Water is dripping from the AC. - Heating & Cooling
  • 43,501 Answers
For a competent expert to be able to answer your problem, you will need to give a specific make and model of your unit.
Also include as much as possible about what you have already tried to do to resolve the problem along with exactly what is not working or what the unit is not doing that it is supposed to do.
This will help us experts to be able to give you the correct advise the first time, without having to guess so much as to what is actually happening.
Thank you!
heatman101
Posted on Sep 30, 2010
2008 Toyota Tacoma V6 Would the AC drain hose drip water onto the frame even if the AC was not used?
If there was a partial blockage in the drain at the ac box it is possible that water will still drip out over time . However some Toyota ac units use the same box for the heater core so I would be looking for a coolant leak in that area . Check coolant level and have a pressure test done on the coolant system to check for the leak. If the drain is in the frame under the car ,the water may be also from the windscreen plenum chamber that collects water from the windscreen and drains in that area.
May 23, 2014 | 2008 Toyota Tacoma
AC dripping water out of it.
Window unit? Tip it so it leans slightly outward so the water can drip outside instead of inside. It is absolutely normal for water to be dripping from any AC.
Here is your response in under 120 seconds.
Thanks for your question @ FixYa.com
Jun 27, 2011 | Heating & Cooling
Water dripping out of rv ac into rv.
Is it a ducted system? If yes, check that there isn't gaps between the divider that separates return air at the front, with forced(cold) air. You can usually use a flashlight and look for gaps, or even (very carefully) feel it blowing cold into the warm air return. If you find some gaps, buy some foil tape, and tape them off good and retry and see if it still happens. Some older units experienced cracks in drip trays that allowed condensation to drip inside as well. Get back to me with year of your RV, and whether it's ducted or non-ducted system, and perhaps I can guide you better on what to look for.
Jun 20, 2010 | Dometic Rooftop RV Air Conditioner
AC works fine but water drips on passenger side
this is normal, water is the condensation leaking out,but if leaking inside the van then the drain is pluged up, the drain is on the pass/side outside the van on the firewall,blow air into drain or stick a coat hanger in to hole until water leaks out,
May 14, 2010 | 2001 Chrysler Town & Country
The water that drains from the airconditioner to outsied is clogged up and not draining how can i unclogg it myself?
I can tell you a few stories of my own - I've had this problem myself and water will eventually build up and leak inside your house - you don't want it to leak on your electrical outlet ! I do not know how long you had this unit or how old is it, but these things can happen over time due to dirt, dust or other foreign objects or rust. Some AC units have fan spinning and picking up the water and spraying it on evaporators, most of it should be evaporated - only excess humidity will cause dripping - on older models water should drip outside through an opening or two at the back of the AC unit.
Make sure your AC is not level, and is tilted about 20 degrees outside, allowing the water to flow outside the AC unit.
You will need to find a way to access your AC unit from outside, locate the areas where the water drips normally, you should see openings, using an object (paper clip, pipe cleaner, etc.) try to insert it in the holes back and forth until you dislodge whatever is blocking the hole - be careful not to damage the very deliate fins at the back of your AC.
if still no water drips then take a ladder and climb up and you shuold be able to see from the inside there should be a slope or container where water accumulates before dripping out, is there ANY water there ? If you mostly see water farther away then your AC is probably not tilted enough to allow water to flow out.
If there is neither any water towards the outer edge where it drips, nor inside, farther away nor dripping inside your home, then it is probably being all evaporated or your humidity level is under control. The more your air has moisture the more water will be produced inside your AC, any excess moisture will accumulate inside your AC - if your AC manages to evaporate all of it, and no leaks inside, good for you, I wouldn't touch it.
Another tip - when you shut down your AC, do you hear swishing and unusual sounds of water ? that could mean accumulated water not being evacuated - Although it IS normal for some stagnant water to remain in your AC - do not worry about that, as long as it doesn't leak inside.
Sep 01, 2009 | Heating & Cooling
Water dripping from furnace while air conditioner is running.
you need to have a drip line that take away the water when the ac is on so the water does not goes into the furnace ,also check for leaky line that could causing water to leak back
Aug 20, 2009 | Heil Sound PR-40 Professional Microphone
A.C. unit
One of the cause of water dripping in the indoor is restricted drainage. To Identify if your drainage is restricted.
- Turn "off " the circuit breaker and take out the face cover of the unit.
- Turn "on" the circuit breaker and start the unit, wait until the unit drips.
- When the unit dripped check the drain pan if overflowed with water.
- If the drain pan is full of water you need to flush the drainage with water to remove the restriction. If the pressure of water in your area is high you can use your garden hose to flush the drainage.
Another is dirty evaporator fins (icing), dirty drain pan, broken drain pan or incorrect installation.
YOU CAN LOCATE THE DRAINAGE AT THE LEFT OR RIGHT SIDE OF THE DRAIN PAN
Aug 16, 2006 | Carrier IBM UNIT 2380 79F4796 Drive Case
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
