Question about RCA P52926 52" Rear Projection Television
Is my bulb going bad!!!!
How to tell if your bulb is going out in a projection televison. the picture is cloudy and starting to see a rainbow from the bottom of screen to the top.
  • Anonymous May 25, 2008
    picture is cloudy and has no green or blue.
  • 927 Answers
Without seeing your Tv it is hard to say what is really going on.
The cloudy picture sounds like one of your "bulbs" needs to have it's fluid changed, not "bulb" replacement.
Rain bowing normally means convergence adjustment or circuit repair is needed.
Posted on Jun 01, 2008
Samsung lns3251d half picture. This TV started off with half picture, found 3 bad caps replaced all on power board, now I get a rainbow of vertical lines, replaced T con board same thing, help!!
Below is a link for the manual for your TV, that may help. Have you tested all the rails on the power supply?...are they all good and with minimal ripple? If you had caps bad I'd have to wonder if there aren't more that you didn't find that are bad, testing the voltages will tell you that. What do you get if you unhook the LVDS cable?..does the screen turn blue or do you still have the lines, kind of wondering if you got a bad timing board.
LG 32LB9D Service Manual
Feb 06, 2018 | Samsung Televison & Video
55 inch sony wega rainbow issue
Your convegence has gone out. You can get complete kits with instructions from sites such as or just the parts from . If you have never done this before i would suggest going the kit route since it includes step by step photo instructions and support.
Mar 05, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
I'm getting a rainbow tint on the upper 1/5th of
usually when the lamp is going out the picture gets dark if you are getting a rainbow tint most likely the light engine is going bad.
Aug 17, 2009 | Toshiba 56HM66 56" Projection HDTV
Is the tubes going out on my rear projection tv?
If the red, green, and blue colors are separated like a rainbow, then the convergence amps are going out. This set has a common problem of two electrolytic caps going bad. The caps are in the upper left-hand corner of the main board and will have a bulged top if bad.
I would not think the picture tubes are bad, especially all at once.
- Dan
Apr 28, 2009 | RCA D52W19 52" Rear Projection Television
Picture with rainbow colors
The convergence circuit is not working. There are bad solder connections on the flyback transformer and a small fuse has opened up. This is not easily done yourself unless you have a technical background but an RCA technician can fix this no problem.
Mar 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Blue rainbows lines
I can help you out because I have circuit details of KP-65WV600but let me know what does it mean of blue rainbow lines?
I would appreciate if you post picture of those blue lines to understand problem of TV.
Thank you.
Nov 24, 2008 | Sony KP-51WS500 51" Rear Projection...
No picture, just red-blue-green lines through the middle of the screen very faint.
The PT-53WX54 is a standard projection set and does not have a bulb. It has 3 separate picture tubes. If you have lost the picture completely, not even on-screen menu, then something has stopped working in your set. It could be a video processor, vertical deflection or possibly a convergence problem. The set should be serviced by a qualified tech familiar with the Panasonic projection sets.
Aug 22, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Bent picture
The convergence circuits straighten out the edges of the picture, putting the 3 colors exactly where they should be for the picture to look normal. There are usually 2 large IC's that handle the 6 convergence channels and if one of them burns out then one of the colors bends dramatically. If the power supply for the convergence circuits stops working, then all 3 colors bend in, the colors do not line up with each other and the image looks almost 3D, and the adjustments in the convergence menu will have no effect. I would bet that is the case with your set - the convergence power supply has quit working. If you do not have experience troubleshooting power supplies and realigning convergence circuits in projection TV's then allow a qualified tech to handle it for you.
Aug 07, 2007 | Philips 51PP9910 51" Rear Projection HDTV
RCA P52926 52" Rear Projection Television Logo
121 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
