Question about HP OfficeJet 4315 All-In-One InkJet Printer
Printer wont print. in the printer folder. It says outbind://d228e32b65a8ea469e30712202a875730644b2300
  • HP Master
  • 17,130 Answers
Try to have a reset .Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command .If the reset wont help it can be the printing head or a mother board error.
Posted on Sep 30, 2010
Mg6150 wont print in colour
Make sure that u have made this the default printer first. Then go to start control panel then printers folder. See if there are other printer listed . THen right clk on this one go down to properties. Make sure it is config for color not blk white..then hit test print button..see if it comes out.
Check the printer setup to..might need to update firmware.
Good luck
chadman
Dec 24, 2013 | Microsoft Computers & Internet
Lexmark x1150 wont print text but will print pictures
In this case what i would Request u to do is.........
Goto Control Panel goto Printers folder.........
There u will see the Lexmark Printer Icon...........
Just right click on the Printer Icon and click on Properties.........
Now click on Advanced and goto Print Processor.........
Change it to Lexmark NTEMF 1.0008........
Click on Apply click Ok now try to Print..........
Prints Fine............Issue Resolved........
Same Problem........
Download the Lexmark ToolBar from:
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1255995709_0_en,00.html
Restart your computer once and now try to print using the Lexmark Tool Bar..........
It should work fine........
Good Luck..............
Apr 18, 2013 | Lexmark X1150 All-In-One InkJet Printer
When i try to uninstall my lexmark x1190 it comes up printing not finished
Try to clear the Lexmark print queue from pending/stuck print jobs so you can successfully uninstall the Lexmark software/ printer driver. Here's how:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
After successfully clearing the print queue, uninstall the printer software by going to Start menu > Programs > Lexmark 1100 Series folder > Tools > Uninstall. Reboot your pc when prompted.
Hope this helps.
Apr 30, 2012 | Lexmark X1190 All-In-One InkJet Printer
Even since we install the edimax server, the printer will just halt and we have to reset the spooler again
Setting the location of the spool folder By default the spool folder is located at systemroot\System32\Spool\Printers. However, this drive also holds the Windows system files. Because these files are frequently accessed by the operating system, performance of both Windows and the printing functions might be slowed.
If your print server serves only one or two printers with low traffic volumes, the default location of the spool folder is sufficient. However, for high-volume printing requirements, to support large numbers of printers, or to support large print jobs, you should relocate the spool folder. For best results, move the spool folder to a drive that has its own controller, which reduces printing's impact on the rest of the operating system.
For information on relocating the print server spool folder, see Change the spool folder location.
To set up a printer to print to multiple devices
  1. Open Printers and Faxes.
  2. Right-click the printer you are using, and then click Properties.
  3. On the Ports tab, select the Enable printer pooling check box.
  4. Click each port where the printers you want to pool are connected.
Notes
  • To open Printers and Faxes, click Start, and then click Printers and Faxes.
  • With printer pooling, the printers must be the same type of printer using the same printer driver.
  • The previous procedure assumes the printers you want to pool are already in the Printers and Faxes folder.
  • Check for print jobs in que,this can cause the printer to spool if a print job is in que.
Dec 09, 2010 | Edimax PS-3103P (ps-3103p) Print Server
Wont print in color only black.
go to printers folder in start menu or control panel, right click properties for this printer or in the print window popup click on advanced tab and click print color button or print quality not sure exactly where but its in there.
Oct 09, 2010 | Lexmark X2500 All-In-One Printer
Prints one or two lines & then stops & says "outbind" error
Hi lhessel,
The best solution is to contact Cannon on the net, ask for tech support and download any updates available for your printer (make sure they are for the operating system you are using, i.e. Windows XP Home or Professional Version, Windows Vista).
Marge48
May 20, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Printer wont print
open up the printer folder in your computer and then cancel the pending documents after that open SERVICES.MSC that u can easily find searching in your computer and after that look for print spooler restert that service 3-4 times and then restart your computer after that try and print if this oes not help leave a message i have a solution for that as well
Dec 31, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Why will my printer print from the internet but wont print an email?
Is your printer set up correctly, when you print form e mail, look a the page propertied..
Clcik File, Print, a window should pop up make sure you select the correct printer to printer..
Or opent the controol panel, open the printers and faxxes folder..
Make sure the printer is set as the Deafault Printer... Right click on it, select "Set As Default"
Nov 04, 2008 | Office Equipment & Supplies
I cannot print but i can scan
Solution:-
Step one: - Restart the computer
Click Start and click Shut Down.
Click Restart or select Restart from the menu.
Click OK.
After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved.
If the issue continues, proceed to the next step.
Step two: - Check the product cable
Disconnect the USB cable from the product and from the computer.
Wait 5 to 6 seconds.
Reconnect the USB cable to the product and computer.
After the product is connected to the computer, the product should start printing the jobs in the print queue.
Step three: - Determine whether the product is paused or offline
Click Start and click Printers and Faxes. The Printers and Faxes window appears.
In the Printers and Faxes window, right-click the product icon and click Open . The Printers folder opens.
On the menu bar, click Printer.
Make sure that the Pause Printing and Use Printer Offline options are not selected. If a check mark appears next to either option, click to remove it.
If the menu includes Use Printer Online , click that option.
If neither Pause Printing nor Use Printer Offline is selected, press Esc to leave the menu without making changes.
Step four: - Stop the print queue
Double-click Macintosh HD.
Double-click the Application/Utilities folder.
Open the Print Setup Utility folder.
Double-click the appropriate product in the product list to open the print queue.
Click Start Jobs.
Step five: - Delete the print jobs
Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue.
Click Start Jobs.
When the print queue is empty, click Start Jobs.
Try the print job again.
Step six: - Remove and re-add the product to the printer list
Select the appropriate product.
Click the red X to delete the product from the computer.
Disconnect the USB or Ethernet cable from the product.
Close all open windows and restart the computer.
After the computer is restarted, double-click Macintosh HD .
Reconnect the USB or Ethernet cable to the product.
If the product is not automatically added, click Add.
Select the product to add and click the Add button. After a few seconds, the product appears in the printer list. Try the print job again.
Jul 09, 2008 | HP DeskJet F380 All-In-One Printer
Printer locks up
  1. Click Start, Printers and Faxes and double-click on the Lexmark printer driver.
  2. Open the Printer menu and select Cancel All Documents. This will purge the print queue so as to allow the printer to print or uninstall the driver.
  3. If the print jobs are not removed from the queue, click Start, Run, type Net Stop Spooler, and press ENTER.
  4. Click Start, Shutdown, and select Restart. The documents or the print jobs should be removed.
If you are having difficulty deleting the print jobs in the printer spooler, do the following:
  1. Restart the PC in "safe mode". To do this:
    1. Click Start, Shut Down and select Restart.
    2. While the PC is restarting, press the F8 key on the keyboard. Note: Do not hold down the key down, but be aware that you may need to press it several times.
  2. When in safe mode, click Start, My Computer.
  3. Double-click on the (C:) drive.
  4. Double-click on the Windows folder.
  5. Double-click on the System32 folder.
  6. Double-click on the Spool folder.
  7. Double-click on the Printers folder.
  8. Select the contents of this folder and click Delete.
Mar 22, 2008 | Lexmark X3480 All-In-One Printer
HP OfficeJet 4315 All-In-One InkJet Printer Logo
74 people viewed this question
Seeker5211
Seeker5211
