Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
Shutter does not close. Camera turns itself off.
  • reuben24 Sep 30, 2010
    Tried it a bunch of times and it didn't work. Got any other suggestions?
    Thank you. I tried it several times and eventually got it to close. Then when I turned it on again, it worked. I also blew softly into the area so perhaps something was blown out of the area.
    Must say I was not optimistic. Thank you very much.
    President:
  • 2,185 Answers
There is probably a grit of sand or residue jamming the lens barrel and this caused the system to recognize it as a fault and turns itself off. Here is what you try to do. Make sure you have loaded a freshly charged battery. Hold your camera with your right hand with its lens facing the ground. Now, tap the camera's base to your left palm as your press the ON button of the camera to power it on. You may have to do this several times with the idea of removing the grit off the lens barrel.
Please let me know how this goes so that I could give you other solutions.
Posted on Sep 30, 2010
  • virtualhost
    virtualhost Sep 30, 2010
    If that camera is no longer under warranty, then you can try to twist and gently push the lens barrel while turning the camera on. Are you sure the battery is fully charged?
My Kodak Easyshare M580 works but the shutter will not go in all the way when turned off? Starts to go in then stops.
The problem is in the shutter itself, I would use it until it go's completely, it would cost as much if not more to have it repaired, chances are they would replace the whole lens housing.
Mar 13, 2012 | Kodak Easyshare M580 Digital Camera
My Kodak Easyshare V1223 turns on and shows all icons normally on the view screen as well as older pictures on the memory card...but shows everything else black and pictures remain black even with flash...
Hi!
It is not necessary something wrong with the camera itself. Sometimes the simptom is caused by the memory card. Reading from it works (so you can see older pictures) but every new picture is written wrong, so the camera shows only black.
Hope it is only the memory card in your case.
Good luck,
Bogdan
Aug 28, 2011 | Kodak EASYSHARE V1253 Digital Camera
When trying to turn the camera on, the lens will not extend fully. it extends partially, and then the camera turns itself off, leaving the lens in the partially extended position. you have to try and turn...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 23, 2011 | FUJIFILM FinePix JX250 Digital Camera
When I try to take a picture you hear a clicking noise and the flash is working but it will not take a picture
You may be too close to your subject and the autofocus is not locking in. back up a few inches and the shutter should go off. Try turning off auto-focus.
If this isn't the case it could be a shutter problem. Turn off the flash (if you don't you'll get blinded during my next step) look inside the barrel of the lens and click the shutter...you should see a little flicker inside the lens as you hit the shutter button. If you do see it, then it is in fact just the shutter...if not it's the camera itself. Be sure you are holding the shutter button down completely...as halfway only allows you o focus.
Nov 28, 2010 | Nikon D40x Digital Camera
Screen is black- will function but can not see images
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Aug 10, 2010 | Canon PowerShot S2 IS Digital Camera
Canon A620 is taking black images/ Can't see images on screen
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't fix it... A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 28, 2010 | Canon PowerShot A620 Digital Camera
When i turn on the camera the shutter closes, when I turn it off, the shutter opens
I dropped the camera and now the shutter opens when turning off & closes when I open the camera. But when it is open, the shutter will open a bit making it impossible to take pictures. What should I do or where do I take it for repairs?
Tks, Ruth
Sep 11, 2009 | Sanyo VPC-S500 Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
Shutter will not close back to starting position with each shot
cablechick25,
do you mean the shutter doesn't close all the way? put select on B , gently push shutter to the left to fully close the shutter. charge shutter and fire it a few times, it should free itself after a few shots.
any mechanical device needs a periodic clean, lube & adjust, ( CLA ), after not being used for 5 years your X350 just needs that. take it or send to a camera repair shop for an estimate first. there are no new parts available for this model minolta.
Jan 23, 2009 | Minolta X-370S 35mm SLR Camera
The camera shutter is always open
Plecs can you send me k750i Camera solution (with photos)
Oct 28, 2008 | Sony Ericsson K750
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
231 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
