Question about LG DLE2532W Electric Dryer
My dryer has water coming from under it every time I dry towels, I mean a lot of water, why is that. I was wondering if my washer was nit spinning out towels enough. also the dryer gets so hot it makers my laundry room very warm.
    Problem Solver:
  • 15 Answers
You vent line is likely clogged or is too long or not connected at all and your dryer is venting directly into the room
Posted on Oct 01, 2010
Have a WDL540 can you explain the symbols on the right hand side of the machine has mins and other symbols. Don't have an instruction book. A wash takes 2 hours at 40 degrees its too long.
Do you mean a Hotpoint Aquarius WDL 540 washer? The wash cycle timing is available in the manual on page 8 of the manual (see link below). A normal-sized cottons wash at 40 degrees C takes about 150 minutes (2 1/5 hours) if you have good water pressure and do not use too much detergent. The coloreds cycle is shorter (just under 90 minutes). The indicator lights on the very right hand side (in a downward slash pattern) give the cycle status information. The top light is wash, and the next one down is rinse. The rest are Spin, Dry and End of Cycle. See page 7 of the manual. The function buttons, below the wash temperature and drying time/humidity selection knobs, are from left to right: Super Wash, Extra Rinse, Mini Load, Slow Spin. These are given on page 9. The dryer dial gives you the choice of selecting a dry time from 40-180 minutes or by humidity. The humidity options are Iron (leaves clothes slightly damp), Hanger (ready to put away) and Cupboard (to dry heavy items like towels to a very dry stage). Note the dryer can't manage as large a load as the washer function does. You may need to split the load after doing the wash.
The manual for the WDL 540 is available on the product page: https://www.hotpoint.co.uk/appliances-1/washer-dryers-3/hotpoint-aquarius-wdl-540-p-.c-washer-dryer-white/F064656/ . The picture of the washer shows the function buttons when you zoom in on the control panel. The direct link to the manual is http://docs.hotpoint.eu/_doc/19512781900_GB.pdf .
I hope this helps.
Feb 02, 2018 | Washing Machines
Why do I have to dry stuff twice.?
A lot of times when your dryer doesn't dry your clothes ,the problem is with the washer not spinning properly. Then there is too much water left in the clothes so the dryer can't remove it all.
Jul 04, 2014 | Whirlpool GEQ8858J Dryer
Troubleshoot
air flow also required. if temp is coming up inside (120'+) look for bent duct out back, flapper stuck. blocked lint or foreign material, air flow holes blocked. assuming your drying other than like towel and your washer is spinning out water ok.
if helpful please rate me. if not please tell me more.
Mar 03, 2012 | Dryers
Water is coming out from under my machine during spin cycle. LOTS of water. I'm going to check my drain hose, but wonder if I need to take off the front of the washer?
No, you do not need to take off the front of the washer. This usually means a drain hose or the drain itself is clogged up or backed up. When the tub spins the water will naturally go over the top of the tub and splash out.
Jul 31, 2009 | Washing Machines
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
DRY TIME IS VERY EXCESSIVE
Excessive drying time can be caused by a number of things.
Is the vent clear of obstructions? If not then the vent and ducting will have to be cleaned. This ch be checked by removing the vent hos from the back of the machine and testing the dry time with a small load of a couple of towels.
Is the temperature hot inside of the dryer? If not then the heating element may have a problem.
Is the washer spinning most of the water out of the clothes? If not then the dryer is overworking to remove the water.
Is the dryer fairly old or was it a "scratch and dent" floor model? Then there may not be an adequate seal around the dryer drum and a lot of drying potential is lost.
Is there lint build up in the blower or is the blower not spinning? This cause the air to not circulate. It can be checked by removing the rear duct hose and running the machine.
Jul 28, 2008 | Maytag Dryers
Broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Jan 07, 2008 | Kenmore Elite 45986 Front Load Washer
"CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Sep 01, 2007 | LG WM-3677HW Front Load Washer / Dryer
Clothes Hot but damp, water out of vent
Is this a combo washer/dryer in 1 unit? water shoud not come out if it is just a dryer. Your air coming out of the back vent hose should be hot. If your clothes comes out of your WASHER damp (more than normal) then your washer is not spin drying good enough. (worn belt, clogged drainage system).
Jan 09, 2007 | LG DLE2532W Electric Dryer
LG DLE2532W Electric Dryer Logo
126 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
