Theres is a burning smell which inturn makes the clothes smell? Any suggestions - the machien is only 3yrs old. Also the water smells when the spin stops? Thanks
  • Washing Mach... Master
  • 17,130 Answers
You have not mentioned make or model of the set ,but if this contain heated washing, then it is possible that the heater coils have burned and exposed .
Posted on Sep 30, 2010
Maytag Performa clothes washer. Model LAT2500AAE. Made screeching sounds during spin cycle also burned rubber smell. Turned off. Removed and replaced belts. One belt was shot. Ran a test run and still...
Check to see if your water pump is spinning. It could be seized up and the burning smell could be the belt spinning on the seized pulley. Good luck Friend.
Oct 10, 2017 | Maytag Washing Machines
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Maytag Washing Machines
Top Load making noise. Wash cycle finished, open
bad lid switch.coupling broke and rubber burning or trans locked up
Nov 15, 2009 | Refrigerators
Burning smell at end of wash
could be the belts but it could also be the motor depending on the smell
Jun 04, 2009 | Kenmore 22622 Top Load Washer
Won't spin on spin cycle, smells of something burning.
sounds like the belt or the tub bearings are shot. It is likely that the motor is spinning and the tub is not, causing the belt to burn.
May 25, 2009 | Maytag Washing Machines
Washer makes a squeel and burning smell
belt which operates pump/motor/transmission pulleys
Apr 10, 2009 | Washing Machines
A STRANGE SMELL WHEN DRYING..
sounds like brushes they can cause a burning smell......as for clothes smell after drying the fan in the heater could be dirty but generally that would mean the heater will not work
Mar 18, 2009 | Hotpoint Aquarius WD63 Front Load...
Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Washing Machines
Frigidare top loading washer 6 cycle - 10 years old
you may want to inspect the bottom part and see if it still uses fan belt. it could be that the belt is loose and the motor is spinning but can not drive the transmission. so the rubber burning smell is coming from the slipping belt.
the solution is to tighten the belt or replace it if necessary.
tnx 4 using fixya,
drcool
Sep 20, 2008 | Frigidaire CWS3600AS Top Load Washer
Top Load Washer
there is a drive belt from motor to drum but unlikely it needs tightening but possible. possibly a motor fault - try to identify where the smell comess from
Mar 20, 2007 | Whirlpool LXR9445JT Top Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
