Question about Miele 30 in. KM443 Electric Cooktop
Ceramic top stove will not turn on. No lights, no heat. It just beeps when I press the power area of the ceramic.
We cannot turn off the lock on our ceramic cooktop and it keeps on beeping.
Try cutting power to it to reset electronics. If that doesn't work, then most likely a control issue
Nov 05, 2017 | Cooktops
Why is stove top displaying symbols not recognizing pots? Had stove 6 weeks, pots are correct and been used on this stove. Displaying on all 3 cooking areas.Can I correct it or is it faulty?
lets review this
please advise readers
maker of cook top so they can find the user manual
model or how old helps also
its not a gas cook top
you have the right type of designed pots for that cook top
but you get no heat radiating to the pot base
when pot is in contact with the heat area
Aug 17, 2016 | Cooktops
Burners ceramic top stove
FIXYA has no agents and have no idea who can assist you there
Dec 15, 2017 | Creda Cooktops
Maytag ceramic top stove with the double oven, two small burners don't get hot anymore can I fix myself and how?
It is simple . Before the process make sure the the power is off .. There screws on the back after removing them you can lift the top n easily remove the none working ones . You can buy the spear ones online or local shop . I have done it myself or search YouTube with model number youse come a cross with repair option . Good luck .
Aug 06, 2013 | Cooktops
I had new countertops put in and they took they drop in stove out. When complete tegy put the stove back in and everything worked fine. Within 5 minutes the control panel went off. Oven light works and...
The control panel must be on and in manual mode for the oven to work. Turn the power off for a moment and then back on. If the panel starts to flash, set the time and set it to manual and the oven should work. If the panel does not light up it is faulty and requires replacement.
Feb 26, 2011 | Frigidaire Cooktops
Whrlpool Electric Stove Top Burners
this is a ceramic top i am guessing.
this is normal, it isthe way it is designed.
it does this so that it does not cause a heat fracture to the glass.. it will continue to turn on and off.. but if you put a pot of cold water on it you will find that this will happen alot less frequently.
Oct 09, 2009 | Cooktops
I have a whirlpool drop in ceramic stove and a burner isnt working. i had a repair man come and he was trying to pry the stove up but was having trouble because the person that insatlled it years ago...
When you dont replace the ceramic top that ios cracked could cause issues in your circuit board. The best thing t do is buy a new stove. The parts nad labor along is going to cost you about the same price as a new one.
Apr 25, 2009 | Stoves 23 in. Premier TC600I Electric...
Stove top in lock mode
Hold your finger or thumb on the red light for a few seconds, and you will hear three beeps. This tells you that the lock is off. If the light is not on, do the same and there will be three beeps, and the light will come on, telling you that the lock is back on.
Feb 18, 2009 | Dacor Millennia ETT304 Electric Cooktop
Stoves 700CTH hob
I have a Stoves 900 CTH with the same problem. Its been like it for about 6 months and we're still able to get it going eventually.
If you turn the power on at the mains and leave it beeping for about 2 hrs then press the power on touch button. You should see all the "0."s flashing. When the flashing and beeping goes slow try pressing one of the hob buttons alot until the little dot illuminates next to the 0 then quickly lit the + button.
It sometimes works after 5 mins but other times it takes 20-30mins and is a real pain in the ****.
I did ring Stoves a while back and they quoted me £190 for the pcb but I hardly use it so just lived with it as it is but I finally had enough tonight and done a web search which turned up this thread.
I've just pulled it to bits to see if I could locate this "C17" but not 100% sure what I'm looking for.
29792d1.jpg Is it the big silver thing in the center with 5B RVJ on it?
Jan 12, 2008 | GE 36 in. Profile JGP962 Gas Cooktop
Miele 30 in. KM443 Electric Cooktop Logo
64 people viewed this question
Top Miele Cooktops Experts
mpservices
Are you a Miele Cooktop Expert? Answer questions, earn points and help others
