Question about Philips bSure SV1 Multimedia Projector
My projector doesn't turn on? - Philips bSure SV1 Multimedia Projector
JVC DLA-RS1U Projector turns off
I have a similar problem. JVC Project (DLA-RS1) shuts off after about 30 min to 1 hour of use. Everything turns off - bulb, fan, even the little light on the projector near the buttons. After 10-15 min the red light comes back on and you can start the projector.
I have seen this happen when I had installed a knock-off bulb. I believe the bulb runs a little hotter and the projector over heats. Now I am seeing it happen even with a JVC bulb.
I am in the process of taking the cover off the projector to see if anything is blocking the air flow (like a piece of broken bulb, which did break a while back). If a problem doesn't show up there I am going to check the fan to see if it is turning at full speed (maybe replace with a beefier fan?).
Does anyone have instruction on dis-assembly?
Apr 17, 2012 | JVC DLA-RS1U Projector
3M SCP712 projector shuts down after an hour--can't turn back till it cools
Hello
the problem is with overheating. Look whether the cooling fan doesn't work or air filter is cloggy with dust. OK.
Nov 08, 2011 | 3M SCP712 Projector
My hd20 has a power-icon light of amber, when power button is pushed it goes to flashing green and it doesn't turn on, just flashes green
Have you tried decreasing the resolution of the computer?
When the resolution is too high for the projector, something similar to your description happens.
Oct 23, 2011 | Optoma HD20 DLP Projector
Epson PowerLite 410W projector (used for a smart board in a classroom) won't project anything or even turn on. Power button (maybe lamp indicator light? I don't really know anything about this...)...
It seems you assume that it is not an overheating problem.
The problem is, the bulb gets really, really hot when using the projector. It doesn't matter whether it has been there without any usage. As you switch it on, it will start to get hot.
But the lamp or other parts of the projector should not get too hot. To control the temperature, air is moved through the projector with the help of fans. Air enters through air filters and move through the projector absorbing heat from hot parts. This prevents these parts from getting overheated.
But what if air doesn't flow freely? Then the parts CAN get overheated.
First, switch on the projector and check whether you can hear the fans working.
Next, switch off the projector and remove power cable.
After about 30 minutes, remove the cover and check whether the air filters are blocked. If they are, clean them with a small brush.
This would probably solve your problem.
Sep 23, 2011 | Epson PowerLite 410W LCD Projector
My projector won't project anything. the computer recognizes the projector, but the projector does not recognize the computer. also when i turn on the projector the benq logo doesn't show.
Disconnect all inputs to the BENQ and power on. Do the lights come on as per normal operation. Does the lamp come on when the power button is pressed. Does anything show when the menu is selected.
Aug 19, 2011 | BenQ PB6240 Multimedia Projector
Projector doesn't turn off when I press the off button ....I have to disconnect the power cable to shut it down
All projectors take a bit of time to shut off, when pressing the power button it first shut off the lamp, than the fan runs for some time after to cool down the lamp, have you waited long enough??? if after a minute or two, if it is still running than try pressing the power button on the unit it self, it could be a defective remote as well.
Cheers!
Jun 29, 2011 | Epson EMP-6100 Projector
I just replaced the lamp, but the projector won't power up. It has 2 solid red lights
To resolve the issue, follow these steps:
1. Turn off the master power switch, disconnect the power cord, and then wait a short time.
2. Reconnect the power cord, and then turn on the master power switch. 3. If the previous steps don’t resolve the issue, the lamp might be at the end of its life. (double check that you get a good one lamp, and that are installed correctly)
4. If your projector still doesn’t turn on, turn off the master power switch, disconnect the power cord, and then contact your local repair shop for Fix the Board on the prjector
Mar 11, 2010 | Mitsubishi HC3000U Multimedia Projector
Cleaning my air filters
air flter is on the left of the projector; just click the plastic cover off and then vacuum the filter: if this doesn
Dec 10, 2008 | Hitachi CP-X275 Multimedia Projector
Red stripes during projection
Hi there
I promise you that it is not normal for your Projector to do this , so don't read too much into what is said about this problem.
Stripes of whatever nature on a Projector normally means there is a fault on your Mainboard. In which case it will need repair or replacement.
Warning : It is quite expensive !
Mar 02, 2008 | Epson EMP-S1H Multimedia Projector
Philips bSure SV1 Multimedia Projector Logo
56 people viewed this question
Top Philips Office Equipment & Supplies Experts
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
