Question about Marshall Mg100dfx 100-Watt Combo Guitar Amplifier
Marshall mg100dfx, internal fuse blowing every time you switch on the unit. What could be the problem
  • 1 more comment
  • cmangles Sep 30, 2010
    Thank you for the advise it really helped. I have found the problem.
    It is the main power chip IC1. Do you know where i can purchase a replacement For the Marshall Mg100dfx in the uk ?
  • cmangles Oct 01, 2010
    Hi, thank you for that.
    I cannot identify the chip from a number as it has no serial number on it.
    I shall have a look on the digikey site and see if i can match it up.
    Once again many thank's
    Got the number of the part and it is the TDA7293
    Thank's for all your assistance
  • Marshall Master
  • 5,603 Answers
The way you troubleshoot this is to put a 150 watt lamp in series with the input power cord. The lamp acts as a resetable fuse and will limit the current while you look for the bad component. Start with the capacitors and rectifiers connected to the power transformer.
Posted on Sep 30, 2010
Testimonial: "It was a great help, didn't take long to isolate the problem. Many thank's"
  • 4 more comments
    Following your advise i have located the problem.
    The main power chip ''IC1'' has gone short circuit.
    Could you recomend a uk outlet to purchase a replacement ?
  • Fred Yearian Sep 30, 2010
    If the IC is TDA7293 I would procure it from DigiKey.com in the USA.
    DigiKey.com search for TDA7293
    They show a couple, one may have offset leads. I don't know of UK sources, but I suspect they have some there.
    They are about $6 USD.
    Hi, the chip has no serial number on it. But i shall have a look on the digikey site under that reference number and have a look.
    Many thank's
  • Fred Yearian Oct 01, 2010
    Download a datasheet for it and compare to the electrical connections you find.
    Thank's for all your assistance, i now have the part number.
  • Fred Yearian Oct 02, 2010
    When poiwering these amps up after a repair DO use the series light bulb trick. Saves fuses should there be another problem!!! I repair a lot of amps and have learned to be cautious.
Blew a fuse now amp wont power up
It must go to a repair shop. There's always a reason that a fuse blows.
Jan 28, 2014 | Marshall Mg100dfx 100-Watt Combo Guitar...
The fuses on my marshall amp kept blowing so i took out the output assembly and it worked, but there is no sound. the output chip was burned. Where can i get a new Output Module Assembly For Marshall...
If the output module has a TDA7293 chip/stick on it, replace it. Use thermal compound like they did and observe any insulating washers used. Clean board and check for shorts after replacing.
Get them at about $6:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=497-2170-5-ND
and
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=497-8865-5-ND
Depending on how the leads are bent... first one leads go down (V suffix), second they are bent horizontally(HS suffix).
Apr 04, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
I am look for a fuses for a Marshall amp like Mg100dfx
Radio Shack Has bus fuses. I don't work for them. The Shack is wack, but they have fuses
Dec 10, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
How do I replace a fuse on a Marshall DFX 100, where is it located?
The fuse would be internal. The fuse blew for a reason, and unless you had an accident with the amp such as shorting a speaker lead, there is likely internal damage requiring servicing. Replacing the fuse without curing the original reason it blew will likely cause damage to further components.
Take the unit in for repair.
Sep 06, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
The digital FX on my Marshall AVT100 amp do not work, regardless of the footswitch. What do you think the problem is?
This is likely to be an internal problem. Check the +5 volt power to the DFX board as a first step.
Jul 28, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Hi i am john... i have a 100dfx mg series... it is
There are MANY more likely components than the transformer that will cause the fuse to blow.
Most common are filter capacitors, rectifier diodes, and shorted components in the power amp section.
Transformer failure is very UN-likely. Have a competent electronic tech troubleshoot the unit.
When testing the unit, put a 150 watt light bulb in series with the power line... saves fuses during troubleshooting. This limits the current so one can analyze the real cause of the problem.
Jul 12, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall GM 100DFX is blowing fuses
Probably one side of the power amp has shorted and there is likely several semiconductor transistors and other components requiring replacement, but this amp uses a stick IC power amp.
Copy/pasted from the music forum between the arrows, this is likely the problem in your unit:
>>The schematic is posted in the Enzo gallery at www.ampix.org
The 15 leg power IC on the heat sink is a TDA7293V - it is the power amp for the unit.
The chip with small board attached can be ordered from any Marshall dealer or from places like http://www.marshallparts.com/
I usually buy my 7293s from Mouser. They currently have 622 of them in stock and they sell for $6.48 each. Probably won't run out of them soon. << Hint for you: When powering this up after repair, insert a 100 watt light bulb in series with the line cord into the unit. This will act as a automatic reseting fuse which will save fuses if you haven't got all the "cancer" out of your failed amp. It will allow you to do troubleshooting by limiting the current to a safe value. Also, when replacing the TDA part, be sure and use heat sink compound under it and if an insulator was used, make sure you replace the insulator. ALSO clean the area of any soldering residue and flux BEFORE powering the amp again.
Jan 13, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Guitar amp shows power but has no sound, could it be a blown fuse
Nine times out of ten, any problem with an amp having no sound coming out, it's a wiring issue. Make sure all of the wires internal to the amp are propely hooked up. Also, try switching out the quarter inch cord you are using from your guitar to your amp. Could be a bad cable. Unless you have blown the speaker completely, something is loose or not hooked up properly.
Feb 27, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall MG100DFX noisy
Before you bring this into a shop, try spraying out all of the controls. Use an electronics switch cleaner that contains a lubricant. Spray into the control and work the control back and forth a number of times to loosen up any dirt inside. Then spray it again.
Let me know if that resolves the problem.
Thanks,
Dan
Feb 14, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall Mg100dfx 100-Watt Combo Guitar Amplifier Logo
575 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
