I recently bought a second hand Hitachi tv (Model C1415T) but can't work out how to tune in the channels!! Help!
  • bigalexwh May 27, 2008
    That's just great service mate! Problem solved 100%
    Sergeant:
    Champion:
  • 241 Answers
Posted on May 25, 2008
Without remote how do I set in on channel 3, the channel button of front of TV only goes from 95 to 99 and back again.
you will need the remote to do a channel search or manually reprogram the tuner to tune in ch3
A good place to fine cheep factory remotes is on e bay. enter your model and make, only buy factory remotes not universal .
Factory remotes can do things a universal one cannot.
Jan 23, 2016 | Televison & Video
Hi I have bought acoustics solutions tv second hand model LCD26805HD I cannot retune it can anyone please advise? Thank you
You need the (original correct) remote. Alternatively, you can use a programmable remote, but the ''menu'' must also be compatible with the TV. If you cannot ''navigate'' the Menu and Settings with the remote, you are stuck without a solution. // With the remote you enter the menu ''settings'' and then enter ''channel tuning.'' Then set for either ''manual tuning'' or (best bet) set for ''auto-tuning.''
Jan 01, 2015 | Televison & Video
How do I tune my hitachi tv. I got it as second hand.
Make sure the cable is plugged into it, or if you're using antenna, make sure the antenna is plugged in. Go to your T.V. menu and there should be an option for channels or programming. After you get into one of those you should have the option to program channels from cable or antenna/air. Also, depending on what model it is and if you're not using digital cable or satellite, then you may need a digital converter box. If you have the model number I can tell you if you need a digital tuner.
May 03, 2011 | Televison & Video
I've just bought a second hand B20V3TS television, it picks up channel 5 but the rest of the channels are not tuned in. How do I adjust the tracking?
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
This will help you understand the workings of this TV both now and in the future
I hope this helps.
Mar 19, 2011 | Daewoo Televison & Video
I bought a second hand philips tv 29ht2212/79r and have tuned in the channels via the interaction menu using 3 1 9 7 5 3 mute on remote and the sound wont work now. is there something i have to enter to...
open the cover of your tv look for the sound IF using a plastic precesion screw driver adjust the IF counter clock wise slowly untill you reach a good sound or clockwise...if nothong happen solder a 0.2 ceramic capacitor to your sound IF at the coil of the IF under the board the IF has two terminals for the coil.sound if is located near the tuner section..there are two IF the video I.F and sound I.F
May 20, 2010 | Televison & Video
Hitachi ultravision model number 42hds69 cable problem.
Usually you need a decoder to receive "Cable" With your "Cable" usually you connect the Cable antenna, to the Cable "Box" form the "Box" to the Audio Visual EXTERNAL inputs, in the back of the TV. Now IF your TV can receive the "Cable" directly, then you would have to connect the Antenna, into the rear of the TV, now you would go to the "Tuning" section, and, the TV, would automatically "Search" for any available channels. They would then, be displayed at the end of the scan. Please find a user manual below, this will help you tune in, IF you can. If you cannot, you will have to get a cab;e "Box" and a remote. Hookup to the TV, from the "Box" to the TV, via, Audio and Video cables. You use the "Box's" remote to change channels and volume. You first must set the TV's Volume, & picture setting, the TV, is basically just used as a "Monitor" for the "Box". Hope this helps..
http://tv.manualsonline.com/manuals/mfg/hitachi/42hds69_55hds69.html
Apr 23, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Manual tuning of Hitachi cle-942 tv
Select the channel to tune & press "CH" this is the key to the right of zero on the CLE-942 remote, Now you can tune the selected channel. You also need this key to sort/move channels after running auto tune.
Aug 20, 2009 | Hitachi HL01453 Remote Control
TV/DVD Combo will not switch back to live TV when DVD is ejected.
I had the same problem with the same unit when I first bought it a few months ago.
First up remove the DVD. If the TV stations do not appear within a couple of seconds press the "TV" button (top, second from left) on your remote control.
Let me know if this doesn't work.
Apr 28, 2009 | LG 26LG30 26 in. LCD TV
Cant tune my Hitachi TV
please check web site for any thing in remote. www.remotes.com and give model name in search. hopr this will help. good luck.
Sep 30, 2007 | Televison & Video
RPTV PROBLEM
If you already tryed to change the AFC mode for the tuning ,thats the cable mode the TV's in, then your Microprocessor, tuning ic,or the tuner is defective.
Aug 19, 2006 | Hitachi 43FDX01B TV
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
