Question about HP Pavilion dv7-1245dx Notebook
What are the expandable slot in my computer, there is one large slot and two small ones. i took the back cover off to see these.
  • HP Master
  • 11,800 Answers
The large one is for the memory, the small ones are for the bluetooth and card reader expansion cards.
Posted on Sep 30, 2010
Testimonial: "thank you "
How to remove a cover on a gateway E-6610D desktop computer
Unscrew a green large knob screw in the back, then the cover of the case should slide backwards. It will be tight because it fits snugly into place, but just push backwards and it will break free and reveal the insides to you.
Nov 28, 2014 | Gateway Computers & Internet
Plastic cover
How to remove back cover of ViewSonic G71F+. First remove the 3 screws at the bottom , one on each side and one above the VGA cable. Now look for three small slots on the top of the monitor near the screen. From the side opposite the screen insert 2 medium-small flat blade screwdrivers into the center slot and the slot on one side at an angle of about 25 degrees from the top plane of the monitor then gently pry up by pushing the screwdriver handles toward the top plane of the monitor. Once the plastic latch in the center and one side are released move the screwdriver on the side to the opposite side to release that side.
Mar 07, 2014 | ViewSonic Computers & Internet
Can not open the case on a emachine t1831
Remove ALL cords plugged into the computer. Lay the computer on it's side with indent facing up and remove two large thumb screws from back. Pull the side towards the back using the indent for leverage. If it is really stuck insert a small flat blade the in the slot between the front cover and side and CAREFULLY twist as you slide the blade from to bottom. The side needs to slide towards the back before it can be removed.
Jan 23, 2014 | Computers & Internet
How can i find memory slots for acer 5359 notbook?
the ram slots are usually underneath a cover on the bottom of the computer, however some manufacturers will also place expandable memory slots underneath the keyboard. Hope that helps you out.
Dec 15, 2011 | Acer Aspire Computers & Internet
How do I slide the green toner tabs?
1. power down the printer.
2. remove all color cartridges from their slots.
3. inside the color slot, you will see a green slide that will not move until you pick up the plastic cover (it is the full length of the cartridge holder).
4. rotate the plastic cover forward.
5. slide the green slide 3 or 4 times. (DO NOT TOUCH SMALL WIRES!)
6. return slide to original position.
7. snap the plastic cover back in place
8. return each color cartridge to it's slot.
9. replace color cartridge holder back to printer.
10. close all covers
11. turn printer back on.
If you still get the "move green slide" error, just repeat these steps
This took me about 10 minutes for the process, after understanding what the "green slide" meant.
Apr 20, 2011 | Brother HL-4040CN Laser Printer
My Dell Optiplex GX270 wont allow me load an OS on it. It gives me 'low battery voltage' error and unusually slow attempting to load xp but wont
This indicates that you need to replace your the computer's CMOS battery. To open your desktop follow the instructions below:
Opening the Computer Cover Dell? OptiPlex? GX270 Service Manual
caution.gif CAUTION: Before you begin any of the procedures in this section, follow the steps in "Safety Instructions."
  1. Shut down the computer through the Start menu.
  2. Ensure that your computer and attached devices are turned off. If your computer and attached devices did not automatically turn off when you shut down your computer, turn them off now.
notice.gif NOTICE: To disconnect a network cable, first unplug the cable from your computer and then unplug it from the network wall jack.
  1. Disconnect any telephone or telecommunication lines from the computer.
  2. Disconnect your computer and all attached devices from their electrical outlets, and then press the power button to ground the system board.
  3. Remove the computer stand, if it is attached.
caution.gif CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before opening the cover. notice.gif NOTICE: Ensure that there is sufficient space to support the open cover—at least 30 cm (1 ft) of desk top space. Small Form-Factor and Small Desktop Computers
  1. Locate the two release buttons shown in the illustration. Then press the two release buttons as you lift the cover.
notice.gif NOTICE: Open the cover slowly to ensure that you do not damage any cables.
  1. Raise the back of the cover, and pivot it toward the front of the computer.
Small Form-Factor Computer
security cable slot
padlock ring
release buttons (one on each side)
security cable slot
padlock ring
Small Mini-Tower Computer
  1. Lay the computer on its side as shown in the illustration.
  2. Open the cover:
    1. Facing the back of the computer, press the release button on the right side of the computer with one hand while pulling up on the top of the cover with the other hand.
    1. Press the release button on the left side of the computer with one hand while pulling up on the top of the cover with the other hand.
    2. Hold the bottom of the computer with one hand, and then pull open the cover with the other hand.
release buttons (2)
security cable slot
padlock ring
You will need to replace the one labeled No. 3 Below.
Aug 15, 2010 | Dell OptiPlex GX270 PC Desktop
Cant get the rear brake drums off
very tricky to adjust them down they do sv<k . Keep at it you need two tools a small screwdriver to move the spring out of the way and a brake adjuster tool to turn the star wheel.
Dont ever hit the outside rim of a drum it is now warped and deformed most likely unuseable now. Hit between the studs only. Also I recomend that if you are just checking them to have shoes ,hardware and wheel cylinders ready to be put ,in every caravan I work on needs everything replaced. Also this style of drum brakes is tricky it has two spreader bars and alot of springs. If you are not an experianced auto tech I would recomened you take it to one.
Apr 24, 2009 | 2000 Chrysler Town & Country
I can not get the metal slot cover off my IBM Thinkcentre
Takes some muscle and prying to get the tension lock to release back and free the slot covers.
Mar 30, 2009 | IBM Think Centre A50 P4 (841923u) Network...
I want to expand the RAM in my Gateway 500SE computer
GATEWAY 500SE Computer Case Cover Removal before installing RAM
  1. Turn off the computer and then disconnect the power cord.
  2. On the rear of the computer, remove the three screws that secure the cover on the case.
  3. Slide the cover back about one-half inch, and then lift it from the case.
  4. Search for a small scale like card in motherboard similar to small scale as shown in figure in BANK A or BANK B.
  5. And place the another ram in free bank slot (RAM Slot).
  6. Make sure the locks are correctly locked to RAM at both sides.
  7. Close the cover
  8. Power On the System
  9. If any beep sound then switch of the system and reinsert the RAM module.
Hope this will be helpful
Thanks & Regards
Nandu
Mar 25, 2009 | Gateway 22929 Notebook
I am trying to install a wireless pci card onto my acer m1100 desktop. I've installed the software first (as suggested) and am now trying to install the actual pci in the slot, but am not sure which slot...
On the back of your computer, there should be a bunch of covered slots. When you take off the cover of your computer, you should be able to unscrew these slot covers and remove them. Taking one off will give you a slot to install your wireless card. You will want the main plug part of the card to fit into one of the three large slots on your motherboard, and the side with the antenna will screw into the slot that you removed the cover for.
Jan 02, 2009 | Acer Aspire M1100-U1402A Refurbished AMD...
HP Pavilion dv7-1245dx Notebook Logo
93 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
