Question about Kwikset 907 907-15 Satin Nickel Powerbolt Keypad Electronic Deadbolt
Replaced the batteries but it still beeps - Kwikset 907 907-15 Satin Nickel Powerbolt Keypad Electronic Deadbolt
  • 963 Answers
Kwikset's warranty covers one year electronics defects and lifetime coverage for the mechanical movement and finish.
Here is a link to it:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
You can contact them from there for further assistance.
Posted on Nov 09, 2011
It was beeping every 15 seconds or so. I pulled unit off ceiling and checked batteries. Reinstalled. No more beeping. Do I need to replace batteries?
The beeping means that the detector was sensing low voltage from the battery. If the battery is over a year old, most manufacturers recommend yearly replacement on smoke detector batteries.
Dec 16, 2015 | System Sensor 2100rfadt Wireless Smoke...
My alarm beeps at night for a short period
if it is about a smoke alarm with a battery in it, when the alarm beeps for no apparent reason, it is a bult in indicator that the battery is flat or approaching a low voltage and needs replacing
If it still beeps after replacing the battery have it checked out as a fire alarm is critical for your safety
Jun 12, 2015 | Kidde 1276-9995 Hardwire Smoke Alarm with...
How do I stop the beeping of smoke detector after battery has been replaced?
How old is it? It may be telling you that it's no longer reliable and must be replaced.
Sep 30, 2014 | Kidde 4618 Firex Hardwire Ionization Smoke...
Why does My alarm still beep after battery is replaced
Could be a bad or used battery. ry replacing it with one that you tested to make sure it has 9V. Also make sure the activator arm that's held in place by the battery body is properly seated and not broken off. If all is OK, and still not working replace the unit.
Aug 08, 2014 | Home
My Weiser powerbolt lock is beeping-changed batteries-won't stop
Why is my Powerbolt 1000 unit beeping?
To determine why your lock is beeping abnormally, please follow these steps:
  1. Take out batteries and unplug powerstrip.
  2. Let it sit for 1 minute, then put the batteries back in and wait another minute.
  3. If it does not beep, the keypad needs to be replaced (17733-1).
  4. If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
Contact Customer service from here:
http://www.weiserlock.com/CustomerService/ProductSupport/SupportContact.aspx
Jan 09, 2012 | Weiser Lock Powerbolt 1000 Lock
We had a power outage for about 45 minutes a few days ago. Ever since then the Powerware 3110 has been beeping. I turned it off and left it plugged in overnight and when I turned it back on the beeping...
This could be several things, fortunately the device should actually be helping you to diagnose the issue. There are different beeps for different issues. They are as follows:
1 Beep Every 5 Seconds = Power Outage\Loose Plug Connection\Tripped Circuit Breaker\Power Cord Damage or Failure
2 Beeps Every 5 Seconds = Low Battery Alarm
3 Beeps Every 5 Seconds = Battery Needs Charging\Service\Replacement
3 Beeps Every 5 Minutes = The Battery is discharged and battery power is unavailable (If this continues battery replacement may be necessary)
1 Beep Ever 1/2 Second = Power Requirements exceed the UPS Capacity (remove some equipment to lighten the load on the unit)
Continuous Beep = Short Circuit / Input Voltage out of Range / UPS Fault (Likely replacement of entire unit)
That should help diagnose the actual issue. If it turns out the battery needs to be replaced they can be found online for around $20. A simple google search for Powerware 3110 Battery should return what you're after. Good luck!
May 05, 2011 | Powerware 3110 UPS System
Powerbolt beeping issues
I removed the batteries and it beeps.
I called customer support. They must have a lot of issues with the keypads, cause they're sending me a new one in 3-5 days.
I thought I would have to mail the whole thing in.
The woman was very friendly.
Great customer support!
Sep 08, 2009 | Weiser Lock Powerbolt 1000 Lock
Getting red light and continuously beep sound to my UPS(Frontech)
hi
If it is showing the red light and continuous beep it shows that the battery is completely gone.
You can buy a battery and replace it by yourself.
Or get it to a professional to change the battery.
you need not replace the whole UPS its just a battery problem.
Thank you
Aug 10, 2009 | Compaq R1500 ( 295459-001 ) UPS...
Smoke alarm beeping
If after replacing the battery the alarm is still beeping, the smoke alarm is bad and needs to be replaced. Hope this answers your question. Best of luck!
Greg
May 23, 2009 | First Alert SA302 Dual System Smoke...
Kwikset 907  907-15 Satin Nickel Powerbolt Keypad Electronic Deadbolt Logo
136 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
