Question about Marvel 61WC Wine Cooler
Need t-stat for 61wcma/2898059 marvel wine cooler THANKS!!
aborcass
  • 2651 Answers
SOURCE: Marvel 61WC Wine Cooler
sorry for the delay in response time you definatly have a bad thermistor, not able to stabilze temp so it contionues run never shutting doen freezing everything, who ever repairs it (if they haven already,)make sure they put all 3 new peices in, thermistor, potentiometer, and contol box. all 3 come in one kit, 20 min to install
Posted on Mar 01, 2008
Krazytech
  • 725 Answers
SOURCE: Marvel model 61WC Wine cooler
first do you have power to the compressor? if not it could be a control... if you do it could be a relay...let me know and I can help
Posted on Sep 01, 2008
  • 51 Answers
SOURCE: frost is building in wine cooler
Check the door seals to make sure they are sealing good this can cause high humidity. The unit also seems to be getting to cold check with another thermometer
Posted on Sep 08, 2008
  • 101 Answers
SOURCE: Marvel wine refrigerator running,but not cooling
If your unit runs but does not cool, you have a "sealed system" issue. Either you are low on refrigerant which would be evident by frost build-up near the area where the freon first enters the evaporator plate. (lower middle, then travels left) or the compressor has lost the ability to develop the necessary differential pressure. You do not want to run the unit like that...you can **** in contaminants that will harm the compressor if you already haven't. You should contact a servicer to get it repaired. If you are still within the warranty period you should contact the dealer you got it from to initiate service.
Posted on Sep 15, 2009
  • 101 Answers
SOURCE: I have a client with a ten year old Marvel 24
Dear Dereck,
Does your client have any idea how old the unit is? What do you mean by "weather stripping"? If you need a door gasket, all their 24" wide units (except ADA height) use the same gaskets. Part number 42241280 for the white and 42243906 for the black. You can order direct from the factory at 800-223-3900 (they are in EST in Michigan) should you need something else, describe the unit to their customer service personnel and they should be able to assist you. (Ask for Tim or Ron) - Subdriver
Posted on Feb 03, 2010
What freon is in marvel wine cooler 61 WCMA
Don't know, but their should be a label on or near the compressor that tells you.
Mar 01, 2015 | Marvel (6SBARBSG) Wine Cooler
Marvel 6BAR6004 not cooling
check you themoistat it may be coated with sofa
Jul 04, 2014 | Marvel 61WC Wine Cooler
Replace marvel wc30 thermostat
Are you looking for instructions how to replace the stat, where you can get one or who can do it for you?
With either question I would need to know the full model/serial number.
If it was made before 2001 it will have an electric-mechanical stat which to my knowledge may no-longer be available. The electronic stat used 2001 to 2007/8 is still available as well as an upgrade kit to replace the old style. You can call the factory at 800-223-3900 and ask for customer service. Ask for Tim Malloy or Ron Peterson. They will know if they still have the old style stat (easier to replace and cheaper) or if you require the SSAC control or the upgrade kit. Make sure you have the full model/serial number when you call. If you cannot locate the serial number reply back and I'll give you guidance how to determine which control you have.
The factory can also refer you to a servicer in your area. If you need to do it yourself, reply back with what control you have and what you purchased and I'll help you get it installed correctly. Good-luck, Subdriver
Feb 16, 2010 | Marvel (6SBARBSG) Wine Cooler
Marvel 61wc wine cooler turns on, but doesn't cool
If you can hear the compressor running and there is no cooling happening your unit has either lost it's refrigerant due to a leak or the compressor is completly worn out (or both). If you just hear the condenser fan running (air blowing), then maybe the compressor just has bad electricals (starting relay, overoad, run capactor) or it has developed a bad winding and will need to be replaced.
If you know you have lost refrigerant the repair will be quite costly and you should consider replacement. If you feel it is a failure of the small electrical parts for the compressor, repair would be more cost effective.
You can get further trouble-shooting assistance and order parts direct from the factory at 800-223-3900.
You can look up a local servicer on their web-site at www.lifeluxurymarvel.com
Should you desire to attempt electrical repair yourself, reply to me and I will provide further troubleshooting assistance or you can contact Marvel Customer Service at the number above. Good-Luck, Subdriver
Jan 28, 2010 | Marvel 61WC Wine Cooler
61WCMA\071800080
Yes, you can purchase a new thermostat from the factory by calling 800-223-3900. Since your unit was built during the year they were switching from electro-mechanical to solid state you will need to know which one you have when you call. They can help you determine which one it is. The electro-mechanical will have an aluminum sensing line exiting the back of the stat (connected to the temperature control dial) and two individual wires. (may also have a green ground). The solid state consists of three parts: Control Board (located in the rear near the compressor), thermistor (located on the right side of the evaporator plate and connected to terminals 4 and 5 of the control board) and potentiometer (attached to the control knob and has wires connected to terminals 6 and 7 of the control board). You most likely have the solid state control.
I hope this helps.
Jan 03, 2010 | Marvel (6SBARBSG) Wine Cooler
Temperature control does not work. Unit freezes everything no matter where the temperature control is set (Marvel Wine Refrigerator)
Either the thermostat itself is bad, or the relay is sticking. If you break the connection between the T-stat and the relay, and it keeps runnning, the problem is the relay.
If the compressor stops running when you break the connection or disconnect the T-stat, then the T-stat needs to be replaced.
Oct 12, 2009 | Marvel (6SBARBSG) Wine Cooler
My light for my marvel wine fridge will not turn off?
There is also a light override ON/OFF button next to the door switch to allow the light to remain on for display setups. Make sure that switch is off. If it is off, then your door switch must be shorted out and should be replaced.
Jun 18, 2009 | Marvel (6SBARBSG) Wine Cooler
Frost is building in wine cooler
Sep 05, 2008 | Marvel (6SBARBSG) Wine Cooler
Marvel Cooler/Fridge Light Not Working
It sounds like the bulb is not getting power. There is a door switch that turns it off when the door closes...this may be stuck. There is usually an optional (depending on age) ON/OFF switch that overrides the light to be on full time. If the light will also not turn on with that switch then there must be a disconnected or broken wire either going to the light switches or going to the light socket from the switches. I hope this helps.
Aug 30, 2008 | Marvel (6SBARBSG) Wine Cooler
Dec 02, 2007 | Marvel 61WC Wine Cooler
Marvel 61WC Wine Cooler Logo
66 people viewed this question
Top Marvel Furniture Experts
Sal De
Charles T Nevin
Charles T Nevin
Joseph Hoffmann
Are you a Marvel Furniture Expert? Answer questions, earn points and help others
