quickly. Release TUNING to stop. Press TIME to return the display
to the current time.
To turn on the Alarm 1 function - Press ALARM MODE or
ALARM in sequence to select the mode you want: tone, radio,
both tone and radio, or off.
For tone only, press until the indicator lights.
For radio only, press until the indicator lights.
For tone and radio, press until both indicators light. When the
alarm goes off, the tone sounds. Press SLEEP/SNOOZE to turn the
radio on. Press SLEEP/SNOOZE to pause the radio for 10 minutes.
To turn off the Alarm 1 function - Press ALARM MODE or
ALARM until the display shows no Alarm 1 mode indicators.
To check the Alarm 1 setting - On the control panel, hold down
ALARM SET to see the wakeup time.
On the remote, press TIME to see the wakeup time. Press TIME again to
return the display to current time.
To wake to a preselected radio station with Alarm 1 - While
holding ALARM SET, press the PRESET button for the station you want
(change between AM and FM if needed).
Dec 02, 2010 | Bose Wave radio/CD remote control -...
What do the codes on the front panel mean... Like LL and AL?
Alarm (AL)
When the Alarm mode is off, all audible alarms will be
disabled until the feature is turned on.
Auto Light Level Selection (LL)
This setting adjusts the light level at which the
dispenser light will illuminate when the sensor detects
that the light levels in the room are low. Setting 1 is
the darkest light level setting, setting 9 is the brightest
light level setting. Important: The Auto Light must be
activated on the ice and water dispenser control to
take advantage of this option.
Sabbath Mode (SAb)
When the Sabbath Mode is on, all control lights,
interior lights, and the night light will be disabled until
the feature is turned off. Press the Door Alarm pad
for three seconds to restore the lights.
Mar 14, 2010 | Amana AFI2538A Bottom Freezer French Door...
How do I set the alarm? Please help! Am I supposed to do something after setting the time of the alarm? The display continues to flash the time.
To set your alarm you should be turning your Set Control (the big round button just below the Set Day button) to Alarm 1 or 2. Once you finish setting your time you should be able to turn the Set Control back to Clock and the time should stop flashing. If this does not work you may have a defective unit which you might have to take up with your retailer.
Jul 07, 2009 | Philips AJ3965 Clock Radio
No volume on my GPS 60
There is no volume control, but page 44 of your manual might help.
Go to the setup menu, then select "tones"
Use the drop down arrows to select a tone for "message beep" and "turn warning". One of those two settings is for the anchor drag alarm.
Make sure the mute box at the bottom is not checked off.
When setting your drag alarm, bear in mind that GPS error is usually @9' to 15' it can be as much as 50' in any direction. Which means any drag distance less than 100' is likely to cause false alarms. Choosing a drag distance that is at least twice as much as the position error reported on the satellite status page will minimize false alarms.
Jul 23, 2008 | Car Audio & Video
Bose Wave Radio Logo
196 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
