Question about HP LaserJet 4700 Printer
Fuser error 50.9 came up when we turned the printer on what does that mean??
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 108 Answers
Normally this error means you have a bad fuser assembly. These items are normally a customer replaceable part. If replacing the fuser assembly does not correct the error code you may have a bad power supply board.
Posted on Sep 30, 2010
Hp 1007 problem fuser error 50
The error 50 code on HP printers usually means a bad fuser unit.
Jul 08, 2015 | HP Office Equipment & Supplies
Machine error 50
On a Brother printer Error 50 typically means that the Fuser is malfunctioning.
Turn the printer off for about 5 minutes. Then turn the printer back on and wait for about 10 minutes. If after 10 minutes the printer doe not recover, you will need to replace the fuser unit. May be more economical to replace the whole printer.
Jun 30, 2014 | Brother Dcp-J125 Compact A4 Colour Inkjet...
50.0 fuser error
SOLUTION: Follow the steps listed below:
  1. Turn the printer off and unplug it for 30 minutes; then turn the power back on.
  2. Try a different power cord. DO NOT use extension cords to plug the printer in.
  3. Remove the surge protector or UPS/CVT device and connect the printer directly to a power source.
  4. Try a different electrical circuit. There could be an issue with the line voltage going into the printer from the power source.
  5. Turn the printer off and unplug it. Let it sit for 30 minutes to let the fuser cool off. Carefully remove the fuser; IT MAY STILL BE HOT USE CAUTION. Examine the fuser, if any damage is apparent the fuser may need to be replaced. If no damage is noted reinstall the fuser, plug the printer back in and power it up.
For More info Source... Hp Error Code 50 Service Errors 50 Fuser Printer Repair
Thanks,
HP Printer Support
Jun 26, 2014 | HP LaserJet Pro P1102
The printer is HP LaserJet III . Please - what means the message "50 service " on the panel ? Thank you! MP
A 50.4 code is bad line voltage. Don't plug it in a surge protector.
Any other 50 error is a fuser problem. Turn the printer off for at least 10 minutes. Power it back on. If the error returns, replace the fuser.
Oct 21, 2010 | HP LaserJet IIIp Printer
What does 50.2 fuser error mean
The 50.2 error means your fuser is not heating up. You will need to order either just the fuser HP Part # RG5-7060 or the maintenance kit HP part # Q1860-69002. Check your local computer store or we can ship the parts to you. If you need additional information contact me at our web site below.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 17, 2009 | HP LaserJet 5100tn Printer
HP Laserjet 5m, appear error code 50...please help.
Error 50 will be a faulty fuser unit or DC controller board. Try replacing the fuser unit.
May 20, 2009 | HP LaserJet 4m plus Printer
Fuser 50.1 error on HP 3500 printer
From HP Website:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
Mar 23, 2009 | HP Color LaserJet 3500 Printer
HPLaserjet4P - printer service 50 -
A 50 Service error is a fuser error. Turn the printer off for 5 to 10 minutes, then turn it back on. If the error is still there, I think your going to need to make a service call you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
Good Luck the HP Laserjet 4p is a great printer.
Jan 28, 2009 | HP LaserJet 4 plus Printer
ON AN HP LASERJET III PRINTER WHAT IS A '50 SERVICE ERROR'
The 50 SERVICE error means that either the fuser has not warmed up. It can be due to a bad fuser bulb, connections, or the power supply.
Reset the machine by leaving the power off for at least 15 minutes, if the error comes back after turning the printer on, you have parts that need to be replaced.
call an expert from HP to replace the parts :)
Sep 26, 2008 | Office Equipment & Supplies
Hello
A 50 Service error is a fuser error. Turn the printer off for at least 10 minutes, then turn it back on. If the error is still there, you can try reseating the fuser, but be sure to let the fuser cool completely before touching it.
If you still have the 50 Service error after reseating the fuser, you might need a new fuser.
You can access the fuser by opening the rear door. It's located directly above the paper tray. There are two screws that hold it in place. Remove those two screws, and the fuser slides outs.
Hope this helps.
Mar 20, 2008 | HP LaserJet 4 plus Printer
HP LaserJet 4700 Printer Logo
649 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
