Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Gear cap which attaches to the drive spindle falls off
The gear cap that connects the beaters to the drive spindle is just a press fit and over time the tollerances widen and the cap falls off into whatever is being mixed. As more time goes by the tollerance keep getting wider and now the part won't even stay on through a portion of the mixing process.
  • BABOSYANKEES Feb 28, 2009
    GEAR CAP ALSO FALLS OFF WHAT DO I DO
  • 118 Answers
There should be a lip on the shaft that hold this up. You insert the shaft from the bottom and a pin goes through the gear to hold it in place. Look at the IPB HERE.
Posted on Nov 30, 2008
Kitchen aid model kg25. vibrates and beater hits bottom of bowl
Your worm gear is no longer seated and that is more than likely because the housing cover is probably the old style plastic and it has cracked which allows the worm gear to jump up during operation and turn out of sync. The worm gear turns the drive gear that works the planetary gears which in turn drives the beater. If the worm gear is not turning true then of course it is pushing the planetary out of true as it turns, which causes the beater to slam the sides of the bowl. The question is this...does the beater hit the bowl in the same place on the bowl every time? Or does the beater hit the bowl in different places every time? If it hits the same place then it is probably just a planetary gear of which there are four gears involved and it could be any one of them. It it hits a different place every time it is most likely the worm gear and cover. In either case parts will cost between 30 and 50 dollars. and it takes about an hour to fix.
Dec 30, 2014 | Food Mixers
The beaters will not stay up in my Oster stand mixmaster. The eject lever will not lock them in. Can it be fixed? Or could it be that I need new beaters because they are worn out and do not fit in
wild guess turn beater as you push in to allow the beater to engage the drive, a little like gears meshing. You should be able to feel it lock into the drive.
Dec 21, 2014 | Oster Food Mixers
Is the mixing gear supposed to turn when the pasta attachment is on? (KV25MCXER)
Yes it will turn, just remove the beater. It is a solid drive and cannot disengage from the motor unless you overload it and wreck the fuse gear.
Nov 24, 2013 | KitchenAid Food Mixers
Professional 600 575 watts 6 qt. beater stem is loose and lets beater drop onto bowl.
b68be83b-c0cb-45d6-8d74-337f1cf098bd.jpgThe part you see is called the planetary, it has two shafts, the long one is called the center shaft and if it is falling off you need a new planetary, the second shaft (shorter) is called the agitator shaft (the beater attaches to it, if this is the culprit then1 you are not attaching the beater correctly2 the locking pin that the beater attaches to to hold it in place is missing3 you have way too much "gunk" build up on the agitator shaft and the beater is not attaching correctly4 if the beater falls into the bowl with the agitator shaft still attached you have three additional problems a) the snap ring a top the agitator shaft has broken off or come off which in turn means that
b) the gear at the top of the shaft has come off and may very well been knocked around and possibly damaged beyond future use which means that you will need a new one and also
c) the shaft pin that holds the agitator gear in place has come out or been broken also
the fix is easy and your parts cost $ will be from $30.00 to $80.00 dollars depending on which parts you need. Now before you get palpitations, cost are listed as a possible need
1 new planetary $30.00, you may not need
2 new agitator shaft and gear assembly $27.00, pretty sure that you need but maybe not
3 new gasket $6.00
4 new gear grease $6.00 KA says 2 oz. (don't buy a 2lb (26.00 bucks) can when you only need 2 oz).
Without more clarity or a picture I can't help further. but before you start tearing you machine apart go to the KA website and get a parts list for your mixer
http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD
let us know how you fare on this or better yet get us a little more info and we can help more.
Apr 17, 2013 | KitchenAid KP2671 Professional 6 Series...
BBeater scraping back bottom of bowl
Is the planetary still off before the taper pin is in place?
It's a shot in the dark but if everything lines up, I can think of two possibilities:
1. The taper pin in backwards, and
2. The shaft hole in the planetary is out of round.
Mar 20, 2017 | Hobart N50 Stand Mixer
I cannot get the beater to lock in place. The
Hi VBPROSANDY, When you say beater, I assume you mean your flat beater. Are you having the same problem with your Wire Whip beater and dough hook? If you are not, then the first thing I’d do is look inside the flat beater’s attachment well, to see that there is nothing; i.e. hardened food, dough or batter, in the bottom of it that would prevent the agitator shaft and groove pin from seating properly. The flat beater has two drain holes at the bottom for drainage, but if these get plugged it may prevent accumulated ‘gunk’ at the bottom from escaping, and over time the buildup may prevent the beater from seating properly.
If you find the beater attachment well is clean, then from the KA Instruction manual, to attach the flat beater...
1. Slide speed control to OFF and unplug.
2. Slip flat beater on beater shaft.
3. Turn beater to left, hooking beater over the pin on shaft.
Finally, check the groove pin on the agitator shaft to make sure it hasn’t become bent so that it doesn’t fit the beater properly. Pins shouldn’t bend, but sometimes they do.
The beater attachment process should not require any effort as the agitator shaft should easily fit into the beater’s attachment well and easily turn to the left. Your planetary should not move during this process and if it does move it will take some effort on your part to turn it. The fact that you’re turning the planetary means you’ve turned the beater as far to the left as it should go to ‘lock’ it. When you get this far, let go and the beater should fall into place on the groove pin.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Dec 06, 2009 | KitchenAid KP2671 Professional 6 Series...
Sunbeam Mixmaster 12 speed may need lubrication
Part 1. Oiling the model 12:
Anyone can do this part.
On the top of the motor are four places where oil should be applied.
Starting from the speed finder dial and working forward-
There is a small hole on the top of the motor, just in front of the speed dial. Using a wooden skewer or a match, clean the hole out, and apply two drops of good quality sewing machine oil.
On top of the motor, and near and behind the juicer attaching cone is another hole, sort of key-hole shaped. Clean it out and put in one drop of oil only.
Three drops of oil go into the juicer cone. Let them run down the side of the hole.
Next to the juicer cone is another round hole. You may need to turn the handle as in removing the beaters to uncover it. Clean this hole too, and apply another three drops of oil.
Do not apply more oil than specified. It will get into the works where it shouldn't.
The following proceedures assume some mechanical ability. Read first to assess whether you are competent before starting.
After all these years, the gears in the front of the motor housing probably need fresh grease. This is a fibre based food grade grease that can be obtained from most bearing sellers. (I used a non-food grade grease, but I have to watch that the motor doesn't get too hot, and the grease run down the beaters, which can happen in extreme conditions.)
Prepare to get greasy during this proceedure. Latex gloves are an asset for doing this job.
Remove the cover plate in the centre of the front, and then the central screw from the front and pull away the front housing cover and handle. Don't loose the coil spring inside. It goes over the screw you just undid.
Unclip the return spring on the beater ejector, and remove ejector and spring together, slide the ejector down and off the beater spindles, then up and out of the guides..
There are four screws that retain the gear cover. The lower right hand one also retains a wire. Remove the screws, and gently bend the wire so the cover can be removed. There is a gasket underneath. Take care not to break it, it's brittle.
Once the cover is away, the gears and worm shaft are visible. Using a pop stick or old screw driver, remove the grease around the under side of each gear. A square headed set-screw retains each gear. When you find each screw, remove it completely. Turning the worm shaft will make the gears rotate.
Once both screws are out, pull the beater drive shafts downwards and out of the housing, and lift out the gears.
Using pop sticks, paper towels etc, but NOT solvents, clean out the gear space. Remove all the grease possible. A toothbrush is good for cleaning the worm thread. Use someone elses.
Wash the gears and shafts in petrol, kerosene or similar and dry thoroughly.
Reassembly is the above in reverse order, first filling the gear housing with fresh grease.
Grease each drive shaft lightly before refitting. Note the holes for the set screws in the shafts.
The nylon gear goes on the left, brass under the juicer cone.
Fit the nylon gear first, working the shaft upwards until the locating hole in the shaft can be seen through the screw hole in the gear. Fit and tighten the set screw.
Align the brass gear so both screws face forwards at the same time when engaged with the motor worm, to prevent the beaters clashing. You may have to put the brass gear in and out a few times to get the right teeth engaged with the worm shaft. Then slide the shaft in, once again observing the alignment of holes to ensure the set screw locks the gear securely.
Put everything else back in reverse order. Apply a smear of grease for the beater ejector where it slides, and don't forget to put the wire back under it's screw.
Part 2, speed control.
The jerky operation at low speed is probably due to dirty points in the governer. Addressing this involves disassembling the rear end of the motor.
DON'T pull the motor armature out of the housing without first removing the brushes during this proceedure. There's no need to remove the armature, but if you're curious....
Remove the chrome cap from the centre of the speed finder dial. Remove the lock nut from the thrust control screw under the cap. Remove the dial, catching the washer that goes under the nut.
There is a resistor, usually green, and a capacitor, a small aluminium cannister under the dial. Gently pry the retaining legs away from one end of each and remove them. Note which one goes where so you can put them back correctly. Marking with a felt pen is a good idea.
Now are visible two slotted screws. Remove these screws and pull the governer housing back and away from the motor. Note the pin with a plastic head, and remember to put it back when reassembling the same way around.
Locate and clean the points with a slip of soft wood and metal polish. Clean away the polish thoroughly. Do not use emery paper, it will make the points arc, and speed control will be worse than now.
Put everything back the way it came off.
To reset the governer, leave the locknut on the thrust controling screw loose. Set the speed control to position 1. Whilst pressing the dial home with one hand, screw the thrust screw in or outwards until the motor just starts to run, and lock the screw by tightening the nut. Test the control for full range, and tweak by slightly altering the thrust screw position as required. Getting the speeds just right first go is usually a fluke.
Replace the chrome cap and you're done.
May 12, 2009 | Sunbeam 2485 MixMaster Series Hand Mixer
How do I remove the metal cap above the whisk? I want to use my new ice cream maker but the attachment won't fit unless I take off the metal cap. I've tried everything but it looks like there's no way of...
your not supposed to remove the cap. under that cap is just a gear assembly that powers the beater assembly. some of these attachments are only compatable with certain units. some of the older units arn't compatable with the newer attachments.
May 06, 2008 | KitchenAid K45SS Classic Stand Mixer
Beaters Misaligned
If this is one of the later-model Sunbeams, the housing has an upper half and a lower half. By removing the upper half, you can see the motor and the gear train. You will have to take out one of the beater gear posts and reinsert it to align properly. I suggest you look at both gear posts and check for worn or broken teeth. In which case, you will need to replace the bad part[s].
Older model Sunbeams have a gearbox housing that mounts onto the front of the motor housing. When you remove the gearbox housing, you will see the gear posts inside. Check for worn or broken teeth and replace as necessary. To insure proper alignment when reattaching the gearbox housing, align the two gears relative to each other then push the gearbox housing back onto the motor housing. The motor spindle will slightly turn both gearposts simutaneously during this process but will keep the proper alignment. You may have to repeat this process a number of times until you get it right.
Feb 02, 2008 | Sunbeam 2350 Heritage Series Mixer
Motor runs but the beater does not move
you most likely stripped the plastic gear (Worm gear???).  This gear is designed to fail to prevent the motor from burning out under EXTREME loads (i.e. when a metal piece falls into the bowl). The plastic gear is much cheaper than a new motor.  Look around on this site to see how to get at/repair the gear.  I've found many parts on eBay.com and also PartSelect.com.
Dec 16, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
447 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
