Question about Thomson TE1152 Top Load Washer
Hi I'm getting a flashin problem code of "do3" on my THOMSON TX898 Washing Machine....any idea of the problem?
3 Suggested Answers
  • 155 Answers
SOURCE: My WF740 is also flashing F-05...unable to unlock door!!
The error F-05 indicates that no drain or pressure switch
jammed on full.
Posted on Sep 02, 2009
Testimonial: "Ok thankyou...do i need to get an engineerto look at the machine?..Or is this a simple problem that I would be able to fix myself!? Thanks again!"
SOURCE: My Thomson TX898 washing machine,
I have the same problem 2, DO2 on Thomson TX898
Posted on May 28, 2011
My thomson machine TX898 got error code d17
google the brand-model#-error code
May 21, 2011 | Washing Machines
My top loading washing machine are unable to spin dry..pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 30, 2010 | Thomson Washing Machines
My Front load washing machine has an error flashing that says F 06. It starts washing and then stops about 1 min into a cycle.
Hello, welcome to Fixya. Since many manufacturer's use there own unique error codes, i.e. F06 on some may indicate a faulty motor, others may indicate a faulty pump for example. Can you clarify the make of your machine as well as a model number ? I'll watch for your relpy and try to assist you from there. Macmarkus :)
May 21, 2010 | Washing Machines
How to use thomson washing machine tx 708
I misplaced the manual of my Thomson TX829, please can you advise where I can obtain a new copy.
Jan 15, 2010 | Thomson Washing Machines
jammed on full.
Sep 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
The drum of my tThomson Washing Machine is stuck as the frame has
hi..
This is a faulty water valve assembly. replace asap if possible. the embedded water pressure sensor is damaged.
You will need to call Fisher Paykel so they may direct you to a local technician. the water valve assembly will need to be replaced at this point.
Aug 24, 2009 | Thomson Washing Machines
WD640 aquarius super silent won't spin or drain
hi there......most likley cause is a blocked or defective drain pump....if the water cannot get out of your machine due to the faults above it wont rinse drain or spin
regards Sir Galahad
Aug 16, 2009 | Hotpoint Aquarius WD640 Front Load...
My indesit washing machine keeps flashine f-03
This code relates to the thermistor un the heating element being faulty or has a bad connection with the control board.Hope this helps.
Jan 21, 2009 | Indesit W 123 Front Load Washer
Thomson TE1152 Top Load Washer Logo
35 people viewed this question
Top Thomson Washing Machines Experts
Garth Jackson
highlander28
Level 1 Expert
Are you a Thomson Washing Machine Expert? Answer questions, earn points and help others
