Question about HP LaserJet M1522n MultiFunction Printer
When photocopying with my lazerjet, it prints a shadow of the document just above. This is especially noticeable when photocopying identification documents with a persons profile. What do I need to do?
  • 6 more comments
  • mstabell85 Oct 01, 2010
    I'm away from the office right now. I'll be back on Monday and will send that scan at that time.
    Thanks
    I've had a friend e-mail me a copy of a document that was photocopied. Unfortunately it is in a pdf file. Is there a way to attach it here or can I get an e-mail address to forwad that to you?
    Thanks again.
    Hey Tim;
    The shadow problem started about a month ago but was barely visible. It's been getting worse and worse since. Now every once in a while it will give a good copy but its less and less frequent.
  • mstabell85 Oct 05, 2010
    Hey nonontech;
    I can't find the "picture button. Can you send me your email address and I'll send a scan that way? Thanks.
    Mark
  • mstabell85 Oct 06, 2010
    Is there a way to upload pdf documents? I can't figure it out.
    Thanks
    Have you figured anything more out? It looks to me like the picture isn't so much giving a shadow as removing and moving some information out of the picture. It doesn't do it all the time and is sometimes worse than at others.
  • mstabell85 Oct 07, 2010
    Sorry! I was just wondering if you had come up with a solution regarding our photocopying problem.
  • mstabell85 Oct 09, 2010
    Hey all FixYa staff;
    Thank you all for your help. I know it was a duzy. We were able to figure out the problem on our end. It ended up being that our power supply was to strong. We are working off of solar power and an inverter here in Mozambique and the inverter was putting out 260V instead of the 220V it was supposed to put it. We are now running the photocopier off of another power source and it has fixed the problem.
    Thank you for your advice and intput.
    Mark
  • HP Master
  • 4,737 Answers
Please clarify, I have some doubts, What if you print documents from the computer? or What if you scan? Is the problem only with Copy?. If possible, please upload a copy of the document (scan the photocopied document and upload here through "Picture" button). That will help a lot in identifying the cause so that we can troubleshoot and fix it.
Thanks and awaiting.
Posted on Oct 02, 2010
  • Lebanon Raingam
    Lebanon Raingam Oct 05, 2010
    Sorry, we are not allowed to post our personal info like email add or phone number here.. Once you click the "Add a comment" you should see the comment box similar to this (Please note: There must be two "Add a comment" tabs, one at the beginning of the posts and another at the end of the posts.)
    For free questions, there isn't, but as your request is Premium, you should see that. If you still have problem, you better post the scanned photo on a free picture sharing website and give me the link...
    You can upload the picture on Tinypic.com and give me the link/s (click here), when you open the link, you'll see the menus on the website similar to this:
    Choose the file, give a Tag.. and click "Upload Now", once upload is completed, you'll get all the links, [shown below]:
    Send me the last link "Direct Link for Layouts".
    Good luck.
  • Lebanon Raingam
    Lebanon Raingam Oct 06, 2010
    Ok.. we have no choice, and even if I give you the free file hosting site, you'll be having difficulty doing the same. Well, send me the scanned Pdf file/s here... nonontech at gmail dot com. I hope you'll get what I mean. Thanks.
  • 1,110 Answers
I have seen this problem be caused by 1 of 2 things. 1 is an easy fix, the other a bit more trouble. This first and easiest solution is to change out the toner cartridge. The problem you are describing is called ghosting or double imaging. Try a new or even used toner cartridge if you have one available and see if the problem goes away. If it does then great, you had the easy fix. If changing the toner does not resolve the issue then the problem lies with your fusing unit. The fuser film, which is a non stick film, starts to go bad in the fuser and a bit of toner starts to stick to it and then is re-applied in a much lighter form farther down the page. So that something that is printed at the top of the page is printed lighter farther down. If this seems to be the case then you can either have someone replace the fuser film only, or have the fuser unit replaced as a whole. In most all cases I replace just the fuser film for my customers. This is quite a bit cheaper at about $150 for parts and labor than the $300 plus that you would spend for a new unit. Unless the machine is very heavily used the rest of the fusing unit is fine and does not need to be replaced.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Oct 01, 2010
    President:
  • 2,777 Answers
Is it possible scan a document you have the shadow on and post it here in the question? I am trying to picture exactly what you mean.. "a shadow of the document just above". Not exactly sure what that would mean, but I think I can help get it straightened out.
Thanks
Tim
Posted on Sep 30, 2010
  • 3 more comments
  • Tim Grayson
    Tim Grayson Oct 01, 2010
    Sounds good! Thanks
    Tim
  • Tim Grayson
    Sure thing, email it over to me at microtechftp@yahoo.com
    Thanks
    Tim
  • Tim Grayson
    Tim Grayson Oct 06, 2010
    Upload documents, you mean on the fixya site here? Or what do you mean exactly?
  • Tim Grayson
    Tim Grayson Oct 07, 2010
    I never saw a reply to the PDF documents question... you asked if you can upload a PDF? Please email whatever it is to me you have at microtechftp@yahoo.com
    Thanks
    Tim
  • Tim Grayson
    Tim Grayson Oct 09, 2010
    Glad to hear it for sure! If possible please come back to the question here and click the Accept
    This Solution button, otherwise I don't get credit for the help
    provided.
    Thank you so much,
    Tim
Rulling line in my photocopy document
hi try to print if the line are the then you need to change the drum and the clean blade
Oct 16, 2015 | Sharp AR-275 Copier
I have Canon ImageClass MF5750 and been having problem with paper size issue.it usually stop printing or photocopying and ask me to check paper setting even though the setting is looks okay(paper size
Make sure that the document you print is set to A4 or Letter, dependent upon the printer setup. If you try to print to the wrong size of paper, the printer will stop.
Feb 11, 2015 | Canon imageCLASS MF5750 All-In-One Laser...
When I am photocopying and scanning documents I am noticing vertical lines on the print in the middle of the page which is ruining the copy, any ideas? Alos message intermittently coming up waste toner...
Most probably you are using the automating document feeder for the photocopy or scanning. If you can lift up the document feeder , there should be the mirror where you can put the original document for manual photocopy or scan. Clean the edges of the mirror with a printer cleaning liquid. There may be some foreign particle stuck there or it is just dirty from long use. Hope this helps.
Sep 02, 2011 | Office Equipment & Supplies
Cannot photocopy document
hi...
the colour catridge has nothing to do with the black and white print out if it is a text document. please check you have placed the black catridge propely and in correct positon. and try printing out the pages
Jul 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
Picture has a red shadow. especially
Convergence problem on rear projection CRT TVs.
Apr 19, 2010 | Televison & Video
Can i use my DCP 130C machine for photocopying? for small business. meaning iwill frequently use my machine for photocopying. would it be okey?What could be a posible problem in the future if there's any
You may use this a copier but usually, all in one printers used as copier take a long time to produce print outs. It isn't as robust as It usually scans the pages first (duration is the same as scanning a document) then prints it out (duration is the same as printing a document from a PC).
In my experience with our multifunction printer, a single page can be photocopied in about 45 seconds to 1 minute. It isn't as robust as photocopying machines.
Jun 25, 2009 | Brother DCP 130C All-In-One InkJet Printer
Canon IR7105 Photocopier
Hello tophams,
I wish I had a magic wand to help you...but the answer is YES! You can fully control the priorities of how the 7105 handles printing/copying/scannng requests. I truly understand your dilemma, it is merely a matter of how the device has been configured. You can program the device to give priority to copies, which will cause print jobs to wait in the que until your copies are done. You can have the print jobs sent to a "mailbox" so that the person requesting a print job will have to walk up to the device and "summon" their print job. There are so many ways to help you with this. You will have to get "THE BOOK" out. I can't type all of the options available to you.
Jul 03, 2008 | Canon NP 6551 Black and White Copier
Poor print quality
the shadow-like copy of text is definitely coming from a faulty tone cartridge, replace it and you will have your solution,
the verical lines are caused by a dirty optical lens which is located under the keypad, just lift that up and you will see a glass bar that is likely dirty, clean it well and this should solve this problem as well
Jun 13, 2008 | HP LaserJet 3015 All-In-One Printer
Photocopier prints red
You might be running low on black ink and it's not an item when you print from your computer because the settings you are calling for are different. The computer asks you if you want to print normal...to best, etc.
Apr 25, 2008 | Dell 924 All-in-One InkJet Printer
HP LaserJet M1522n MultiFunction Printer Logo
63 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
