72 inch Mitsubishi Big Screen TV Model VS-6043, the problem is the television wont come on at all, I would like to konw exactly what the problem is so I can have a general idea of what I am looking at in repair costs.
    Sergeant:
    Champion:
  • 241 Answers
Your power supply " igniter " has gone bad.
have somebody with some electrical expertise to take a look at it, it may be the fuse that is located right after the power connection. i have replaced several of them, if that fuse is ok. the is your coil.
Posted on May 25, 2008
MyMitsubishi VS-6043 Big screen TV just started to black out while we were watching it.I would turn it off and back on the picture would be there. Now the power light goes on but the screen is black. Is...
Not sure on that one. My local repair guru tells me the 6043's are constantly having problems. I've got one that I'm looking for board parts for, so if you end up not wanting to fix yours, I'd love to get your board set for some parts.
Nov 11, 2009 | Mitsubishi VS-6043 60" Rear Projection...
Flyback
Some of these parts are no longer available. The manufacturers are only required (by law) to have replacement parts for 5 years. If the set is popular enough, some parts will be available generically. I will look up your model to get the part number and try to locate one for you.
Dan
Jul 01, 2008 | Mitsubishi VS-6043 60" Rear Projection...
How to adjust aspect ratio on Mitsubishi VS-6043 TV?
I have the same problem and the only thing I could do was to change the name of the input on your tv to pc on the menu screen and it should set it to 1080p reduced this will fit the whole picture and set your screen res on your computer to 1920x1080
hope this helps
Aug 01, 2009 | Mitsubishi VS-6043 60" Rear Projection...
52" mitsubishi rear projection tv model vs6051 sound no picture
Not exactly familiar with this model but sounds like the projector lamp is burned out. Hopefully it's a replaceable type. Try calling these people - http://www.purelandsupply.com
Mar 29, 2009 | Mitsubishi VS-60111 60" Rear Projection...
No picture
Sound like you lost Vertical Deflection.  Youshould not have a line across the screen because this could destroy the threeCRT Red, Green, and Blue (Picture tubes) if left on to long. There is a protection circuit built in to protect your CRT’s.    Check on the PCB-SIGNALboard (Tuner located on this board) transistors Q-206 Collector should be around 1 Volt Base and Emitter 0V. If the voltage atthis point is greater then 5 Volts the Vertical output IC-401 (Mounted on heat sink 7 pin inline IC) is bad, Part # LA7845.  Pin Voltages should be PIN 1= 0V, 2= 34V, 3= 32V, 4= 3V, 5= 3V, 6= 33v, 7= -6V.  Data sheet located at http://pdf1.alldatasheet.com/datasheet-pdf/view/40357/SANYO/LA7845.html
Jun 22, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Will vs-6043 parts interchange with vs-6061
What specifically are you looking to interchange?
May 20, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Mitsubishi VS-6043 - 60 inch
These are fairly simple, remove the speaker cover and then remove the screws at the bottom of the screen, then the whole thing lifts up and off, be sure to unplug the front panel controls, this plug can usaly be found just behind the cover behind the speaker grill
Feb 07, 2008 | Mitsubishi VS-6043 60" Rear Projection...
HOW TO RESET MY TV LOCK CODE
OPTION MENU "MENU 1370" SERVICE MENU "MENU 2357" CONVERGENCE MENU "MENU 2359"
Sep 20, 2007 | Mitsubishi VS-6043 60" Rear Projection...
Televison & Video Logo
643 people viewed this question
Top Televison & Video Experts
