Question about Belkin (F5D6230-3) Wireless Router
Belkin f5d7634-4 opening ip number please - Belkin (F5D6230-3) Wireless Router
    Guru:
  • 825 Answers
192.168.2.1
Posted on Sep 30, 2010
  • 708 Answers
Http://192.168.2.1
Port 88 UDP problem
1) You have to enter UDP and TCP on seperate lines with same port numbers in each line respectively. So you will have four lines, UDP 88, UDP 3074, TCP 88 and TCP 3074. Also, make sure you have your 360's IP entered. You can find that in the 360 network info.
2) Also, place your 360's IP in the DMZ. That should help.
3) For testing, turn off the routers Firewall. It will make it easier to figure out what is going on.
Nov 17, 2012 | Gateway Belkin F5D7230-4 802.11g Wireless...
Tip
To Open Port Number or Port forwarding in Belkin Routers for XBOX,PS3,Wii
Hi Friends,
Please follow the default steps for all the belkin wireless routers to open or Forward ports for XBOX 360,PS3,Wii,etc
Before,Preceeding for the steps,please call to the Particular vendor and get the port numbers to be opened and please make a note of it.Also get the ip address of your particular device.
Step 1:Connect the Modem to Router (in the Port named Modem) and take another ethernet cable abd connect one end to the Router(in the port named Wired) and other end to any one of your computer
Step 2:Open an internet explorer and type 192.168.2.1 and click on Enter button in the keyboard
Step 3:Now you will be able to see the belkin router setup page
Step 4:On your left hand side click on Virtual Servers.It will ask for login password,leave it blank and click on Submit
Step 5: Put a Tick mark in the 1st check box
Step 6: In the descrption type it as XBOX360 or Wii or PS3
Step 7: In the Inbound Port type the 1st port number given by the vendor
Step 8: In the Type select it as either TCP or UDP (it will be given by your Vendor)
Step 9: In the IP Address place type the IP Address of your device (get it from your vendor)
Step 10: In the Outbound Port type the same as you have typed in the Inbound port
Step 11: Follow the same steps for all the port numbers to be opened.After completing all the port numbers click on Apply changes
Step 12: After completing this,On your left hand side please click on DMZ
Step 13: Put a Tick Mark in the Check box and type the same ip address given by your vendor for the deivce and click on Apply changes
Step 14: After completing this,go to the device and check whether you are able to access the device in the internet
Regards,
Aysaam
on Jun 09, 2010 | Computers & Internet
How to resolve Belkin N150 conflicting with Linksys WRT54G
Both the routers are having the same default IP addresses that's why they are conflicting.
Put only one router in the switch connected the a PC on the same LAN.
Open your browser and put the default IP address (like for most of the routers 192.168.1.1 or 192.168.0.1), hit enter and give the login ID and password (in most of the cases, admin/password orv admin/admin), go t configuration> IP settings> Static IP Mode> Change the IP from 192.168.x.1 to 192.168.x.2 (or any other other number except 1 and <254).
Save and reboot.
Now enjoy both routers plugged in simultaneously in the same LAN. :)
Sep 03, 2012 | Belkin Basic Wireless Router
I have a newer newer belkin router but i hope you can still help me out,okay when i try to play a game on xbox live it won't let me because it says my NAT rating is closed,how do i set it to open?
Hello your Belkin Routers has a Firewall Feature on it which might be blocking you to Play games on your Xbox.
To Solve this Issue you Just have to open Ports on the Router For your Routers Ip Address or Enable DMZ ( De-militarized zone). Which will Open all the Ports on the router for an Ip address.
---> Steps to Enable DMZ on the Belkin Router
- Connect your Computer to the Router using an Ethernet Cable.
- Open Internet Browser & Goto 192.168.2.1 it will take you to Router Setup Page
- Towards your Left Pane Click DMZ Under Firewall
- Leave the Password Box Blank & Click Submit
- Check the Enable Box
- In the Private Ip Box Type in any Numbers in range of 2 - 254. EG: 192.168.2.9
- Click Apply Changes
- Unplug the Power Cable From the Router & Plug it back After 15 seconds
> Now Let us Assign the Ip Address on your Xbox
- In the Xbox Dashboard
- Go to My Xbox and Open System Settings
- Select Network Settings, Configure Network.
- On the Basic Settings tab, select IP Settings, then select Manual.
- Select IP Address, enter your chosen IP address EG: 192.168.2.9, and select Done.
- Select Subnet Mask, enter the Subnet mask 255.255.255.0, and select Done.
- Select Gateway, enter the Default gateway 192.168.2.1, and select Done.
- Select Done to save your settings.
- Go Ahead & Test your Connection.
Mar 13, 2011 | Belkin (F5D8231-4) Wireless Router...
I have a Belkin Router which has a nat setting type3, I need type2 to play online for most games
Hi i got your problem ....
To enable the belkin router to nat 3 you need to get the port numbers and the ip address of that particular device ...then please the following steps
Step 1) Connect modem>>router>>computer
Step 2)Open the router page
Step 3) On the address bar type http://192.168.2.1
Step 4)On the router page towards the left coloumn check with virtual servers under firewall
Step 5)Enter the port numbers and the ip address
This will surely work out ....if you have any issues please let me know back
Thanks .....
With regards
Priya
Sep 06, 2010 | Computers & Internet
I need to password protect my belkin wireless router
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Apr 23, 2010 | Belkin (F5D7230-4) Router (587009)
My PS3 and my Belkin trying to get wireless
*its simple jus get the port number for the ps3 u can get it from ps3 vendor *once u get it login to the router set up page using a computer AS * open any browser type 192.168.2.1 in address bar * on left hand side click on the virtual servers( password -- leave it blank ) * enter the port numbers only for one ip address only for example 192.168.2.10 for all the port numbers. * then apply changes * then go to ps3 assign a static ip address in ps3 for the ip address the one which u opened the ports for (ex 192.168.2.10) * it will definitely work
Apr 13, 2010 | Belkin (F5D7230-4) Router (587009)
Can not keep connection with ps3 using a belkin_f5d5231_4_router
*u need to open the ports for the ps3 *contact the ps3 and get the port number * open the belkin router setup page using 192.168.2.1 in the address bar *then click on virtual server then open ports toa particular ip only for ex:: 192.168.2.10 *after opening the ports assign the same ip in the ps3 *then sure it has to work without any problem
Feb 25, 2010 | Belkin (F5D5231-4) Router
When I type in the ip address in my browser.....it doesn't open anything. it takes forever then eventually says error. PLEASE HELP!! Trying to find my WPA key so I can connect to XBOX Live. Been trying...
Which IP address are you typing in? The router will have a specific address. Its not your Internet IP address. Go to the Belkin website as the default IP should be th same for all belkin routers.
Jan 06, 2010 | Belkin (F5D8231-4) Wireless Router...
I have a belkin wireless g router and my nat settings are strict?
I understand your problem..To fix this issue all you have to do is,You should open the x- box port numbers on the belkin router(please call tech support for assistance),
And also i would suggest you to assign static ip on x-box on belkin range(192.168.2....) then you need to enter same number on router under DMZ. It may be quiet difficult for you to do all this.please call toll free number"belkin".
Dec 17, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D6230-3) Wireless Router Logo
820 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
