Question about Dell Inspiron Mini 10 Notebook
My dell mini 10 wont start. When I press the start button the white power light comes on and then switches off in a but 2 seconds. The screen doesn't come a live at all. HELP!!!
  • Dell Master
  • 17,130 Answers
You will need to see if there is problem in the bios back up battery or the memory.If on start up you cannot go to bios settings you must consult Dell support centre.
Posted on Sep 30, 2010
Dell optiplex mini tower wont turn on
Make sure the power is being supplied from a working source, then check if the switch on the bottom-back of the computer is switched on. If the power button still doesn't work, try holding the button down for 10 seconds. Next, try switching the switch off, unplugging the computer for at least 30 seconds, plugging it back in, switching the switch back on, and pressing the button.
Apr 25, 2014 | Dell Studio Mini-Tower Desktop Computer
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
Dell mini inspiron mini won't shut down
Force off by pressing the power button for 10 seconds or more. Boot into safe mode, type msconfig in the run line, disable everything that starts. Restart normally, re-enable each program untill you find the one giving trouble.
Aug 30, 2011 | Dell Inspiron Mini 10 Notebook
My dell inspiron mini 10 wont power up at all with charger and only gives me a brief white light when battery and charger are plugged in. Any suggestions
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Feb 25, 2011 | Dell Inspiron Mini 10 Notebook
My Dell mini 10 labtop worked fine 1 hour ago now when I turn it on, the screen is very meesed up. (Its not white) You can make out small things like login but outside of that it is impossible to use.
Hi.
Try turning off your laptop. Remove the power connection and also the battery. Press and hold the power button for about 10 seconds. Connect everything back and try to boot it up. If you still get the same issue check if you are able to see the bios screen on startup. If you do not then most likely this is a hardware issue already. It would be best to have your laptop checked by a hardware specialist. If you are able to see the bios screen and also the windows logo screen and that this occurs when you are in windows then what you could do is go to safe mode and restore your computer to an earlier date. To go into safe mode you will need to restart the computer and start tapping the f8 button when you see the bios screen. From there choose safe mode by using your arrow keys and press enter. Go to System restore. if you are using windows xp then it would be by pressing start then programs then accessories then system tools then system restore. if you are using vista or windows 7 then just type system restore when you press the start button then click on system restore. you will have to restore your system to an time. If that does not work then it would be best to go into safe mode and back up your files from there and reinstall everything.
Feb 10, 2011 | Dell Inspiron Mini 10 Notebook
I can not switch on my mini laptop (Dell Inspiron mini 10), The power button is just lighting on. Within seconds the light disappeared. I took the battery out, but now is also no light on the power...
The power module in your motherboard is malfunctioning. Is the Dell notebook less than a year old? If so, go to www.dell.com and click on Support and go through the process to get an RMA code. You will then be told how to send the notebook back for repair. It will probably take at least 10 working days. If the notebook is over a year old, contact you local computer repair or go to eBay to look into getting a new motherboard. Perhaps, it's time to look for a new PC; they make them to fail these days. You are lucky if you get to 2 years in many cases.
Oct 31, 2010 | Dell Inspiron Mini 10 Notebook
My dell inspiron mini 10 won't boot.There is just this annoying sound that wont stop.
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else. I've removed the battery and unplugged the unit and put it back together and it still does the same thing. HELP!
Apr 21, 2010 | Dell Inspiron Mini 10 Notebook
Dell Mini 10 Won't turn on. When I press the
try to power drain pc first. to do that, turn pc off, remove battery and ac adapter. press down power button for 15-20 sec, then but all back in and try to turn pc on. if still no go, you may need to replace battery or ac adapter, f it still wont work, possible motherboard replacement is needed.
Mar 29, 2010 | Dell Inspiron Mini 10 Notebook
My inspirion mini went into hibernate mode, and now won't restart. tried power button, light flashes 3 times but won't come on. tried pulling battery, no luck. Help?
Try this: Disconnect AC power, pull the battery, then press and hold the power button for 10 seconds. Release the button, replace the battery & AC, and try booting.
Mar 09, 2010 | Dell Inspirion Mini 10 Netbook
Black screen and won't turn off.
press and hold the power button for 10 seconds. If all else fails, diconnect the power cable from the system. Then turn it back on.
Dec 26, 2009 | Dell Inspiron Mini 10 Notebook
Dell Inspiron Mini 10 Notebook Logo
280 people viewed this question
Alun Cox
