Hi I have got problem with my laptopts.. its shows blue screen and displays starts windows normally? Can any one help me? Thank you tiontos
  • 629 Answers
Blue screen errors may indicate either a hardware problem or software. if this just recently happened, try restarting Windows, tap F8 a few times to enter Advanced Options Menu, then select Last Known-Good Configuration and press Enter. If this does not work, try the same steps to get to the Advanced Option again, select Safe Mode and press Enter. If this works, you may try system restore to a point before the issue started. If this does not even work, your next bet would be an OS repair or a reinstall of your OS.
Posted on Sep 30, 2010
My Dell mini Inspiron 10 shows a blue screen at startup
BSOD! blue screen of death....most common in windows vista, your gonna need to get into the recovery part of your computer on boot up, try to hit/hold f11 on boot up to get to system recovery tools
Jun 17, 2013 | Dell Inspiron Computers & Internet
Hi I have Dell inspiron 1720 (17 inches) laptop with intel centrino- window vista ultimate OS Problem: after system boots up, just before windows login, it comes "Please wait" and again it...
That's an interesting problem. It sounds like it's applying new display settings, but I'm not sure why it would do so over and over again. I would suggest trying to start Windows in "Safe Mode". To do that, as the computer is booting, hold down the F8 key to get the "Advanced Boot Options" menu. Maybe this will get you to a normal login screen. If so, you should try to change your display settings to the simplest possible and then reboot. I hope this helps.
Apr 10, 2011 | Dell Inspiron 1720 17" Widescreen...
Blue screen error
Hi
Just boot in safe mode or Last Good configuration and then go to windows START button there take MY COMPUTER>>ADVANCED>>START UP AND RECOVERY>> Disable memory dump here .Your blue screen problem will be solved
Thank U
Please rate me as it wil cost u just one click
Oct 23, 2009 | Acer Aspire 4315 Notebook
Dell Vostro 420 will not boot
If it is booting up to the second window, you might have to re-install your windows
Sep 16, 2009 | Dell Vostro 420 Desktop Computer
Wont get to the login screen no matter which option i click
If you are able to start the pc in safe mode, login as Administrator and restore the computer to a previous date when it was working fine.
When you turn on the computer in safe mode, it will show you the default user and Administrator. Click on Administrator to logon.
Then it will show you a screen which tell you that the windows is running in safe mode, press "No" on this message
You will be getting a system restore window. Follow the instruction for restore the windows to a date when the system was working fine,
After restore Reboot in normal mode
Aug 29, 2009 | Lenovo ThinkPad R61e Notebook
Pavilion ze4600 will not start
The blue screen that you see is what they call "the blue screen of death". The error that you have is Unmountable Boot Volume. This is caused by the operating system not being to load due to hard drive errors. This happens due to the computer being shutdown improperly or hard drive problem. I suggest that you contact the manufacturer of the computer so they can try and restore the computer without formatting or changing the hard drive.
Jun 10, 2009 | HP Pavilion dv6000z Notebook
I want to install windows xp on my acer 4230
Hi shaikh_shaha
Can you get it to boot using any of the options it gives other than boot normally? If the blue screen is caused by hardware then installing xp will still present the problem. If the blue screen is an operating system crash then using the recovery disk or doing a repair install will solve the boot problem.
If you still rather install xp then you need to go into BIOS and set 1st boot device as CD. To go into BIOS you will need to press F10 or F2 (usually) as displayed on the splash screen when you power on
Does this help?
May 02, 2009 | Acer Extensa 4620 Notebook
Amilo A1650G laptop display problem.
ur display memory is corrupted. normally it is a shared memory or a part of the main memory unless u r using the graphics card.
try take out the RAM, clean it and put it back and switch on.
if not helped this, try with a good RAM.
good luck
Please don't forget to rate or accept the solution
Jun 18, 2008 | Siemens Computers & Internet
Cannot display this video mode optimum resulotion 1280*1024 60hz
Chances are that the video driver for XP and 2003 differs (even if only slightly). You might want to start the 2003 in "Safe Mode" first to lower both the Screen Resolution and Screen Refresh Rate to the lowest possible. Thereafter do an update on the video card driver compatible with 2003 from the Dell.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 30, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
